My creative Zen Touch Is not recognized by my computer when I plug it in. I use windows vista at home and have already updated the firmware to ver.2.11.01 what can I do?
Thank you for your question.
To allow Vista to work with the Zen Touch, you will first need to download and install this specific version of MediaSource. Click here to download it.
After installing the above, connect your Zen Touch to the computer. After connecting the device, you will now need to download and install this specific version of the PlaysForSure software. Download it here and install it.
The software above will change the firmware on your device again, and will erase all songs! Even if it asks for a backup, the backup will fail on Vista, and if you want to keep all the songs, make the backup on XP first!
The Zen should work in Vista now. If you made the backup of songs on XP, you'll have to put them on the player one-by-one. In most cases, they will not be importable all in one go.
Best regards
nLinked
Posted on Jun 20, 2009
Firmware update went wrong
What operating system are you using? The Zen Touch firmware update will fail in Vista or 7 -- you need to run the update from an XP install. Once you successfully get the 2.11 firmware on the Touch, it will then interface with those later OS's without difficulty. Also, what version of Windows Media Player are you running? Believe it or not, this makes a BIG difference. The latest Media Player 11 will cause the firmware flash to fail, as will WMP <= 9. I have three separate players that have experienced this problem, including one that had been disassembled THREE YEARS AGO after a failed flash, and was able to resurrect all utilizing this method:
(1) Uninstall everything Creative: the driver, Jukebox, etc. Delete the Creative folder from Program Files. (Some amendment to these instructions may be in order if you have a Creative sound card -- I have built-in Realtek sound so it didn't apply in my case). A restart may or may not be required: go ahead and do so to be safe.
(2) Plug the device in after restart. Windows will want to find drivers for it -- cancel that process. Open the Device Manager. The Touch should come up with an exclamation point next to it (since the drivers were not uninstalled): right-click and select "Uninstall." I have seen instructions on the Web to also uninstall all USB root hubs, but I have found that unnecessary and a pain if you have a USB keyboard and/or mouse. Unplug the device. Restart.
(2) If you are running a version of Windows Media Player not equal to 10, either install 10 (if you have 9 or below) or roll back from 11 if you have that. Restart.
(3) Plug the device back in. My supposition is that this is particular to WMP 10, hence the problems with other versions. The device should pop up as "Creative Zen Touch:" if Windows asks to find drivers, cancel that process, and the device should now come up as an "MTP device."
(4) Since the firmware flash failed, the Zen is probably in recovery mode. Launch the firmware updater software on the computer, and stay at the language selection screen. Choose option 3, "reload firmware," from the recovery menu. It will inform you that it is "deleting old firmware" and then will give you a short period of time with a dialog saying "start firmware update" on the Zen screen. During this time period (about 2 secs), press the language selection of your choice on the computer in order to start the update. It should go through successfully this time.
Jun 07, 2009 | Creative Labs Zen Touch MP3 Player
Upgrade firmware problem zen touch 20 gB
I contacted Creative about a similar problem with mine when I went onto Vista and they advised that I had to update the firmware. The downside they stated was that I would probably lose all my songs. The only way round this is to save them all to a non vista computer and then upgrade and hope you can put them back onto your player. Here is the info they sent me. Not sure if it works as I never got round to it.
I understand that you cannot get the software to work in your Windows
Vista.
With regards to your enquiry, there are two things that you need to
consider, player and the software.
For a proper set up, you should update the player with an MTP Firmware
version using a PC with Windows XP installed.
What is the MTP Firmware?
http://uk.europe.creative.com/support/kb/article.asp?l=3&sid=6773
Ensure that computer has both Service Pack 2 and Windows Media Player
10.
a. Verify SP version, click+Start+Run+type Winver.
Next, update the driver first, once it has been installed, connect the
player then click the MTP firmware program.
Proceed to this link and download the following files needed.
http://uk.europe.creative.com/support/downloads/
just click on the link above then type the filename of the
driver version : JB3MV2_PCWDRV_US_2_01_00.EXE
firmware version : ZenTouchP4S_PCFW_LB_2_11_01.exe
at the search box provided.
download and save them to your folder. Click the program and follow
further instructions during the installation.
For instruction on updating the firmware, please use the link below and
select ZENTouch
http://uk.europe.creative.com/support/kb/article.asp?l=3&sid=4789
As for the software, you maybe required to download and install the
following updates below:
Please view important notes written at the website for further
information.
Proceed to this link http://uk.europe.creative.com/support/downloads/
then type the filenames: CMS5_PCAPP_LB_5_10_38.exe
CMS5_MTP_PCAPP_LB_5_00_36.exe
at the search box provided. Ensure device is attached before you start
the installation.
Sorry it's so long winded and I hope it works.
Andy
Jan 02, 2009 | Creative Labs Zen Touch MP3 Player
Zen micro firmware problem
I just got a ZEN Micro 4GB player for free due to Firmware problem. This totally fixed the firmware issue. Windows XP PC with Media Player 10 and the latest driver and firmware from creative. Once I had all that I plugged in my player, let it recognize and then re-flashed to latest firmware. BAM now the play is working perfectly and I can sync music to it. Thanks for the fix.
Jun 25, 2008 | Creative Labs Zen Micro MP3 Player
HElp!!!!
After three months of trying and trying in many computers, following many, many procedures found all over the Internet, my Creative Nomad has accepted the firmware and has borned again.
What I did?
1. Connected the Nomad on a computer with Windows XP and Windows Media Player 9, that never has been touched by a creaive device.
It recognizes the device but can´t find any update to the drivers,
2. Updated Windows Media Player 9 to Windows Media Player 10,
3. Restart the computer
4. Connect the Nomad and the computer recognizes the device and autamtically search and found updated MPT drivers.
5. Run the firmware update program "ZenXtraP4SAudible_PCFW_LB_2_10_03 (Creative Zen Xtra PlaysForSure Firmware 2.10.03)"
6. Finally the magic button always has been disabled was enabled so start reloading firmware.
And now the Nomad is working in windows vista.
The difference between the computer where the firmware works and the others is that this has never had media player 10 or 11 and never has installed creative drivers.
Hope this can be useful to smoeone, somewhere, sometime.....
May 12, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Creative zen
What I did?
Apr 26, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Creative Zen Touch firmware problem
Before preceding, goto control panel, add/remove programs (vista equivalent) select windows media player and uninstall note the response it gives you. If it is going to allow you to uninstall OR downgrade windows media player to version 9 then keep going. If not, then find another computer that you've never used the player on try upgrading firmware there, make SURE it's got windows media player 9 by downgrading it in add/remove programs.
Now for the fun stuff:
Sounds like the same problem I've resolved several times in the past on here.
1. Plug in the device.
2. Goto device manager in control panel and remove the device drivers.
3. Reboot if it asks you to, make sure to unplug the device.
4. Goto device manager again, remove the USB hubs.
5. Don't reboot.
6. Goto control panel, add remove software or equivalent for windows vista ultimate.
7. Select creative labs, and uninstall any and every zen related software.
8. Don't reboot.
9. Goto my computer, find the creative directory located on your main hard drive at \program files\creative. Deleted it completely.
10. Select windows media player select uninstall, or downgrade accordingly.
11. Make sure your zen touch is not plugged in and reboot your system.
12. After system loads, plug in the device and run the firmware software again.
And if you wish, reinstall windows media player 10 and the creative software (which you don't need at all with vista) all the other drivers should reinstall themselves.
BTW it's a hell of alot easier to just use another CPU if you have access to one, I've done it both ways and it saves alot of time.
Mar 15, 2008 | Creative Labs Zen Touch MP3 Player
Creative zen sleek photo not recognized by win xp
I got my Creative Zen Sleek Photo from a friend and everything I did wouldn't let Windows recognize it, but then I got it to work almost magically.
1. Make sure you have the proper drivers installed for it that come with the CD. If you don't have the CD, you can download the ISO here.
http://wp.randyr.net/windows-xp/creative-zen-sleek-photo.html
2. Reboot. When it comes back up, plug the cable into your computer, then into your Sleek. The software should sync up. For some reason, my Zen wasn't being recognized from the usb port on my computer tower, but I plugged it into my monitor's USB port and then it worked. Try that, if none of that works, then it may be a problem with your computer not knowing which driver to assign to your Zen, and if so, try the steps below.
1. Plug your Sleek to your computer.
2. Open up Windows' Device manager (right-click on "My Computer" and select "Properties". Go to the "Hardware" tab, then click "Device Manager").
3. Locate the entry for "Creative Zen Sleek" in your device list. It should appear either under "Sound, video, and game controllers" or under "USB Devices". Once you locate the entry, uninstall it.
4. Unplug your Sleek and wait a few seconds.
5. Plug your Sleek back in and allow the "new Hardware Wizard" to identify and install the drivers for it.
Mar 01, 2008 | Creative Labs ZEN SLEEK MP3 Player
Zen Touch mp3 player isn't able to play tracks in windows media player 11
im not sure but i think you have to create the playlist first then transfer to mp3
Feb 20, 2008 | Creative Labs Zen Touch MP3 Player
My zEn...
you should not have had to install anything for the Zen to work on Vista. If you have installed any Creative software, remove it. Reboot, plug your player in, open Device Manager, and remove the device that shows up representing your player (completely uninstall it). Reboot again, and plug in your player. It should be recognized now.
If that still doesn't work, then boot your player into Recovery Mode, and perform both a Disk Cleanup and a Reformat. Reboot the player and try plugging it in again.
if it still doesn't try another computer and upload the latest firmware to it and then try it on your pc after firmware is loaded
http://us.creative.com/support/downloads/
try downloading the MP3 player recovery tool from Creative's website (the tool contains the latest firmware update available -- 1.15.03). Plug your ZV+ into your PC, run the program and let it update the firmware. Then format, reload your music and try it.
Jan 24, 2008 | Creative Labs ZEN V Plus MP3 Player
Confused!!!!
there might still be hope. If you downloaded firmware version 2.11.01 it will not be recognized by creative organizer; you will need to install plugins to make creative organizer recognize it again. Go to www.creative.com/support --> downloads and follow the links to download the plugins. There are 1 or 2 to download. Do you have windows media player 10? If so then the zen should be recognized in wmp 10 and you can download songs that way. If you have windows media player 11, you will need to roll back to windows media player 10 for it to be recognized. NOTE: if you don't use windows media player to sync songs, then just ignore everything I said about it.
Sep 16, 2007 | Creative Labs Zen Touch MP3 Player
19 people viewed this question
 Grubhead
Grubhead
