Question about Dryers
I need to replace the belt on a Kennmore 70 series gas dryer. It is 10+ years old. The tumbler isn't turning.
  • erica graber May 11, 2010
    is your lint screen on top of the lid or inside of the door?
    Sergeant:
    Champion:
  • 266 Answers
Open the back and ur belt should be in bplane site us a flat head screw driver to remove and replace
Posted on Jun 21, 2009
Kenmore 11062612101
From your description, the dryer belt could be in need of replacement. The burning smell could come from the motor pulley spinning and trying get a grip to turn the drum.
Dec 20, 2013 | Kenmore series 70 80 90 Dryer Motor...
I smell gas when my gas dryer is not on and the pilot light is not lit prior to turning on; it is a 1997 series 70 kennmore
There is a leak in the gas line supplying the dryer. This is DANGEROUS and should be repaired.
S for the pilot light, is it continuously on or is there an igniter that only heats up when you start a dryer cycle?
Sep 22, 2012 | Dryers
Kennmore dryer, series 70, motor runs but drum will not turn. Probably a belt. How do I get to the belt?
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Jun 15, 2011 | Kenmore Dryers
I have a Kenmore 70 series. About 10 years old. The inside light comes one, the timer ticks when turned but nothing happens when I push the start button. We have already checked the breaker. Is there...
you either have a blown thermostat, blown thermal fuse, or a bad heating element most likely a blown thermostat
email me if you need more help in replacing or testing
Nov 16, 2010 | Kenmore 73952 Gas Dryer
Dryer runs then stops.
IF LESS THAN 10-YEARS OLD/CHECK THE TUMBLER BELT AND BAND.IF 10-YEARS+ REPLACE YOUR MOTOR OR BUY A NEW DRYER.***ALSO UNPLUG THE DRYER AND MAKE SURE ALL YOUR WIRES ARE TIGHT.
Jan 17, 2009 | Kenmore 74602 Gas Dryer
Put belt on dryerg
While I don't know about your specific dryer, most dryers are set up the same. I just replaced the belt on my Maytag LDE8404ACE. It was easy. The hard part was cleaning out 14 years worth of lint and fuzz that coated everything inside. Here's the instructions:
1. Unplug the dryer or disconnect power.
2. Remove the front panel. There are two screws, each is about 4 inches up from the bottom of the front panel. Unscrew them. Then hold the front panel along the bottom edge and pull it away from the dryer. Once it's away enough, the clamps along the top will pop and disengage from the dryer. Be sure to note the wires connected to the door switch are connected to the dryer. Disconnect them if you need to move the panel away from the dryer.
3. With the front panel off, you should be able to reach inside the dryer to remove the old, broken belt.
4. Remove the tumbler from the dryer. It's held in place by the tumbler front which is secured by 4 screws, 2 on each side. That piece will pull straight out toward you. With the tumbler front out of the way, the tumbler itself will come straight out as well. I recommend taking it out and cleaning the inside of your dryer while it's open. A vacuum hose works great. Also, check the pulley and the back two wheels that the tumbler rests on to make sure they turn easily. If not, you may want to grease them. Also, it's normal for the idler pulley to appear to be loose and wiggle in place. Once a new belt is installed, it's under tension from the spring so any play that exists shouldn't be a problem.
5. put the new belt around the tumbler with the smooth side of the belt against the tumbler. Use the old belt marks on the tumbler to align the new belt. It's easier to hook the belt to the idler pulley and motor pulley from the back. So we'll get to that part in a minute. Just let the belt hang loose for now.
6. Reinstall the tumbler front and secure with the 4 screws you removed earlier.
7. Reconnect the wires to the door switch, if you removed them earlier.
8. Reinstall the front panel, reversing the steps you took to remove it in #2 above.
9. Go to the back of the dryer and remove the access panel along the bottom right hand side.
10. From there, reach in pull the dryer belt around the idler pulley. Then take the belt on the left side of the pulley and move both the belt and the idler pulley to the right, until you can get the grooved side of the belt onto the motor pulley. I've attached a diagram with instructions.
11. Once connected, manually turn the tumbler so that the belt will align and make sure the tumbler turns as easily as it did when you first removed it.
12. If the belt looks good and you've manually turned the tumbler at least one full revolution (to ensure the belt didn't get twisted), then plug the dryer in and turn it on to make sure it works correctly. If so, then re-attach the access panel on the back of the dryer. You're done!
Nov 16, 2008 | Whirlpool LER5636P Electric Dryer
Kenmore gas dryer after 5 to 10 min. later no more heat
My Kenmore 80 series (model 11072802100) has the same problem that it fires up first and then stop producing heat after a few minutes. It's also 7 years old. After a while, if I restart it, it will run and do the same thing. I found a thread of discussion on another forum that says that this can be the gas valve coil (solenoids) problem as these coils turn on and off the gas flow to the chamber. I'm going to check out the coils, but don't know where they are located (can't find the manual). If anyone has any idea, please share. Or I'll just tear off the top and back to see where they are.
Any gurus here to help? Thanks.
Oct 10, 2008 | Kenmore 72802 Gas Dryer
Drum problem
Aug 28, 2008 | Kenmore 73952 Gas Dryer
Broken belt that turns the drum
12. If the belt looks good and you've manually turned the tumbler at least one full revolution (to ensure the belt didn't get twisted), then plug the dryer in and turn it on to make sure it works correctly. If so, then re-attach the access panel on the back of the dryer. You're done!0798e0b.jpg
Aug 17, 2008 | Maytag PYG2300A Gas Dryer
Dryers Logo
62 people viewed this question
Top Dryers Experts
Marvin
Marvin
