Question about Car Audio & Video
Does anyone know were the acc. connection is located for portable device in a 2003 Yukon Xl? I am trying to instal 2 flipdown monitors. I would greatly appreciate any advice.
  • 578 Answers
Get a read out of the roof light curcuit
Posted on Jun 27, 2009
Where is the fuse to the alarm for a 2003 gmc yukon
2003 GMC Yukon Car Security Wiring Diagram
www.modifiedlife.com/2003-gmc-yukon-car-security-wiring-diagram/
Whether your an expert GMC Yukon car alarm installer, GMC Yukon ... GMC Yukon, a 2003 GMC Yukon car alarm wiring diagram can save yourself a lot of time. .... Alex, double check ALL your fuses and make sure ALL your fuses are good.
How to Disable a Car Alarm - YouTube
? 2:41
https://www.youtube.com/watch?v=EKbjYlK4g0E
May 13, 2009 - Uploaded by ehowauto
In order to disable a car alarm, an individual will have to locate the horn that was put in and disconnect it, or ...
GMC out alarm fuse Questions & Answers - Fixya
www.fixya.com/tags/out_alarm_fuse/browse/gmc
If you have an alarm installed remove the in line fuse from the alarm and see if that ...Multiple issues with my 2003 GMC Yukon XL and hope someone can offer .
Jan 20, 2016 | GMC Cars & Trucks
Directed 10.2
remove all the wires connected externally and then try as some of the wire has got loosed and not supporting the device to work properly.remove the wires and then reconnect it properly.
Oct 25, 2008 | Myron & Davis ADM169GY 7 Inch Flip Down...
Does my Yukon have remote start?
There is NO WAY that anyone online can tell you what aftermarket equipment has been installed on your vehicle or where any of the components for such equipment would be located. It is hard enough to figure out where some of the factory installed components are located on some vehicles.
Your best bet would be to take the vehicle to an experieced auto repair technician. There is no substitute for an evaluation by someone who is familiar with the vehicle and can give it a first-hand look.
Nov 22, 2011 | 2003 GMC Yukon XL
2001 yukon Xl 1500 intermittent connection to rear ac . I need to know location of ac relays and wiring diagram
YOUR REAR AC AND HEATER CONTROLS SHOULD HAVE RR HVAC FUSES IN THE FUSES RELAYS BOX UNDER THE HOOD IN THE ENGINE COMPARTMENT.
Jul 21, 2011 | 2003 GMC Yukon XL
Which fuses is for the lighter in the car?
There are two fuse boxes on a 2003 GMC Yukon XL.
One is on the drivers side of the instrument panel. It will be visible when you open the drivers door. Remove the cover and you will locate several fuses.
The other fuse box is in the engine compartment. When you open the hood, there will be a fuse box on the right hand side of the engine.
The lighter fuse is located in the car . It should be marked 20A and its location should be designated by the schematic in the cover of the fuse box.
Feb 19, 2011 | 2003 GMC Yukon XL
Where is TPS sensor location on engine of 2003 GMAC Yukon XL denali?
TPS is always on the side of the throttle body, attached to the butterfly/throttle blade. Remove the tube that goes from the air filter housing to the throttle body, it'll be directly across from the blade, usually a squarish box with 2 wires connected to it.
Jan 25, 2011 | 2003 GMC Yukon
2003 YUKON XL 5.3L (I THINK), HAD WINDSHIELD REPLACED, GUY CUT MY REARVIEW MIRROR WIRES, HE FIXED THOSE AND NOW I HAVE POWER TO THE MIRROR BUT MY TEMP GAUGE ISNT WORKING....SAYS "OC".....IS THE...
Call a GM dealer for the number as these have changed since then. A good qualified Tech with a hi-end scanner should be able to find the problem.
Jan 11, 2011 | 2003 GMC Yukon XL
Where to locate cabin air and heat filter for 2003 yukon xl
It does not have one. Starting in 2003 the cabin filter was no longer installed on your vehicle.
Jun 10, 2010 | 2003 GMC Yukon XL
2003 Yukon DVD player won't work.
you might have to go to the dealer or go to a car audio shop
Feb 06, 2009 | 2003 GMC Yukon XL
The heater fan in my 2003 GMC Yukon XL will not turn off, even after the key is turn off, and the door is opened.
I don't know if you already fixed it, but I had the same problem on my 03 yukon, TysonRicky is right. In my case it was the blower control module. You can find it right under the glovebox. It cost me close to $100 for a new one, but very easy to replace. Can't even imagine how much it would've cost me if I had a mechanic do it.
Dec 08, 2008 | 2003 GMC Yukon XL
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
