Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Picture and audio cut in and out.PWR/STBY button 5 red flashes
The picture and sound cut out after a few seconds and then return after 15 seconds and cut out again after a few seconds. The POWER/STANDBY light flashes 5 times after the TV is shut off. The light is green the whole time the TV is on and eventually the red light stops flashing and stays solid red
    Sergeant:
  • 227 Answers
Look at this link on the bottom to see what the blinks tell you.
http://www.agoraquest.com/viewtopic.php?forum=70&topic=31721
Mike
Posted on Jun 20, 2009
TV cannot turn on
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Action-3: Replace the main board!!!
Mar 25, 2017 | Hitachi Televison & Video
The tv cycles on and off
dry soldering on EHT out put side horizontal SEXCTION
Jan 15, 2010 | Hitachi 55HDS69 55 in. Plasma Television
When turned on green light flashes and no picture
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Dec 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
No picture, audio flickers on and off
THIS IS USUALLY THE MAIN TOTAL ASSY OR THE PANEL IS BAD.
Jan 30, 2009 | Televison & Video
PICTURE ON LCD TV GOING IN AND OUT
it works!! First i took off the front panel. Just check your manual for instructions, very easy to do. If you do not have a manual just down load one from google.. The instruction are easy to follow. The screw they have you loosen with a alan wrench is attached to the plastic, so you do not have to worry about dropping it inside the tv. Removing the lamp was simple. once out you will notice on either side are two small mesh screens. One of mine was 80% blocked with dust, the other side was only 30-40% covered. I used a vacuum to remove the blockage, i did not want the dust and dirt to go inside the bulb. i then cleaned all around the lamp. Reinstalled, and we are go to go. The kids are happy and i am happier since my wife not be buying a new TV.
total cost of repair $.00
time required to fix, less than 15 minutes.
Also when my TV was loosing sound and picture and then return. I did turn off my TV, then turned on. I nothiced a red blinking light. Mine flashed 5 times. After some reserch, 5 times is video related, bulb or video board. google red flashing light with the model you have and you will find what all the codes mean.
So if yours is flashing 5 times try the above, it might work for you and it is well worth the time before you call a tech and drops hundreds of dollars.
hope this helps.
when your tv blanks out, turn off the tv and then it back on. below the power button usually flashes green light. does yours flash red? if so you need to count how many flashes. the number of flashes will help in resolving your problem. then google red flashing light sony and you will find what the red flashing lights mean.
Oct 04, 2008 | Sony KDF-E55A20 55 in. LCD Television
42PF9630A 42
ssb:pnx2015 stby &control
b4e
7j00-5\pnx2015
STBY CPU
1LA0\16MB
X840GA
May 22, 2008 | Philips 42PF9630A 42 in. Plasma Television
My Sony comes on then both sound and picture goes black.
After being on a little while, the screen goes black (no audio as well) for 20 to 30 seconds. Green light stays on. Then, picture comes back on and takes a couple of seconds to get up to full brightness. About 5 seconds or so after the video comes back, the audio returns.
Until this morning, has only happened a couple of times a day, now happening more often. About 3 times in last 20 minutes.
KDF-E55A20 is about 3 years old.
May 03, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
320 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
