Question about Kenmore 3.5 cu. ft. Front Load Electric Washer
Type of detergent in front-loading washers
Is it possible to use powdered detergent in front-loading washers? If so, any special instructions? (Kenmore super capacity 3.5)
  • 530 Answers
Yes make sure the box of detergent says HE on it. and read the directions on the soap box for load size and amount.
Posted on Jun 21, 2009
Should I put powder detergent in the tray or in the drum in my Asko front load washer?
But the powder in the tray. I have a asko washer myself
You should to able to go on line and download your manual
Go to Asko.com Good Luck
Feb 12, 2013 | Asko W6461 Front Load Washer
I have an ariston awd 121 front loader washer dryer. What kind of soap does it call for? Can it be the powder? Does it have to be liquid? Does it have to be a certain brand/type?
To my knowledge all front loading washers require low sudsing high efficiency (he) detergent and these only come in liquid. A powdered detergent could probably be used, but I'd try a 1/4 of the recommended amount for a normal load first. Also it is not recommended. Regular liquid detergent can also probably be used but i'd start with 1/2 the the amount for a normal load. If you don't use the recommended "he detergents" expect occasional oversudsing problems and possibly even early drain pump death. Hope this helps.
Here is the owner's manual for your machine:
http://www.managemylife.com/mmh/owner_manuals/25710/ARISTON-Laundry-Centers-L0520687
Jan 12, 2013 | Ariston Technologies Ariston AWD12 Front...
Does kenmore recommend liquid or powdered detergent for front load machine
liquid is best as powder is mostly made of a "clay base" in its detergents??? yes i did say clay!
Nov 28, 2010 | Kenmore Elite 45986 Front Load Washer
Where to put the powder detergent in the washer? how come did not dissolved?
Chances are that the washer is a front load. If it is it requires liquid detergent. If you want to use powder put it in with the clothes and not in the top detergent well.
Hope that clears things up.
ash
Vote please.
Sep 22, 2010 | GE WSXH208A Front Load Washer
DETERGENT
You MUST use "HE" (High Efficiency-Low Suds) type detergent--but to use the correct amount. Nearly all brands of "HE" detergent have incorrect instructions. The correct amount is as follows:
HE: (2) Tablespoons Per Wash load
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
This reduces/prevents:
1) Musty Odor
2) "LE" Error/Interrupted Cycle
3) L-O-N-G Cycle Times (longer than time displayed)
4) Insufficient Cleaning Results
5) Small Water Leaks from the air vent behind the washer or at the
front door gasket
6) Damaged Sensors
7) Reduced Spin Speeds (laundry not spin-dried effectively)
These washers MUST have the right amount of the right stuff or they simply will give you lots of grief. The program can sense suds. It cannot pronounce your wash clean if it thinks their are suds. So it try's to fix the problem and ends up overworking itself.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Do I put powder detergent in the same place I put Liquid detergent?
Detergent compartment
Add liquid or powdered detergent to this compartment for your
wash cycle. The detergent separator must always be in place,
either in the front or back position.
 Do not fill beyond the “MAX” level.
 Liquid or powdered color-safe bleach may be added to the
Main Wash compartment along with the same type of
detergent, liquid or powdered.
 Liquid detergent: Put the SEPARATOR in the front position,
between the guides, as shown as shown by Position 1 below.
There will be no gap between the bottom of the wash cycle detergent
compartment and the bottom of the separator.
Powdered detergent:
Put the SEPARATOR in the back
position, behind the guides as shown by Position 1 below. There will be
a gap between the bottom of the wash cycle detergent
NOTE: The separator will be in the POWDER (back) position
when shipped from the factory.
Nov 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Is powder or liqued detergent better for front
They are trying to make money off you!!!!!!! LIQUID!!!! Dont ever!!! use powder soap in your front loader. Powder soap doesnt dissolve all the way and then gets into the bearings of the washer and eats them away! This caused about a 450 dollar repair for your repairman. Never use powder soap.
Feb 19, 2009 | Frigidaire ATF6000ES Front Load Washer
How to add liquid detergent and powder booster at the same time?
any booster would go in the detergent dispenser,should not be a problem if you are doing warm washes.if you do alot of cold washes,check for build up and clean from time to time.
Sep 28, 2008 | Frigidaire Affinity ATF7000E Front Load...
Type of detergent
You can use either but it must be "HE" or high efficiency soap for front loaders. It will be marked with an HE symbol on the container.
May 13, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Powder vs. liquid laundry detergent
I was searching the net looking for the same answer - have just bought an LG front loader but wasn't certain I should be using liquid detergent - my manual refers to powder without telling you specifically to use it only. Look at the answers to the question after yours on the Fixya website "LG washer has awful mildew odour" or something similar. Solution 3 by Tresilla convinced me I should use powder! Also, the salesman who sold me the machine recommended powder because, quote, " gentler on clothes and more efficient ..." - he didn't mention the possibility of a later mildew odour which is apparently generic to front loaders!
Feb 08, 2008 | Washing Machines
Washing Machines Logo
214 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
