My amana washer won't spin - Washing Machines
    Sergeant:
    Champion:
  • 266 Answers
Check ur belt?
Posted on Jun 21, 2009
Amana NTW475OYQ1no lights or sounds. Verified power @circuit board. Someone closed lid on a shirt earlier that preventing lid to I open.verified switch waz working and the wife did a load of laundry.
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following ... Speed Queen, Amana Whirlpool ..... Lid lock lightflases; no spin cycle.
Amana Washing Machine NTW5400TQ1 Troubleshooting ...
www.repairclinic.com/.../Washing-Machine...-/Amana-Washing-Machin...
Amana Washing Machine NTW5400TQ1 Troubleshooting & Repair Help. Amana Washing Machine problems. Washer won't spin · Washer is making loud noise ...
Jan 16, 2016 | Amana Washing Machines
Filled with water. Took towels out - would not spin. Unplugged it. Now it tries to drain but stops and lid unlocks.
Amana , Whirlpool Washer Repair - Not spinning or draining ...
? 1:50
www.youtube.com/watch?v=q7ey58YZrm8
Jul 2, 2013 - Uploaded by ApplianceVideo.com Repair your own Amana Washer with these following issues: Not ... How to Fix a Washing Machine That Does Not Spin (Fast and Easy) ...
Sep 17, 2015 | Amana Washing Machines
Ntw4501xq0 washer won't spin
You have a bad lid switch and it will need to be replaced. Here is the part to order. Below is a video to show you how to replace the switch.
Jan 21, 2013 | Amana NTW4501XQ
Amana nav5805aww washing machine won't spin
You will need to replace the thrust bearing kit. Here is the part to order.
It comes with the instructions and is an easy fix.
Oct 30, 2012 | Amana NAV5805A Top Load Washer
Washer won't spin. smelled burnt.
What is the model number of your unit?
Oct 30, 2012 | Amana Washing Machines
Amana NFW 7200 TW door won't close because lock is engaged
You door lock is bad and needs to be changed. Without the proper model number I can't really give you accurate instructions
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 22, 2012 | Amana NFW7300WW Washer
Amana front load washer error code "nd". Door is
Hello there and welcome to fixya
From what you're describing it sounds like the drain pump is blocked. The nd error code indicates "no drain". If the unit can't drain it won't spin. You're going to have to slide the washer out far enough to remove the rear panel; be careful not to damage the floor. Once you get the rear panel off you will see the pump. Be sure to have plenty of towels & a small container to catch water. I am sending you instructions from the service manual to remove and replace the pump. Another possibility is the drain line is blocked or something is stuck in the tub to pump hose.
Nov 05, 2011 | Amana Washing Machines
Washer fills, agitates, won't spin. Makes buzzing noise. Amana LWA50AW
Most likely it could be the forward belt . When the machine is under load you hear a winding noise it sounds like the pulley belt tensioner. One other thing to check the rinse and hold button is activated as in the past accidentally people have switched it off.
Jul 26, 2011 | Amana 3.2 cu. ft. Top-Load Washer
Amana washing machine makes loud noice when trying to spin
sounds like you are dealing with the same problem as me .
take off the front panel (after unplugging power) take a flash lite and look at the large pulley at the back just below the pulley is the helix check to see if they are worn .
http://fixitnow.com/wp/2008/10/21/amana-washer-makes-loud-ratcheting-noise-during-spin-but-doesnt-actually-spin/
Feb 26, 2010 | Amana NAV3330AW Top Load Washer
AMANA WASHER WON'T SPIN. HOW DO I REPLACE THE BELT?
is this a whirlpool built amana? if so, its most likely a direct drive model, and when it doesn`t spin its likely a coupling between the gearcase and motor assembly...youtube has videos on how its replaced, which isn`t too complicated to do...good luck
Apr 30, 2009 | Amana ALW480DA Top Load Washer
Washing Machines Logo
219 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
