Question about RCA WHP140 Consumer Headphones
Sound cuts out
I have my headphones hooked up to my computer with the transmitter close by. The sound is clear and good but when the audio volume lowers such as a soft section of music or a silent moment in a movie I get a blast of static. I have minimized this some by jacking into my speakers and turning the volume way up. This works alright for a movie when the audio is continuous, but when I am listening to music, the pause between songs will always trigger this. The audio will not return unless I turn off my desktop speaker and turn it back on. Turning off and on the transmitter base works rarely. I can't find my model number on RCAs website, this worries me.
  • 709 Answers
Hi Sirxon,
My headphones are not RCA, but are wireless like yours. I get this symptom when my batteries get weak. Using a volt meter, you can test the batteries voltage. They need to read at least 1.2 volts each. Check the connection from the base to Headphones. My headphones do not have a physical connection, and if I place them in the base backwards, my headphones do not charge. It may be time to get you some new rechargeable batts. I hope this helps you.
Posted on Nov 03, 2007
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
Headphone jack does not work
The headphone jack on the computer connects to the sound card, a hardware device that controls audio input and output on the PC. The card contains a digital-to-analog converter that converts analog audio into digital signals and visa-versa. The performance of the headphone jack, therefore, depends on how well the sound card functions; if the card doesn't work, then the headphones connected to the PC won't output sound. Reconfiguring the audio settings will often fix problems with audio output on the headphone jack, but if the former fails to resolve the issue, replacing the sound card in its entirety is sometimes the only means of repair.
Click "Start." Enter "sound" into the search box. Select "Sound" from beneath Control Panel. Double-click "Headphones." If no "Headphones" option is available, double-click "Speakers." Click "Properties" on the General tab. Check the Device Status field for errors. Look up the message on Microsoft Support for more assistance, if applicable. Close the window if the Device Status field reads "This Device Is Working Properly." Go to the "Levels" tab. Click the speaker button to unmute the volume if the icon contains a red circle-backslash symbol. Drag the top slider to the right to increase the headphone volume. Go to the "Enhancements" tab. Check "Disable all Sound Effects." Go to Applications, and then clear "Allow Applications to Take Exclusive Control of This Device." Click "OK" to close Headphones Properties or Speakers Properties. Test the audio. If the headphones fail to output sound, unplug the headphones from the computer. Reconnect the headphones to the PC. Headphone jacks are color-coded lime green on most PCs. Look for the headphones symbol if the jacks are not color-coded. Plug the headphones into the line-out port on the back of the computer if the headphone jack on the front of the PC fails to work, or visa-versa. Test the headphones. If headphones still won't emit sound, the sound card most likely requires replacement. b> Replacing the Sound Card b> Shut down the computer. Remove the power cord from the back of the PC. Disconnect the keyboard, mouse, monitor and all other peripheral devices. Loosen the screws found on the back of the case, then slide the cover panel off of the case. Touch the chassis to protect the hardware from electrostatic discharge, or ESD. Set the computer on its side. Locate the sound card found on the opposite of the audio jacks and loosen the screw that secures the card to the computer. If no expansion card is located opposite the jacks, the computer uses an integrated sound card which can't be removed. Remove the new audio card from its protective packaging. Line up the card with an available expansion slot on the motherboard, then push the card down into the slot to install the new audio jacks. Screw the card to the computer case. Reassemble the computer. Turn on the PC. Boot in to Windows and insert the CD that came with the new expansion card. Follow the onscreen instructions to install the sound card software to the computer. Plug the headphones into the new line-out jack. Hope this helps.
Jan 21, 2013 | Acer Aspire Computers & Internet
I have a huge problem with these headphones (the Sennheiser HDR 120)... and my wife bought two of them... They have great sound on the computer, but once the green light turns off on the base? There...
The volume of the sound source (Mac) must be sufficient, otherwise the transmitter automatically turns off. Turn up the volume on the Mac, and turn down the volume on the headphones. There is no way to disable the Automatic On/Off function of the transmitter.
Aug 12, 2011 | Sennheiser RS 120 Consumer Headphones
How do I hook up my blue tooth headphones to my onkyo SR 605
You cannot rig up a blue tooth headphones to this receiver with out a blue tooth transmitter ( the Onkyo does not have one built in ). If you have a transmitter it can be plugged into the headphone out socket of the Onkyo ( in front ), just remember that it will cut out the sound from all your speakers when you insert the headphone jack . The advantage though with this connection is you can control the headphone volume using the Onkyo remote.
Mar 12, 2011 | Onkyo TX-DS656 Receiver
The sound keeps breaking up the green light goes out and there is a terrible hissing sound
I know this is a bit late but i had the same issues with my unit. turns out if you listen with the source volume really low the headphones cant detect sound so they shut off. you fix this by simply adding more volume from the source and then just decrease volume on the actual headphones to obtain desired listening level and say goodbye to this issue.
Jan 17, 2011 | Sennheiser RS 110 Consumer Headphones
Same problem, brand new Dell Vostro, hooked up Polk Audio speakers from former computer and get very, very faint music. Need a solution
if the sound is very faint. you can check the volume properties if it is set to maximize and also check the physical volume control on the actual speaker - also Disconnect Any Headphones That May Be Connected to the Computer - Check for and remove any headphones connected to the computer or speakers to prevent them from muting the external speakers.Click Start, and then click Control Panel.Double-click Sounds and Audio Devices. Click the Sounds tab. You can also try head phone if it is Crystal Clear on headphone then the problem is with the Speaker as Dell might need to replace it. :)
Dec 08, 2010 | Dell A215 Computer Speakers
Standard speakers to the computer , low volume
You are getting low volume because there is no amplifier in those speakers. Computer speaker sets are powered -- there is an amp in one of them them which drives both speakers -- a computer audio output without an amplifier will only satisfactorily drive headphones.
May 11, 2009 | HP Compaq JBL Pro (401508-001) Computer...
Audio from tv is not restored by turning off power on headphones
It sounds as if you are plugging the base into a standard headphone jack located on the Television set.
RCA Headphone jacks (incl mini) automatically stop the sound output to the main speakers on almost every set I have seen.. or home stereo.. etc etc
In other words you can take a standard RCA jack.. with nothing connected to it.. plug it in while the music or sound is coming out the main speaker.. and it will cut off the output to those speakers..
If you set has audio outputs on the back.. preferably Fixed Audio Out .. you will need to connect your base unit to those.. turn your set volume to 0 and adjust the headset volume using the control on the right ear-cup.
If you have variable audio out.. you will need to go into your TV sets setup menu.. turn off the speaker.. and turn up the set until you achieve a signal and decent volume through the headset.
If you are missing these connections.. your current “work around” is your only solution.
Best of luck
Dec 31, 2008 | Sennheiser RS 120 Consumer Headphones
GARMIN NUVI 350
HI Heather,
Make sure you don't have the sound muted. Have you tried plugging in a set of headphones into the headphone jack? If you can hear sound with the headphones, most likely, the internal speakers have failed. If you still can't hear any sound, the audio output stage on the motherboard has failed. In either case, you will need to send the unit back for repair. Be sure to have your serial number handy. Register it online https://my.garmin.com/mygarmin/marketing/register.htm
if you haven't already done so.
Hours:
Monday - Friday
8 a.m. - 7 p.m.
Central time (closed holidays)
1-800-800-1020 (U.S.)
1-866-429-9296 (Canada) or (913) 397-8200
More Info: If you can hear sound through the speakers and don't want to send the unit back for repair, you can buy a FM transmitter at Best Buy - the kind that will allow you to play a portable CD player through your car stereo. Just plug the transmitter's audio input cable into your GPS headphone jack, power the transmitter with your car lighter jack, set the transmitter frequency to a unsued FM channel and tune your car stereo to tha same channel. You should hear your GPS through your FM stereo.
Good Luck,
- Jim
May 15, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin GPS - suddenly has no sound - it just cut out
1. Are you sure the volume setting is all the way up?
2. Are you sure the sound isn't muted?
3. Have you tried a pair of headphones in the headphone jack? If the headphones have sound, your internal speaker is bad. If you don't feel like sending it back for repair, you can purchase a FM transmitter like those used on IPODs and CDplayers and plug into your GPS's headphone jack and play the audio through your car's FM stereo.
4. If you don't hear sound from the headphone jack, most likely the audio output section is defective and you'll need to send it back to Garmin to be repaired.
Please let me know if I can be of further assistance to you.
- Jim
Mar 17, 2008 | Garmin Nuvi 660 GPS Receiver
RCA WHP140 Consumer Headphones Logo
251 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
