Question about Westinghouse Refrigerators
A buzzing noise
I have a Westinghouse Virtuoso side bty side refrigerator that is out of the 5 year wanrrantee and it has been a problem from the very first day.
Now it has started making a loud buzzing noise followed by a click every now and again, surely an ominous warning that something else is about to go wrong. Also when ever it is moved from it's lair I can see a green patch on the floor below where the LHS would be. This would appear to be a chemical reaction from a copper pipe I think.
Len
    Sergeant:
  • 212 Answers
Compressor start device going bad.
Posted on Jun 21, 2009
Our Westinghouse Virtuoso side by side refrigerator with ice-maker Model RS645V*10 will not make any ice. Would changing the water filter fix the problem or is it a bigger concern?
If you are getting water from dispenser, then changing filter wouldn't help. Is ice maker getting water? Is freezer at or near 0F?
Nov 16, 2017 | Westinghouse Refrigerators
Westinghouse virtuoso freezer alarm will not turn off, why?
the alarm on virtuoso/ westinghouses are generally a high temp alarm
meanning the freezer has not reached its set point temp . it could be caused by many problems . i would suggest you get a tech to diagnose it properly .
Oct 03, 2014 | Westinghouse Refrigerators
Westinghouse virtuoso fridge freezer on top has stopped cooling frreezer alarm goes off every now and then. have defrosted freezer as suggested. freezer still not cooling.
you have a piece of electronic installed in the cooling freezer it must be the problem if there is nothing so it will be from the behind side you must change it
Oct 13, 2010 | Westinghouse Refrigerators
Westinghouse virtuoso fridge is noisy after leaving the freezer door open several hours
First analyze from where you are getting the sound.
1)Check the fan at the back side of the freezer.Is it making noise.Remove it and put some oil so it will rotate without sound.Check for the bending and straighten it and see it
doesn't hit on body.
2)compressor motor may vibrating a lot making noise to the condenser coils.It makes the full fridge to vibrate and makes noise.Adhesive stickers will soften them.If still problem persist coil could be damaged.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 06, 2010 | Refrigerators
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My refrigerator buzzes for 5 or so seconds then
the buzzing noise your hearing is possibly your compressor trying to start up. this is generally a buzzing for 5-7 seconds followed usually by a click noise if it goes on for several hours you will notice the temps in the unit starting to rise. for alot of may tags with the tecumseh compressor the compressor had to be replaced. if it has an embraco compressor you can just replace the start relay on the compressor. let me know what you find thanks Peyton
Mar 06, 2009 | Maytag MSD2756G Side by Side Refrigerator
Unbalanced fridge
you need to first remove the bottom kick plate. you will notice two 3/8 bolt heads on each side. These are to raise and lower the rollers in the front and rear of the unit. There are also 2 legs in the front that can screw in. These are usually lowered after the unit is installed to keep it from moving.
Jan 31, 2009 | Refrigerators
Westinghouse Virtuoso Fridge - Circuit Diagram
It won't be the defrost timer, unusual, it will be the defrost element inside the freezer section behind the back panel or a shorted defrost klixon.
Mar 30, 2008 | Refrigerators
Refrigerators Logo
385 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
