T8011 HONEYWELL THERMOSTAT TURNS OFF & ON
SCREEN GOES BLANK AND AIR SHUTS OFF AFTER A FEW MINUTES IT CYCLES BACK ON FOR A SHORT TIME
    Sergeant:
  • 340 Answers
Battier dead replace or their is a control wire problem check for loose connections. Tom
Posted on Jun 21, 2009
Thermostat is not coming on we are in san antonio is there help out there for us
Reasons for a Blank Screen on a Honeywell Thermostat ...
homeguides.sfgate.com > ... > Real Estate Rental & Lease Basics
Honeywell and other brands of programmable thermostats typically show a blank ...and the batteries can no longer provide power to the screen, it will go blank. ...electrical system, a blank screen indicates there is no power going to the unit, ...
programmable thermostat troubleshoot - YouTube
? 3:35
https://www.youtube.com/watch?v=pNVTAUcBx-U
Sep 26, 2011 - Uploaded by Maxxmentum
Programmable thermostat started to fail and behave erratically after being in service for a few ... My thermostat works but the remotes have stopped working. .... Honeywell CM907 Digital Programmable Room Thermostat user ...
HEAT WON'T TURN ON How Test if your Thermostat is ...
? 2:36
https://www.youtube.com/watch?v=lSJn69EAcAw
Nov 16, 2014 - Uploaded by You can Fix It!!!!
Heater fails to turn on it does not mean you have a faulty heating system ... 4th - Check programming on a programmable
Jan 10, 2016 | Honeywell Programmable Thermostat Heater
I have a Honeywell programmable thermostat and I have central heat and air system. When I set the heat to a temperature above the inside temperature, the heater turns on for a short period of time and then...
I would say that the problem is in the furnace, not the thermostat. The Thermocouple or other temp sensor needs replacing, the sensor that tells the furnace that it is heating. It just keeps turning off and trying again in 3 minutes cycles.
Jan 01, 2015 | Heating & Cooling
Honeywell Chronotherm iv Plus power cuts on and off
There's a trouble shooting guide here, you need to check for the presence of 24V when it goes blank, and trace back to where it's disappearing (I assume it is losing the 24v, if not you'll need to go through the installer setup or read on...
My first thought would be to check the wiring which has been touched last if it started doing that after you had coil replaced.
As an aside I'm not sure which model you have but if it has batteries you should replace them (I don't think it does have batteries but not seen a model iv so I'm unsure)
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1410.pdf
May 12, 2014 | Honeywell Programmable Thermostat Heater
Electric furnace/air handler short cycles
check that the replaced thermostat is the same temp degree setting of the last one
Dec 16, 2013 | Goodman Heating & Cooling
Honeywell thermostat blank screen on cool
I wonder if they shorted a wire a during install. That is where I would begin.
May 14, 2013 | Honeywell Rth2310b 5-2 Day Programmable...
Honeywell thermostat short and then went blank by mistake i short the thermostat with a wire and then became blank
Check the transformer in the air conditioner/heater. There should be a fuse on teh 24 volt side. Shut power off to the furnace. Locate and check the fuse. If there is no fuse, you probably destroyed the transformer.
Jul 17, 2010 | Honeywell Programmable Thermostat Heater
Honeywell thermostat t8400c intermittent blank screen
It actually sounds like the batteries are going dead if the 24v from the furnace are not providing the power to the thermostat.
Sep 28, 2009 | Honeywell Electronic Programmable...
T8411r1028 honeywell thermostat blank screen where would fuse be?
That thermostat should get power from 24V side of a transformer in the air handler. There should be a fuse in there on the PCB, but just as likely, there may be a 2-wire sensor in your drain trap that will shut it down if it senses water backing up in the drain piping. Clear that line from the outside of your house with a shop vac, cycle the breaker for the air handler if needed. You may also be low on freon, though, so a service call might be a good idea anyway.
Jun 01, 2009 | Honeywell Programmable Thermostat Heater
Honeywell HZ7040 shuts off after few minutes
This sounds like a theromostat problem. If you're NOT still under warranty you should at least open the heater and look for the theromostat. A lot of times you can buy replacement at a local electronic or hardware store and they're easy to replace. Good luck!
Dec 02, 2005 | Honeywell HZ7040 Compact Heater
Heating & Cooling Logo
201 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
