Question about Kenmore Dishwashers
Water leaking from the front door - Kenmore Dishwashers
  • 6,784 Answers
HI. your door seal has been compromised. replace this damaged door seal asap.
Posted on Jun 21, 2009
Leaks water from underneath and when load is done , if you spin the drum all you hear is a bunch of water still in there somewhere, can not see water sitting in the drum
Hey mate, thats normal for these machines to have water like sound when you spin the drum. The water leaks either come from the pump, door seal or the tube between the door & heater elements. Either way you need to remove the front panels to be able to see where the leak is.
Two screws at the rear top corners & beneath the soap dish (4) to get top off.
from the inside if i remeber correctly 2 screws to remove the front panels as well as located above door your lock units.
This will allow acess to the front of the machine, remove the door itself if you wish, after the front panels come off you could put it on again (door only) and run the machine so u can see your leaking porblems.
Have fun
Jun 14, 2011 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool fron loader washer leaks at the door
The water should be able to come up to the door level without leaking. Chances are you have build up on the bottom side of the glass on your door. If so take a razor blade and scrape the build up off. Your door will quit leaking.
Aug 12, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE3 water is leaking out the front door
These are notorious for the door boot leaking. Look for any tears, rips, pinholes in the door boot. Also make sure the door is parallel with the machine. Most likely it's the boot. Parts about 100.00. Labor can run from 110-140 depending where you go.
Mar 16, 2009 | Kenmore Elite 45986 Front Load Washer
Door leaks on the floor in front of my dishwasher
1. make sure dishwasher is level front to back and side to side.
2. check the main washer arm (WD22X154) on the bottom side for leaks. If you use heated dry, the heating elements can cause the part of the spray arm directly over it to soften and eventually leak. When water comes out that leak it can spray at the bottom of the door, splashing water inside it and resulting in your leak.
3. if 1 and 2 OK, watch how you load the lower rack. If dishes or a bowl direct water from the lower wash arm to spray against the bottom of the door, especially at the center of the door bottom, the resulting splash inside the door allows water to hit the outer door panel and drip out a one or both corners of the door.
Dec 07, 2008 | GE 24 in. GSD2220Z Built-in Dishwasher
Leaking door
get a thin rubber ring of the same diameter of the door and fix it around tightly then the water wont leak out
Jul 25, 2008 | LG WM-2277HW Front Load Washer
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Leaking....front door won't close
Carefully look at the door gasket to see if any irregularity in seal. Could be problem with door seal; or you could easily change door mechanism thru a spare part shop quoting your model and spare-part No or "door mechanism"
Mar 28, 2007 | Kenmore 43042 Front Load Washer
Dishwashers Logo
78 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
