Question about Ruud UAKA060 Air Conditioner
The unit runs fine for a couple of days then trips. some time it will trip twice a day
  • panilling9
    panilling9 May 11, 2010
    what trips?
    circuit breaker?
    Sergeant:
  • 306 Answers
The compressor may be old or the starting capacitor is weak. Could be bad connection on the AC supply line or pitted contacts on the run relay. Check all AC wiring supply connections even in the house electrical panel for tightness, Replace the starting capacitor first.
If it still has a problem install a hard start capacitor kit. Could even be a bad breaker - breaking out on a lower current draw.
Posted on Jun 21, 2009
SPLIT AC CONDENSER TRIPS AFTER 1 OR 2 MINS, ONLY DURING THE DAY TIME
The condensor is not cooling fast enough. Try cleaning the condensor coil. Also check that the fan goes on. At night the outside temperature is cooler and does not need much work to cool down the condensor.
Jul 15, 2012 | Haier Heating & Cooling
Why does my fridge trip the power on defrost cycle?
have a technician come in and do an insulation test on the unit
the very smallest insulation leak will trip the RCD unit in the breaker
Sep 13, 2017 | Refrigerators
This is a freezer with Danfoss type temp and defrost control, customer complain that unit is tripping braker about once a day , when switching to defrost or from defrost to freeze cycle, controller is...
There is definately a ground fault in this unit. Also according to the service manual this is an "Electronic Defrost Control" similar to an "
Adaptive Defrost Control" which determins the defrost initiation by the amount of run time. You cannot set this yourself.
Dec 08, 2010 | Delfield Freezer 6151XLSR Stainless steel
ON excessively hot days, the outside heat pupmp trips the circuit breaker. Most times it is only once, I turn the breaker to "on" and it works fine. Some days it pops two or three times. When the outside...
Hello I would add a HARD START KIT to the run capasitor (if there is not one already).This makes the compressor come on easy.If the breaker trips during running time the pressures are too high,hose off the condenser coil (fins).The unit might be slightly overcharged but I would be careful before adjusting the freon at all.
Sep 02, 2010 | Carrier 38CKC036 Air Conditioner
Have a package unit that is tripping the circuit breaker early in the morning, around 5 a.m. each day for the past few days. The blower fan motor was recently replaced, but it seems to work fine, all day...
Excessive current draw when motor first starts could and most likely does cause this breaker trip. I would check wiring connections to motor, check cold motor start up amperage draw, also breaker may be the issue (weak bimetal spring).
Jul 19, 2017 | Goodman GPC1342H21A Air Conditioner
Pump was tripping the GFI...now it wont work at all
My pond pump had to be replaced after three years. They said the fine grit out of my fish pond. got into my bearings and cut them out.
Nov 06, 2017 | Savio Water Master Solids Handling Pond...
Unit shuts off on hot days
It may be low on refrigerant. On hotter days, the compressor has to run longer to reach the temperature you have on your thermostat. Have it checked for the proper refrigerant charge and have them test how many amps that the compressor is pulluig as well. With the proper breaker installed, the unit should not be tripping out. Make sure that the breaker that is in there now is actually the proper one for your unit.
Best regrds, --W/D--
Aug 01, 2009 | Dometic Rooftop RV Air Conditioner
Domestic a/c runs fine for hours then trips circuit breaker
Check the difference between your incoming voltages at these times, it may be, if your plugged in to park power, the voltage getting to you may be less due to neighbors using more. If you have a genny, try using it when this happens and see if it trips. More lights, TV's etc are probably being used at night by others.
Jul 30, 2009 | Heating & Cooling
Flame roll out protection device just started tripping a couple of days ago. Can be reset and unit runs for 10-12 hours and device trips again. 14 year old furnace and this just started happening. ...
No, heat exchanger is most likely cracked. Time for a new furnace. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 29, 2008 | Amana Heating & Cooling
Ruud UAKA060 Air Conditioner Logo
80 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
