Question about Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer
Maytag LAT9205AAE washer not filling with water
It will go through the rinse cycle on Regular Cycle but there is no water to drain out and it will not operate at all on the Permanent Press Cycle
dididsaythat
  • 291 Answers
SOURCE: Amana LWA40AL will not go to agitate cycle
Sounds like a timmer to me.. got a couple bad cycles too bad its the main cycle
Posted on Sep 05, 2007
vest6
  • 196 Answers
SOURCE: Washer is not filling during rinse cycle.
Sounds like the water is being siphoned out by the drain hose. Check to see if the drain hose rises above the top of the tub.
Posted on Jan 08, 2008
SOURCE: GE top load washer won't drain or spin
there was something stuck in the water pump. we pulled it out and good to go.
Posted on Jun 15, 2008
onthejob5130
  • 640 Answers
SOURCE: Washer quitting on rinse cycle
no cold water ,,lid switch or defective
Posted on Dec 25, 2008
jumptrout51
  • 3361 Answers
SOURCE: amana washer only works on delicate cycle
Open the control panel. Unplug the timer and then plug it back in good and firm.
If it does not work correctly after that,
Replace your timer.
Posted on Mar 12, 2009
Why won't maytag MVWC6ESW go into rinse cycle?
The cold water valve screen in the washer water valve is clogged. You have grit in your water and it will continue to happen until you get a filter system installed on to it.
Mar 18, 2016 | Maytag MVWC6ESWW Washer
It will not drain the water on the rinse cycle
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Mar 24, 2010 | Maytag Washing Machines
Maytag washing machine skips rinse cycle
I found this problem with mine intermittently and it was because i had filled the machine too full that it was too heavy to initiate the spin. maybe try a lighter wash?
Jul 03, 2009 | Maytag Washing Machines
Rinse cycle wont fill
check your drain hose. needs to be at hieght of tub before entering the drain....should only be 3-4 inches in the drain and secured with a ziptie.
Jun 08, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Water will not stay filled in tub on rinse cycle
It sounds like a siphon issue.
Check that the drain hose does a high loop before it goes into the drain pipe. (ie. drain hose loops above the water level inside the tub). Make sure the drain hose is not pushed too far down into the drain pipe. Also if the drain hose is sealed to the drain pipe this will create an airlock and a siphon will occur, allow air to enter between drain hose and drain pipe connection.
This should help you but if there is still a problem let me know and I'll try to assist you further.
Mar 21, 2009 | Maytag Washing Machines
Oct 29, 2007 | Maytag Performa PAV2200
Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer Logo
109 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
