Question about HP Compaq Presario SR2170NX (RK549AA#ABA) PC Desktop
How do I get the monitor to return when it sleeps?
    Genius:
  • 1,269 Answers
Just press the power button
Posted on Jun 20, 2009
How do i change sleep mode
Sleep Timer Mode
The Sleep Timer mode is an energy-saving feature that enables you to set a time for the monitor to
power on and off at the same time every day. This also extends the life of the backlight bulbs in the
monitor. The Sleep Timer has five settings:
? Set Current Time
? Set Sleep Time
? Set On Time
? Timer: On/Off
? Sleep Now
To set the timer:
1. Press the Menu button on the monitor front panel to display the OSD Menu.
2. Scroll down and highlight Management.
3. Press the OK button to select Management.
4. Scroll down and highlight and select Sleep Timer > Set Current Time.
NOTE: You must set the current local time before you reset the time for Sleep Time or On Time. Note that the time is displayed in a 24-hour clock format. For example, 1:15 p.m. is displayed as 13 hours 15 minutes. A power failure or loss of power to the monitor will cause the timer to reset to 00:00. If this occurs, you will need to reset the sleep timer mode.
5. Press the OK button once to enter the adjustment mode for hours.
6. Press the - (Minus) or + (Plus) button to adjust the hour.
7. Press the OK button again to enter the time for minutes.
8. Press the - (Minus) or + (Plus) button to adjust the minutes.
9. Press the OK button to lock in the time chosen.
10. After setting the current time, the highlight automatically skips to Set Sleep Time. Repeat steps 6 through 9 to set Sleep Time.
11. If you do not want to set Sleep Time, press the OK button twice, then select Save and Return to exit the menu.
12. After setting Sleep Time, the highlight automatically skips to Set On Time. Repeat steps 6 through 9 to set On Time.
13. Set the Timer mode to On to activate the Sleep Timer settings.
14. When you are finished, select Save and Return to exit the menu.
The fifth selection, Sleep Now, turns the monitor backlights off immediately and stays in sleep mode
until the next On Time activates or a monitor button is pressed.
May 27, 2014 | HP Pavilion 22bw Black 21.5" LED Monitor...
Monitor keeps going to sleep
This issue is related to the Video cable. Better check its connection. Unplug/replug it to both computer and the monitor. If this doesn't work, then you need to replace it.
Thank youfor visiting FixYa! We answer yourconcerns promptly for FREE. Please spare a few seconds toclick on YES button in return. Havea good one!
Jul 04, 2011 | HP w1907 LCD Monitor
My HP 2009m goes into sleep mode & shuts down
hmmm is it your monitor going to sleep..or the machine? might the computer still be running?
if it's the computer go to power setting and change to your pref
Feb 15, 2010 | Computers & Internet
Went into sleep mode and will not awake, gives message of not being able ti find vga source, but all connections are good and secure, then returns to sleep mode
Sounds like there could be a short in your video cable. I had this problem occur where i would boot up my pc and after about 5 seconds the screen would go blank. Also give your monitor a reset manually after starting up your box. Just unplug the power cable to it for about 10 secs and see if that helps. Good Luck
Dec 09, 2009 | HP vs17c 17" LCD Monitor
Stuck in sleep mode
When you say stuck in sleep mode if you mean the power light blinks and no picture then the internal power supply has died. This is a very common problem on the Dell E173FP series of monitors. That series has 3 different versions and each requires a different repair procedure. Check our web site at: www.ccl-la.com We have repair guides for many LCD monitors and the E173FPb, E173FPc and E173FPf versions are included. If you don't want to do the repair we do offer a repair service for $30 plus return shipping.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 09, 2009 | Dell E173FP 17" LCD Monitor
Monitor goes to sleep
go to control panel, display properties, screen saver, turn off,
than go to power options, turn off the "turn off display" option.
Jun 06, 2009 | HP Computers & Internet
Monitor went to sleep and won't wake up
It sounds like a driver issue, but more likely the monitor driver, not the video card, since the other monitor works properly.
If you go into the video properties, check the monitor settings. You should be able to switch it to a generic monitor. You also need to make sure that you have the correct monitor refresh frequency set. If you have a mis-match, the video card could send signals at a rate the monitor can;t handle, which is why it won't "wake" even after a reboot and might need to be unplugeed to get it to come back on.
Jan 01, 2009 | HP Pavilion dv6000z Notebook
my monitor comes on for a few seconds and then shows monitor going to sleep and then it does. can you please help me as i really need my computer.
many thanks
barneytina
Aug 11, 2008 | Princeton Digital VL17151 17" Flat Panel...
HP Compaq Presario SR2170NX (RK549AA#ABA) PC Desktop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
