Question about RCA F27242GY 27" TV
No Picture I was watching my TV (I have a cable box hooked up to it) when the picture went out and it made a noise like when I normally turn the TV off. The sound, however, was still going. For about 3 days to a week the picture would go in and out, with no change to the sound. Is there anyway my husband or I can fix this or is my TV dump material? If it can be corrected, is it a costly repair or not? My email is if you could please let me know. Signed, TV Impaired in Virginia.
Re: No Picture
The picture on mine was fading out. Turned out the heater connection on plug A13 had a cold solder joint.
Posted on Sep 07, 2008
  • RCA Master
  • 5,138 Answers
Re: No Picture
Mbrave , Your set has cold solder joints this means you have poor connections on your chassis / resolder around flyback and all poor connections this should fix it,if not then look for leaky capacitor 100uf 160volts.rember solder first! laubaker YOUR TV if at my shop repair cost 85.00 you have 1 or 2 things wrong if only shorted hori out 85.00. you have lost of high voltaged.
Posted on Dec 25, 2007
0 characters
3 Points
No picture, but sound
tried to hooked up with an air antenna. if you can not get any channel and just a white raster or snow, it could be the tuner get fried.
Jul 22, 2012 | Sony KV-32S45 32" TV
Can't get TV picture after hooking up PS 2
How many sets RCA ports (for Video 1 / Video 2 so on and on) does your TV have?
Jul 26, 2008 | Panasonic Standard (CRT) Televisions
I was watching my tv (sanyo) with cable hooked to it. The cable all of a sudden went out. I tried hooking up the dvd player and the tv is no longer recognizing the cable box or dvd player. I don't know...
sound like a tuner problem. there is a resistor that goes to the tuner that could of went bad 39,000 ohms i think which should have a orange white orang strips around it and a gold. anyway there is a problem with tuner. Sanyo was good about haveing a problem with tuners in there smaller sets. If you do not know anything about how to repair you probly shoud take to a shop but the total cost might be high and not worth it in the long run. think before you jump still water runs deep.
Mar 06, 2009 | Sanyo AVM-2506 TV
No Picture
i do know that this unit which i have also if you plug the tv up and turn it on several times it will reset the tape drive and take out all slack on the tape and it will then eject the tape then clean the tape path after you get tape out tv should return to normal but tape unit must be cleaned are the sensor mabe going bad like the end sensor and so forth etc..
Dec 17, 2008 | GE 13GP344 13" TV
DELL 42 inch Plasma TV
I have a 42" LG LCD TV and just experienced this today. Watching cable, then the screen went to black, but audio continued. I pressed the guide button on my remote and pic came on with my guide menu. But then went to black again 10sec later and has remained that way for nearly an hour. Tried switching off both cable box and TV, disconnecting and reconnecting cables, but no luck. Finally unplugged mains, waited a minute, then turned back on. Everything seems normal now after the reboot. Phew.
Jan 17, 2008 | Sony KV-36XBR450 36" TV
Picture turns into looking like a reverse negative
Often you will get a bluish or reddish looking picture if your wires from your cable box/satellite or DVD player are inexpensive RCA type video cables. Try using a nice set of component cables or HDMI cable from your sources to your TV. If this is your setup, try this first...its the most inexpensive first option.
Dec 31, 2007 | Hitachi 36UX59B 36" TV
Female coax connector in tv bad?
If your cable converter box has audio/video connections on the back of it,you don't need to worry about using that RF coax connector. Just hook it up the same way your DVD is hooked to the TV input jack. Get a 3-wire cable (yellow-red-white)hook it to the same colors on the back of the cable box and hook the other end to an unused input on the back of the TV. Then select that input with your remote and watch TV.
Aug 30, 2007 | Sharp 27J-S100 TV
Excessive voltage coming from television
there are 2 probable cause,...flyback transformer leak out and ur power supply goes high- v.not 4 to fix it too risky..both of this cost much..
Feb 24, 2007 | Samsung TXP3275H 32" TV
RCA F27242GY 27" TV Logo
73 people viewed this question
Top RCA Standard (CRT) Televisions Experts
John mullen
Are you a RCA Standard (CRT) Television Expert? Answer questions, earn points and help others
