Atlus GBA Game Shark for Nintendo 64 Logo
Posted on Jun 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why wont perfect work with my gameshark?
I have a v 3.3 gameshark and when i put perfect dark in and turn it on it says the number 8 but when i put goldeneye in it works fine any solutions?
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Aug 31, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1758
Points
6
If the problem is that the gameshark won't boot you'll have to change the keycodes. this question gets all the time.
mra85008
Level 2:
Filmmaker:
Uploaded 5 video answers.
  • Expert 182 Answers
  • Posted on Jul 06, 2009
mra85008
Expert
Level 2:
Filmmaker:
Answers
182
Questions
0
Helped
58026
Points
371
YEA SOME CODES INTERFEAR WITH ONE ANOTHER SO TRY ONE AT A TIME TILL U FIND THE ONE THAT FREEZES UR GS I HAD THE SAMEPROBLEM
Nothing happens except the number 8 shows up but nothing else happens with the gameshark 2.0
http://www.atariage.com/forums/topic/132541-some-help-with-my-new-gameshark-pro-3-3-for-n64/ Check this site... Check the pins in the cartridge and the game shark... Try with different games... Make sure its clean and making all connections. :) hope it helps.
1helpful
I put my gameshark in and the only thing that happens when I turn it on is the little 8 pops up on the gameshark itself and stays there... the tv stays blue...if I take th game shark out and just put my...
Hi, daniel_ray_s
use an Isopropyl alcohol put it on a cotton buds then clean the underside of the cartridge then let it drive for 5 minutes. here's the pic i have put an arrow on it.
Thanks,
Banaple
2answers
GOD GARNED N64 GAMESHARK!
The original GameShark for the N64 only works on certain games. During the N64 era, game creators would often include code on the game itself that prevented the use of a GameShark. It is possible that you can find a newer version of the GameShark that would work with this so called "blocked" games, but it might be difficult.
I'm assuming that this is the GameShark Pro for the N64. If so, the button is used to find and create your own cheats, such as infinite life, infinite ammo, etc...
To use this feature, start the game, say a first person shooter, and load into a level and when you are ready to begin playing, press the button. The GameShark screen will show up and you can say "search for code" or "search for changes" something like that and the game shark will run a diagnostic that it shows on the screen. A number will appear noting the number of lines of code executed since the game loaded. When it is finished, press the button again and it will return you to the game exactly as you left it. If you are trying to get infinite ammo, simply shoot once and press the gameshark button again to search for codes again. When it is finished, the number it shows will be much smaller, since much less lines of code have executed since the last run. Press the gameshark button again to return to the game and continue the process until you have only a few, say 5 or less, or even just one code left on the gameshark diagnostic. This code will be the one that dictates the amount of ammo that you have. By altering this code with the gameshark, you can either start with an extremely high amount of ammo, or have infinite ammo entirely. The key to this strategy is to do as little as possible between code searches so that you can quickly narrow down on the code that you trying to alter. Hope this helps.
My games wont work in the GS
SOME OF THE CHEAT WILL FREZEE GAME WHEN U ACTIVATE THEM WITH OTHERS TRY ONE CHEAT AT A TIME AND THAN TWO AND SO ON TILL U FIND THE CHEAT THAT FREZEZ I HAD THE SAME PROBLEM TRY IT AND HOPE THIS HELPS
8helpful
3answers
My n64 gameshark won't turn on
my gameshark wont work i have sm64 and alot more games i turn it on and it just sits there an says 8
1helpful
3answers
Nintendo 64 Gameshark boots up with 1 game
after you load up 007 you must go to key codes to select your game. Then you turn it off and put that game in. It wont start again if you put the wrong game in so dont screw up. Then you can select cheat codes.
Top Atlus Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you an Atlus Video Game Console and Game Expert? Answer questions, earn points and help others
