Question about Whirlpool GD2SHGX Refrigerator
Smell fish odor when fan comes on.
I HAVE A SMALL KEMORE REFRIGERATOR IT SMELLS WHEN THE FAN COMES ON BAD FISH ODOR. IT ONLY DOES IT IN THE SUMMER TIME NEVER IN THE WINTER. CAN'T CLEAN THE DRIP PAN WON'T COME OUT NEVER TO MUCH WATER IN IT ALWAYS DRY. FREEZER ON TOP ITS A AD-18 NEED ADVISE AND HELP.
THANK YOU TIM
  • Whirlpool Master
  • 4,655 Answers
Tim, Clean the refrigerator completely with clorox and water. Unplug and remove the rear panel in the back of refrigerator and wash the evaporator coil with this solution. Check the amount of flow to the condensate pan below. The drain line has the gel and this contaminated smell from top to bottom and you will need to insure that all the smell remaining in the drain is draining freely and decontaminated with the clorox. Do these things and wash the remaining pan below the best you can and you will be set to go.
Posted on Jun 21, 2009
  • John Tripp
    John Tripp Jun 21, 2009
    Coils behind the back wall in freezer.
Fridge and freezer smell like fish
I suspect u have a plugged evaporator drain plug hole and rooting food smelling
Jul 17, 2014 | Kenmore Refrigerators
There is a strong odor coming from the freezer something like a fish smell or a burnt wire. The ice maker is working ok and the fan blows air just fine and the freezer and refrigerator are operating just...
The smell could either be the fan motor or the defrost heating coil...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Amana ABB1927DE Bottom Freezer...
My sub zero ice smells bad like fish how di I remove and clean?
My ice maker smells like bad fish too! Emptied everything out. Cleaned every part, placed baking soda inside to absorb odors, but still stinks! Why? What more can I do?
Mar 07, 2011 | Sub-Zero 632 / S
Bad smell that won't go away
try a bowl of white vinegar for a week or so. m just dont spill it!!
Sep 21, 2017 | Amana 22.6 cu. ft. Side-By-Side...
Chemical smell in freezer and refrigerator
Have you tried cleaning wil Bon Ami ? Sometimes , we have to clean our reconditioned appliances that we sull to environmentalists ( detergent smells , fafric softner smells , etc , ) . Refrigerants ( freon ) have no odor , so it has to be the inside plastic which has the odor . Try Bon Ami and if that doesn't work , stuff 1 freezer shelf with crumpled up newspaper . The ink in newspaper , absorbes odors . This is the only way to remove fish odor in freezers that have quit cooling .
Aug 30, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Fish odor in freezer and fridge
Unplug first. You will need to clean the inside of the refrigerator and the freezer with a good cleaner and warm water. After this you need to remove the rear panel in the back of the freezer and spray water with Clorox on the evaporator coil and pour some of the solution down the defrost condensate drain to disinfect and remove the odors that drain down that hole to be evaporated and returned to the air in your home. That should take care of the fish smell, Please rate my solution, Thanks, Sea Breeze
Aug 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Foul odor from back area of fridge/Kenmore bottom freezer
I had the same problem, but just fixed it. I have a maytag bottom freezer and when the fan blower comes on, there was a foul/stale smell that permeated the kitchen. There is no drip pan that I could remove to clean.
I just removed four screws from the back cover of the fan blower area, reached in with a small cup of organic odor remover and poured it into the drip pan just under the fan blower.
Any odor remover would work. probably vinegar or enzyme odor remover would work, too.
I now have fresh smell when the fan blower comes on.
Jul 03, 2009 | Kenmore 50522 / 50524 Side by Side...
Fish odor
I turned off my frig and washed it out with soapy water, then I went over it and cleaned it out with lemon and vinegar. I let it sit open for one day. It did not work. As soon as I plugged in the frig it was smelling like shrimp again. Then I put two round cake pans FILLED with ground coffee and crumbled up news paper lightly sprayed with water and let it sit for two whole days. It WORKED. My frig does not smell like shrimp or fish any more. It smelled like coffee but it will go away in a couple of days and your frig will smell good.
Feb 18, 2009 | Thermador 42 in Built In Custom Panel Side...
Refrigerator Smell
remove grill. pan will not come out ( leave it in place ) took an empty liquid dish detergent botlle of bleach and water squirt into pan let it sit - scape if needed . then take a wet/dry vac - repeat)
I will let you now if the odor is completely gone
Oct 15, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Very bad odor in Maytag refrigerator
There is a very bad smell from the bottom of the refrigerator . There is a pan under the refrigerator with a very bad smelly Liquid , How can I clean that pan I couldn`t pull it out ? Thank you
Feb 20, 2008 | Refrigerators
Whirlpool GD2SHGX Refrigerator Logo
456 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
