Question about CyberPower (CP1200AVR) UPS System
Cyberpower AV1200 battery backup box - flashing green light. Does this mean the box is recharging? We had a power outage for about 5 hours.
flopez
  • 161 Answers
SOURCE: CyberPower 325SL won't work...
NEVER mix surge protectors and UPS!!!. Doing so overloads whoever of the two gets connected to the wall. This equipment is built to be plugged DIRECTLY to the wall. Your unit just crossed it's inner battery. Take it to a recycling center, then stop on your favorite electronis shop and buy a new one.
Posted on Sep 21, 2007
  • 37 Answers
SOURCE: Cyberpower 575SL stored unplugged x 5 wks-won't power up
check the battery it could be the battery is dead.. if it is so replace the new batts.. than plug in the power to ups.. n turn on it i suggest doen't turn off the power all the time i might cause the lifespam of the battery to shorting.. normal the ups can be use up to 3 yres time..
Posted on Mar 24, 2009
  • 26 Answers
SOURCE: CyberPower 325SL backup system
That's a tell tale sign of wornout batteries. They last about 3-4 years in a UPS like this. Here's a replacement: http://www.batteryinternational.com/cyber-power-cps325sl-ups-battery-ups-batteries-f1.html
Posted on Oct 23, 2009
  • 26 Answers
SOURCE: Cyberpower 725sl
First - turn off the unit and unplug. There are six philips screws on the bottom of the unit. Remove these and the top will come off. There are still some wires connecting the top to the bottom, but you should be able to access the battery. Pull off the connectors on the battery and replace with a new one. A new battery can be found here: http://www.batteryinternational.com/cyber-power-cps725sl-ups-battery-ups-batteries-f1.html
epettingill
  • 175 Answers
SOURCE: cyberpower 425 va When the device kicked in during
You can change that. It is designed to alart you during a power outtage. That way you will have time to shut down your servers. It will alway alarm during a power outage. But check to make sure your batteries are in good condition
Posted on Sep 09, 2011
Battery Back-Up not coming back on after power outage. Charged for several days without anything plugged in with trip button pushed in. Surge side still working. No beep light or anything on battery...
Does the unit have a breaker on the back? There may also be a fuse. You should be able to find a users guide on the CyberPower website.
If the unit may have failed during the power outage.
Jan 07, 2013 | CyberPower Computers & Internet
Cyberpower 425 va When the device kicked in during
Sep 09, 2011 | CyberPower Intelligent LCD CP825LCD 825 VA...
After battery replacement, upon power up, constant beep with fault light full on and battery light flashing. On some trys, the bypass light will also light up. No response from buttons. Unit is...
Try and push and hold the on button for about 3 sec. This will start a manual battery test. If only three of the five battery led illuminate allow the ups to recharge the batteries for 24 hours. Battery light flashing means internal battery source not available. Check battery connection, completely power down and reboot UPS
Sep 06, 2011 | Liebert UPStation GXT1000RT...
One side of my Cyberpower 525SL stopped working. When i press the red button the green light comes on, but goes off quickly accompanied by a beeping. The TV, dish, and vcr/dvd continues to work. Help...
Hi droger68,
The reason for the issue that you have right now with your Cyberpower 525SL is a bad battery. This means that some of the battery relay's component or relay has failed. You may contact the manufacturer if it's still under warranty. If not you may check this site they do have battery for your machine.
Hope this helps.
Thank you for using FixYa.
May 24, 2011 | CyberPower 525SL (CPS525SL) UPS System
Lights on Rechargable Lantern.. Swissgear SG66301
I don't know how to solve your problem but, the three lights mean this:
Red LED light indicates the battery is being charged
Green LED light indicates that the battery is fully charged
Amber LED light incidates that the battery power level is low - the battery needs recharge.
Do not recharge you battery over 24 hours.
Nov 03, 2009 | Kitchen Appliances - Others
Mar 22, 2009 | CyberPower 575SL (CPS575SL) UPS System
'Battery' outlet dead.
Hi There, Its definately the battery. The batteries can be replaced.
Nov 05, 2008 | CyberPower OfficePower 650SL UPS System
When power goes out, it turns off.
Yes, that could be the case. Eventually, a battery will be unable to recharge and would need to be replaced.
You could get a new battery from a local battery specialty store like Batteries Plus or Interstate Battery, or online at www.replacementupsbattery.com. A new battery would be about $30. If you took your old battery there, they could recycle your old one, as well as match it up with the correct one you would need (BP7-12 battery).
We have a 3 year warranty on all our battery back up units. If you have any questions, you could contact us here at CyberPower Systems Technical Support at 877-297-6937, M-F 8-5 Central, or email us at tech@cyberpowersystems.com.
Sep 14, 2008 | CyberPower Office Power 585AVR...
Cyberpower 725sl
Yes, it would appear that you need to replace the battery on this unit.
You could get a new battery from a local battery specialty store like Batteries Plus or Interstate Battery, or online at www.replacementupsbattery.com. A new battery would be about $30. If you took your old battery there, they could recycle your old one, as well as match it up with the correct one you would need (BP9-12 battery).
Mar 15, 2008 | CyberPower 725SL UPS System
How old is the unit and have you ever replaced the batteries?
Sep 14, 2007 | CyberPower 325SL (CPS325SL) UPS System
CyberPower (CP1200AVR) UPS System Logo
860 people viewed this question
Top CyberPower Computers & Internet Experts
George Nalley
Level 1 Expert
Paul Bade
David Payne
David Payne
Are you a CyberPower Computer and Internet Expert? Answer questions, earn points and help others
