Yes, it is the problem with the Audio Driver.
Click here to go to the website which will allow you to download Audio Drivers for free. Download them and install to have your speakers working again.
Don't forget to rate the solution.
If it's just the drivers you can anytime look for them using the Google.You should save all your photos in any other drive other then C drive or in any other flash/external drive you can save it in your cell phone and later on load it back to PC.Make sure while you install windows you don't format the drive you have put your photos in.
By default C Drive is meant for installing windows.
2) Double-click on the downloaded file to run it 3) AVG will present you with three options to choose from. Choose the Uninstall option to completely uninstall AVG
Add/Remove Components - choose if you want to add/remove some components or reinstall the entire AVG program Repair installation - this option repairs or reinstalls missing or damaged components of AVG Uninstall - this option removes the AVG program from your PC 4) Once the uninstall has completed, restart your computer. You can then proceed to install another antivirus or install AVG again.
REset your Bios setting ..and then boot your computer to safe mode and then remove the raid installation from the add/remove programs....do not boot your computer from the utility disk.
what I would do is delete the hard files first. do this by going to Start then hitting the Search button in the search bar type Lexmark X3550 and all subfolders do a search in your hard drive more possibly labled C:// drive once all those folders appear making sure that only Lexmark information is shown drag and drop these in the recycle bin. next go back to Start-then Control panel-then add or remove programs scroll down once populated search programs appear search to see if there is an icon for lexmark if this is so then click add or remove button after highlighting and click to remove. the next step is to remove the printer from the computer and remove the power cord. reinstall the printer as a new install first time install follow the instructions that are on your install disk.
try this steps When
installing Sigmatel* or Realtek* audio drivers (either from the Express
Installer CD or using the latest driver download available from the web), the
installation may fail with either of the following error messages: ·Device Object not present, restart
the system and run setup again. ·The system does not support the
driver you are attempting to install. The Universal Audio Architecture (UAA) High
Definition Audio class driver for Windows* may be corrupted or causing problems
with the audio driver installation.
To resolve this, try the following: 1.Click Start > Control Panel > Add/Remove Programs. 2.Look for the following two items: Realtek* High Definition
Audio Driver and High Definition Audio driver Package - KB888111. 3.If these items are listed in Add/Remove programs, remove them.
4.Restart Windows. 5.Download the latest audio driver for your desktop board
from DownloadCenter. 6.Double-click the filename to extract the files. 7.Go to the folder where the files have been extracted and browse
to the \HDAQFE\xpsp2\us\ folder or the \MSHDQFE\Win2K_XP\us\ folder.
(The name of this folder depends on your desktop board model.) 8.Double-click the file kb888111xpsp2.exe to install
the High Definition Audio Driver Package. 9.Restart Windows. 10.Install the audio driver.
In order to update your system from the current Windows operating system to Windows XP Home, there are several steps that need to be taken prior to upgrading. Please follow the items listed below in order to prepare for Windows XP.
Uninstall Trend PC-cillin2000
Click the Start button located on the Windows taskbar. Choose Control Panel, highlight Settings and select Control Panel.
Double-click the Add/Remove Programs icon. Click install/Uninstall tab, select "Trend PC-cillin 2000".
Click the Add/Remove button to uninstall "Trend PC-cillin 2000".
Uninstall NTI CD-Maker 2000*
Double-click the Add/Remove Programs icon. Click the Install/Uninstall tab, select "NTI CD-Maker 2000".
Click the Add/Remove button to uninstall "NTI CD-Maker 2000".
Uninstall Intel LANDesk Client Manager*
Double-click the Add/Remove Programs icon. Click the install/Uninstall tab, select "Intel LANDesk Client Manager 6".
Click the Add/Remove button to uninstall "Intel LANDesk Client Manager".
Uninstall PowerDVD*
Double-click the Add/Remove Programs icon. Click the install/Uninstall tab, select "PowerDVD".
Click the Add/Remove button to uninstall "PowerDVD".
* This software is optional. If this software is not installed previously, please skip the step.
