SOURCE: Fuse box, Suzuki Boulevard C50 2005
Should be behind one of your sidecovers. I f you did'nt get a manual w/yor bike then order one from your dealer. It's an invaluable tool....Good luck to you friend....Tim
SOURCE: 2005 Suzuki boulevard c50 won't start, starter
I'm thinking it's either the ignition switch or a fuse.
Try replacing the fuses first...it's easier.
If it's not the fuses feel free to post again and we'll work on the switch,or try alternate ideas.
SOURCE: One day tried to start 1996 suzuki katana,turned
I would be checking main fuse not much more it can be
SOURCE: My 2005 Suzuki Boulevard C-90 doesn't start and is
According to the owners manual an F1 reading indicates a problem in the fuel injection system. The owners manual states that you should take it to the dealer to have it checked out.
The Clymers manual says that there is a certain "mode select switch" you need to recover the trouble code for what the problem is. That part # is 09930-82710. It hooks into a harness plug just behind the steering head covers.
Without knowing what that code is I can't tell you what is wrong with your bike.
SOURCE: How do I remove the seat on a 05 Suzuki Boulevard
remove the two 4mm alen head bolts form the side, theses have lock tight so uses a small hammer to tap while you put preasure on them. a trusted buddy to tap with the hammer. then remove the two forward covers to be able to remove the forward two. and lift the seat from the rear.
