Question about Sony STR-DE445 Receiver
Cant get sony sub woofer model no. ss-wg60 working on my sony receiver model no. str-de445
  • 1 more comment
  • jose ortiz Jun 21, 2009
    Did not work going into set up, sub is "on", actually it says "yes", and the maximum "0". Still not getting anything.
    My sub has no power cord that goes to the wall, it has no on or off switch, and didnt have RAC cable. My sub woofer was working when it just had the bare wires, had connected it to the regular speakers. Bought RCA wire and now nothing.
  • jose ortiz Jun 22, 2009
    Thats why. Too bad I dont get the power I should when I have it directly from the speaker wires. Thanks.
    President:
  • Sony Master
  • 1,114 Answers
First, go into the "setup" mode of the receiver and go to speaker select, then toggle to sub, highlight and make sure it's "on" Then toggle to speaker volume and check the sub level. Maximum setting is "0". Make sure you are connected to the subwoofer output on the receiver as well. If you still have a problem, post a comment and I can help you some more.Hope this helps
Posted on Jun 21, 2009
  • Frank Fulton
    Frank Fulton Jun 21, 2009
    Disconnect the sub RCA or digital then put your finger over the tip, does the sub humm loudly? if so that's good, if not, look at the back of the sub for a switch that say's "auto""off""on" switch it to on and make sure power light is on. Touch the sub cable again, if it still does not make any noise, the problem is in your sub not your receiver. If it does humm, set your receiver to "A.F.D" surround mode and test again. Beyond that, you will need to get it to a service center. Hope this does the trick!
  • Frank Fulton
    Your sub is passive. it has no amplifier, it's getting it's power from the receivers speaker output and crossing the signal over internally to produce sub bass. Your receivers sub output is just signal not power, it's meant to be used for an amplified subwoofer. The way you had it hooked up prior to this is the way it is supposed to be. Direct from speaker wires.
I have a sony str de 325 receiver....what sub woofer will go with it and where do you plug it into the receiver?? Thanks
You will need a powered sub, one that has a built in amp. It will also need speaker terminal type inputs. Use the B channel to send signal to the woofer. Since the audio from the B channel is full range, use the crossover on the sub to determine which frequencies you want to hear. I would start at 100Hz and go up and down from there. Use the gain to adjust the volume in relation to the other speakers. The sub volume will be affected by the master volume.
Please rate if this helpful
Apr 05, 2011 | Sony STR-DE325 Receiver
I bought a sony receiver,but i can't connect the sub from JBL on to it?
If the model ??? JBL sub is self-powered like most just run an RCA cable from Sub Woofer Audio Out to it and select YES for Subwoofer in the setup menu.
Jun 08, 2010 | Sony STR-DE445 Receiver
Connecting a Sony Subwoofer SA-W2500 to a STR DE 598
It is based on your sub-woofer type..whether powered or passive sub woofer..
Assume that you have powered one..RCA sub woofer jack is the best to feed it ..you should use RCA sub woofer output on your receiver as well..good luck
Jan 08, 2010 | Sony STR-DE598 Receiver
NO SOUND FROM REAR OR CENTER SPEAKERS.JUST THE FRONTS AND SUB WOOFER WORK.
have you checked the wiring of the speaker some time the can cut internally so to check use a small wire and connect just like the one which is in the manual this Can solve the problem
Nov 19, 2009 | Sony STR-DE445 Receiver
Trying to use a passive subwoofer with STR-DE445
The output of the Sony is "signal only" not power. Being "passive" like your sub. What you need is a sub amp, and they are not cheap, 400-600 on average "min". Unless you have a Velodyne 15 or 18, just get an amplified sub, they start around 150 new. Hope this helps
Mar 27, 2009 | Sony STR-DE445 Receiver
Receiver str de 445
Hi - You can download the manual from the link underlined in blue below:
STR-DE445
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 28, 2008 | Sony STR-DE445 Receiver
Sony STR-DE445 protect displayed
It sounds like a bad solder connection. It just needs to be soldered up, if you take it into a shop just tell them it doesn't need any new parts, it just needs to be soldered up.
Or, if you can solder it yourself, or know someone that can, that would be much easier.
Aug 04, 2008 | Sony STR-DE445 Receiver
RCA Sub-Woofer
Did you try making sure the subwoofer is turned on under the set up menu on the Sony Receiver?
Press Set Up, Press the left or right button above the scroll wheel until you get to SW. It should say SW: ON or SW: OFF. If it says SW: OFF, use the Scroll wheel to scroll right until it says SW: ON. Also, make sure you aren't in 2CH mode, try A.F.D or surround sound.
Jul 26, 2008 | Sony STR-DE445 Receiver
SONY STR-DG510 Sub woofer does not work
You will need a powered sub because your receiver does not amplify in the sub output.
Jan 21, 2008 | JVC RX-554V Receiver
Sony STR-DE445 Receiver Logo
305 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
