Question about Carrier 38CKC036 Air Conditioner
Turned air on but outside unit will not come on at all
Turned thermostat on air little air blowing out but not cold.
  • 148 Answers
When you say a little air could the filter be plugged up or the coil iced up is the outside unit running
Posted on Jun 21, 2009
  • Jason vangel Jun 21, 2009
    when you say a little air could the filter be plugged up or the coil iced up is the outside unit running
I have a haier air conditioner 5000 n it not blowing cold air its not cooling my house
check thermostat turn off system wait 3 to 5 minutes turn on to cool and turn thermostat to coolest setting if no compressor test thermostat and compressor check filter if dirty and coil iced turn off and lit defrost and change filter if coil warm and unit running compressor internal damage or low freon
Jul 28, 2016 | Haier Heating & Cooling
Fan on unit comes on but no cold air comes from the registers
is the outside compressor running or just the condensor fan.
Jun 18, 2014 | Goodman Heating & Cooling
Honeywell thermostats keep turning off and on and blowing cold air
Need to know the type of heat you have. If it is an air to air heat pump, with this cold weather, you are not going to get much heat out of it. It will feel cool (a little higher than room temperature). If the temps outside stay below 25 degrees, then switch it to Auxillary (Emergency ) heat.
Nov 25, 2013 | Heating & Cooling
Lennox 10HPB36-10P is blowing luke warm air.
What coil is getting cold? In cooling the evaporator coil should be getting cold not the outdoor condensing coil. Verify you have the tstat setup for heat pump, verify you have a proper refrigerant charge.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 19, 2017 | Heating & Cooling
My AC unit stopped blowing cold air. Everything is on and running including the outside unit. I tried to turn off the thermostat, but it will not turn off. The read out shows a fan blowing with the word...
You can remove the face from the thermostat and see if that stops it. If it does the problem is in your thermostat. If it doesn't then a contactor or relay is stuck. Let me know what you find and I will offer more suggestions.
Sep 25, 2010 | Ruud Heating & Cooling
AC unit outside blowing out cold air, vents
Sounds like compressor not running. may be a bad capacitor, could also be low on freon.
Aug 30, 2009 | Goodman CLJ30AR32 Air Conditioner
Uotside unit blowing cool air but hot on the inside
It sounds like you have a unit called a heat pump. When a heat pump unit is in cooling mode the outside unit blows hot air and the inside unit blows cold air. If the outside unit is blowing cold then the indoor unit is most likely blowing room temperature or warm air. It sounds like the thermostat could be controlling incorrectly or you could have a failed reversing valve which is the device that switches the unit from heating to cooling mode.
May 31, 2009 | Ruud UBHC Air Conditioner
My ducted heating continually blows cold air thru
Well, if need be, turn the breaker off. Turn it on when you need heat. Sounds like the fan relay is sticking or something if that sort. Is the tstat fan selector on auto?
Jun 17, 2017 | Heating & Cooling
No cold air
First unplug and remove front cover, straight wire the thermostat wires together and if it works replace thermostat. If not get back with me. Sea Breeze
Apr 24, 2009 | Heating & Cooling
Cooling problem
Since it is not so hot outside you may have to adjust the Thermostat to a lower setting to get the AC unit to kick on the compressor and blow out cold air. Give it a try, and if not the T-stat then we can go from there.
Jul 14, 2008 | Office Equipment & Supplies
Carrier 38CKC036 Air Conditioner Logo
201 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
