Question about Xerox DocuMate 510 Document Scanner
I had a paper jam in my scanner a few months ago. I got the paper jam out. But now, when I try to scan from the ADF, the paper goes through fast and then stops half way through and an error comes up in Adobe "paper jam." I am an insurance agent and have policies to scan and it's taking me 10 times as long to do it in the flatbed. HELP ME PLEASE!!!
  • 490 Answers
There are sensors under the ADF which sense the movement of paper and the presense of paper. Either they are jammed or faulty. Clean them thoroughly.
S. Mohan
Posted on Jun 21, 2009
Adf konica minolta bizhub 350. theres adf working good but no printout. a few minute machine says jam paper at adf. actualy original it was throw out.. help me please...
Konica Questions answered here ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/40820
Aug 22, 2008 - Am working on a Magicolor 2300 DL that sometimes fails to lift the paper tray ... good afternoon I have a konica minolta bizhub c550 when I open the ... I'm no printer tech, but in most other lasers (HPs, etc) the paper tray lifts, .... It seemsthere is a "waste toner sensor" which only lets the printer print out a few ...
Konica Minolta paper jam adf scanner Questions & Answers ...
www.fixya.com > Forum > Tags > paper jam adf scanner
Question about bizhub 350 All-In-One Laser Printer ... Konica Minolta bizhub 250 jammed but no paper ... Good luck. ... ...paper is there if the switch is working the adfboard is fualty or the cable between the machine and adf broke from all the ...
Konica Minolta bizhub document feeder not working ...
Jan 23, 2016 | Konica Minolta Office Equipment & Supplies
Fi-6130z fujitsu scanner jamming repeatedly
Hello Meg,
To troubleshoot your scanner issue, yuo are advised to perform the steps provided below:
1.Remove all documents from the ADF paper chute.
2.Open the ADF while pressing down the ADF open lever. If your has the imprinter option attached, please open the imprinter and then open the ADF.
3.Remove the jammed papers from the ADF.
4.Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, then please check the followings:
1. Do the documents satisfy paper specification?
2. Have the documents been jogged?
• Align the edge of documents for stable paper feeding.
• Remove documents with crease or dog-ear.
• Scanning different width of documents may cause skew and result in paper jam.
3. Are Chuter Unit (ADF paper chute),Guide P ASSY (Sheet guide), Feed roller cover (plate guide) and Brake roller cover installed correctly?
4. Clean the Feed rollers, Eject rollers,Plastic rollers, glass surface and paper feeding surface, and see if the error is resolved.
5. Check the consumable counter from the TWAIN driver screen. When the counter exceeds the values, replace Pick roller or Brake roller see if the error is resolved.
6. If the issue still persists, then you are recommended to contact the nearest Fujitsu service center for further assistance.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Nov 26, 2013 | Fujitsu Fi6130z Sheetfed Scanner
Samsung CLX-3160N Document jam Scanner Error
the printer samsung clx 3160nprinter to check the any papper part .to clear the papper jam then will be the adf scaner sencer hang.so you can change the adf paper senser or correct fix the senserliver. best wishes
Apr 05, 2013 | Samsung CLX 3160fn All-In-One Printer
My Documate 152 is saying paper jam but no paper jam
E08 error message which indicates papert jam is caused by lose or mis-alligned input paper tray (automatic document feeder).
Resolve issue by powering off the scanner, opening the paper path section, removing the adf, and then re-seating the adf.
Mar 26, 2010 | Xerox DocuMate 152 Pass-Through Scanner
Richo is200e scanner ADF thinks there is paper in the ADF and asks to clear the originals before trying to scan. We have checked the ADF for paper jam and tried cleaning the unit but it will not clear the...
These scanners will collect alot of paper dust. You need to remove the ADF cover and using compress air and or a vaccum blow out the jam/original photosensor's, I believe there are 4 sensors. Power OFF then ON and try it..
Mar 22, 2010 | Ricoh IS200E Flatbed Scanner
Fi-6130 not grabbing paper, displays Code: DS32002
My scanner is Fujitsu M4097D. I just have problem with ADF: Error Code DS32002: Paper jam in the ADF. Here is my solution: 1. Bend two white platin pieces down a little bit in order to "sensor" the paper scanned. This problem is occurred after I am scanning 50 thick pages. Until paper count 42, it is stopped with error code DS32002. Hope help anybody having this problem.
Jan 06, 2010 | Fujitsu ScanPartner fi-5120C Pass-Through...
ADF paper jam, when there is none
If you are receiving an Error Code 103 or a Paper Jam error, but there are no pages in the ADF (Automatic Document Feeder), follow the steps below:
  1. Close the scanning application (such as PaperPort)
  2. Turn off the scanner and the computer
  3. If you have a combination ADF with a Flatbed scanner, unplug the ADF cable from the base of the scanner
  4. Plug the ADF cable back in
  5. Turn on the scanner power
  6. Turn on the computer
  7. Try scanning again
For a Paper Jam or Error Code 103, make sure that the ADF cable in the rear is connected to the scanner base. Check the flatbed to make sure that it is clear. A page incorrectly placed on the flatbed may interfere with a page feeding through the ADF.
If your scanner stops scanning due to a paper jam in the Automatic Document Feeder (ADF), a warning dialog box appears after a few moments.
To clear a paper jam:
  1. Open the Automatic Document Feeder cover.
  2. Remove the jammed paper and close the cover.
If you are receiving a paper jam error, or if the scanner is running continuously, check to make sure the paper sensor arm is not stuck down.
  2. Look for the small black plastic arm
  3. When you press on this arm, it should move freely up and down
  4. If the arm is stuck down, please contact Technical Support for troubleshooting options
  5. Close the ADF cover.
May 26, 2009 | HP Scanjet 8350 Flatbed Scanner
E9 code
E9 code means there is a paper jam.
Clearing Paper Jams
Document Feeder, a warning dialog box opens after a few
moments.
1. Press the ADF cover release on the top-left of the scanner
body to open the Automatic Document Feeder cover.
To reduce the number of paper jams, smooth and straighten the
paper before scanning and adjust the guides to the paper size.
This should help. Please let me know if it does. Thank you, Binary Bob
Dec 04, 2008 | Xerox DocuMate 252 Path-Through Scanner
ADF Document Jammed
Have you tried manually rotating the ADF wheel back and forth, sometimes the sensors are OK but the rotators lose grip.
Oct 23, 2007 | Brother MFC-8440 All-In-One Laser Printer
Xerox DocuMate 510 Document Scanner Logo
404 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
