Back to:
Tags:
Car Video Players
Generic problem for all Car Video Players
1998 CHEV CORVETTE...I'M INSTALLING JVC KW-AVX800... (by 2 users)
posted by DEE CEE COLE on Nov 03, 2007
JUST NEED THE PROPER WIRING LAYOUT
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Dec 03, 2007
i need help wiring a panasonic cqvd7001u for a 1994 honda accord..
Solution #1
posted on Jul 11, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
let a professional in stall it..
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on 1998 CHEV CORVETTE...I'M INSTALLING JVC KW-AVX800 IN DASH VIDEO DVD CD PLAYER AND 2 AMPS . ONE AMP IS A 2400 MONO D BLOCK BLITZ FOR THE SUBS ...AND A 1200 WATT FOSGATE AMP FOR THE HIGHES AND THE MIDS:
I don't want to Accept this solution
Solution #2
posted on Nov 03, 2007
Not Rated (0)
Benimur
Rank:Guru Guru
Rating: 87%, 2403 votes
For a JVC KW-AVX800 wiring would be:
Black - chassis ground/negative
Yellow - always on B+ (12V + terminal of battery)
Red - Accessory B+ (goes to 12V when ign key is switched to Acc)
Blue - Power/motor of antenna
Blue/White - remote trigger on of external devices such as an amplifier
Orange/White - park light
Brown - mobile phone sensor
Light Green - parking brake
White & White/Black - left front
Gray & Gray/Black - right front
Green & Green/Black - left rear
Purple & Purple/Black - right rear
Hope this be of some help/idea. Post back should you need additional information.
Good luck and kind regards.
Thank You!
Can you Help with these Car Video Players problems?
Insignia Mobile DVD Player with 9.5"...
I just bought a used unit, and need tips/instructions on...
Pioneer AVH-P5700DVD Car DVD Player
Can you advise how to switch My Avh-P5900 between Pal...
Jensen VM9510 Car DVD Player
i have tried connecting the pink wire to a ground and now...
Kenwood KVT-617DVD Car DVD Player
i know that other divices can be upgraded maybe i can...
how i need to turn off the demo mode?
Loading problems.
Repair Service
Find Car Video Player Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
