Question about Epson Stylus C86 InkJet Printer
Changing Cartridges does not move into view so I change it
When I lift open the lid to try to change the cartridges on my Epson StylusSX100 the cartridges are tucked away in one corner and I cannot access the cartridges to change them is there a button I can use so that it moves to where I can access them to change the cartridges.
  • 154 Answers
Try the on/off button with the lid open. it should move the cartridges.
Posted on Jun 21, 2009
    Novelist:
    Sniper:
  • 68 Answers
"When I lift open the lid to try to change the cartridges on my Epson StylusSX100 the cartridges are tucked away "
Lifting the lid will not move the print head on most Epson printers, they don't work the same way as say HP or Canon printers. In fact you can still print with the lid up on most Epson printers.
When ink cartridges are showing empty by the computer software, they should in fact also be showing by the printer software and so you should have a light of some sort illuminated on the printer.
The light is usually within or next to a button on the printer and it is this button you need to press to cause the print carriage to move to the change position so you can access the ink cartridges.
If you have no light on the printer then either you are only getting low warnings (yellow triangle) and the cartridge is not yet ready to be changed or it could be that you have a LCD screen on the printer in which case, you'll have the empty message there and the ability to use a Menu or Maintenance/Tool button to select cartridge replacement.
When you either press the illuminated button or select cartridge replacement on the printer menu, the carriage will move to the change position, however if it doesn't, it will be for one reason and that is simply that the printer is still busy doing something else.
This can be a variety of things:
A print job part printed
A print queue holding up the printer
A paper jam
A multitude of printer errors
The first two possibilities are easily remedied: go to Control Panel, select Printers/Faxes, double click your printer icon (e.g. SX100), click on the Printer tab and select Cancel All Documents... wait a few seconds and all pending jobs will disappear.
If you've had a paper jam, normally after you clear it, a small amount of paper sometimes gets left behind and gets shunted onto the sidewall of the printer by the carriage, which stops the carriage reaching its full travel and throwing up an error, rendering the printer unable to print or carry out any other function. Simply remove the paper and switch printer off and on and it will reset.
If you have an error of any other kind, many remedies and fixes for these can be found on my website http://www.the-inkstore.co.uk/frame/pages/epson.htm
There should be no other reason why the print carriage does not move to the change position apart from one very obvious one to me but surprisingly unknown to most people. This is when you press an ink button on the printer to move the carriage, most Epson printers have a plastic pointer on the chasis (plastic frame) where the carriage first moves to lining up on a particular cartridge colour with the pointer to tell you which cartridge needs changing, if you press the ink button again, the carriage will align another ink colour to the pointer if another needs changing, if not, the carriage will now move to the change position so that you can remove and replace the ink cartridge.
These methods above are good for 90% of Epson printers.
The difference with the new 2, 3 & 4 series printers without LCD screens, is that instead of a pointer system to tell you which cartridge needs changing, there is only a small gap for you to access the ink cartridges and only the one that needs changing will appear in that gap and obviously any others that also need changing will appear there everytime you press the ink button.
I hope this helps all Epson users that need to know how to change cartridges and why the carriage doesn't move to the correct position when expected!
Regards
Aeronautical
Posted on Oct 25, 2012
How to change the ink of printer Epson stylus Office BX300F. Show me in the computer to change the ink in printer now.
Turn on your printer and raise the lid or press the cartridge changing button. Wait for the cartridge carrier to slide out.
Lift the cartridge holder lid, and the cartridge will pop up for removal.
Carefully remove the tape from the ink opening on the bottom of new cartridge.
Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been.
Close the cartridge holder lid and press the cleaning button to charge the cartridge.
Close printer cover.
Watch here full details:-https://www.youtube.com/watch?v=8gL5xoiDenA
Still unable to change the ink, you should go to customer support at +1-800-243-0051 ' +1-800-243-0019
May 05, 2017 | Epson Office Equipment & Supplies
Please give us step by step instruction on how to change ink cartridge?
  • Turn on your printer and raise the lid or press the cartridge changing button.
  • Wait for the cartridge carrier to slide out.
  • Put your finger behind the ridge on the top front of the old cartridge and pull it toward you to remove. If you have an Epson printer, lift the cartridge holder lid, and the cartridge will pop up for removal.
  • Carefully remove the tape from the ink opening on the bottom of new cartridge.
  • Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been.
  • Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned.
  • If you have an Epson printer, close the cartridge holder lid and press the cleaning button to charge the cartridge.
  • Close printer cover.
  • Mar 03, 2011 | Epson Stylus Multifunction Inkjet Printer/...
    Fter lifting lid how do you get the cartridge holder to move to obtain access to change cartridge
    After opening the lid, just wait 10 to 30 seconds -- it should slide over.
    Or, if the printer has a few buttons on its face-plate, eg., "form-feed", "rain-drop",
    press that "rain-drop" button to move the print-head.
    Feb 22, 2011 | Epson Stylus Multifunction Inkjet Printer/...
    Trying to change ink cartridge on epson nx515 printer. how do I move the container out from under the printer to change it?
    If your printer is out of ink, it will display the ink that you need to replace. Just open the lid and press the OK button.
    If you want to replace an ink before it runs out, press the Setup button then go to Maintenance and press the OK button. Select "Ink Cartridge Replacement" or "Change Ink Cartridge", then press OK. You can now lift the lid then replace the ink.
    Nov 18, 2010 | Epson Stylus Multifunction Inkjet Printer/...
    How to change ink cartridge on Epson SX100?
    Lift the whole top section up (from under the scanner bed) and the ink cartridges will move to the centre allowing you to lift the plastic clip up and remove and replace the cartridge. DO NOt try and drag the cartridges to the right place. It should do it automatically provided the cartridges need changing. Good luck
    Jul 15, 2010 | Epson Stylus Multifunction Inkjet Printer/...
    How to change ink cartridge? When scanner lid is lifted ink cartridges do not slide over to be removed.
    If the printer still thinks the cartridges have some ink in them (ink light blinking, but NOT SOLID RED), it won't move the carridges into place- this only happens when they are completely empty. if you want to change them MANIUALLY you will have to look for "changing ink" in your manual- usually, but not alwyas done by holding down the INK button for 3 seconds, but like I said- check the manual, and if you don';t have it, downlaod from EPson website
    May 31, 2010 | Epson Stylus NX400 InkJet Printer
    Cartridges on 924 can't be accessed for changing
    When changing ink cartridge on this printer verufy first that the power is on. Once you lift the lid it will move the cartridges into view so you can access them.
    Mar 09, 2010 | Dell 924 All-in-One InkJet Printer
    How to change the ink of an epson stylus sx215
    press the index sheet button and the scan button at the same time, you then get setup menu. use" >" to select "change ink cartidge". the ink cartidge will move to the opening position. lift the grey plastic clip at the back, and it will open towards you. then they just pull out
    Jan 07, 2010 | Epson Stylus Multifunction Inkjet Printer/...
    I'm trying to change an ink cartridge. Cartridges
    Usually the printer manual will have instructions on changing the cartridge. If you don't have a manual, there is a chance you can find one online by googling the make and model number. On some printers the cartridges center when you open a door to access them, or lift a lid or a scanner deck, or turn off or turn on the printer.
    Oct 03, 2009 | Office Equipment & Supplies
    Epson Stylus C86 InkJet Printer Logo
    496 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
