Question about Zoom 220 HMV 3-Wheel Travel Scooter
Zoom 220.Battery charger shows green light, fully charged.I tested battery at 12plus volts. When I turn on the key the battery charge indicator hand does not move. (It will when the battery charger is pluged in and the key is flipped on). With the brake engaged and key on there is no movement of the scooter when I pull the throttle although the horn works. Brake is engaged. I have pressed the reset button several times. The 10amp fuse looks good.
  • terik5 Jun 20, 2009
    I have checked the connection between the front half and back half of the scooter and it seems to me to be connecting.
  • 790 Answers
Hi
Thanks for using fixya!!!
did you check the current of the battery? The battery reading 12 volts is good!!! but the most important is the current,. the battery current is 12 ampere,. if the current is drop, you have a bad battery and need to replace,. because the motor drive is need more current to move this unit...
or please check the electrical wiring specially the relay junction The Relay is DPDT maybe this have loose contact and need to clean...
Thanks!
Posted on Jun 21, 2009
  • 13,433 Answers
A cable might be lose between the handle bar control panel / instrument panel and the scooter.
I've seen it a few times the wire connectors might come lose if turned too much or hard. The wires are generally on the front, likely under the front cover. cover.
Posted on Jun 20, 2009
Need Homelite Mower UT13122 wiring schematic to check switch problem. Battery fully charged
Check the switch for current flow with and without the key. Then make sure the ground switch is disengaging when you pull the handle.Possible stretched cable.
Dec 11, 2012 | Garden
Pheonix plus batery flat,charged up,now it is mobile but all i have on dial is single red flashing led.
John the red flashing light indicates a low battery When you charge the battery your charger should be showing a red light for power and a yellow light. When the batteries are fully charged you should show a red and green light on the charger. Now if you have a voltmeter plug the leads into the two outter holes of the charger port located under the front of the joystick.Without the charger plugged in you will be reading the battery voltage. Fully charged it should read 27-30 volts if you are only reading 20-24 volts then the batteries are low. If you have an onboard charger plug it in and you should read the charger voltage of 29-32 + volts If you aren't getting that voltage then you have a bad charger if you are getting the charger voltage then you have bad batteries and they need to be replaced Hope this helps you
Apr 18, 2011 | Health & Beauty
Ryobi p103 battery charged but dosen't work.
You need to have the charger tested, if you know that batteries are good then what else could it be. This LIon charger has a logic circuit in it like a computer.
May 17, 2017 | Ryobi Two 18V Lithium-Ion Batteries +...
Have Zoom 220 HMV 3 wheel scooter. Charged battery in house socket. Shows green, turn key shows fully charged but will not move forward or backwards. Horn works.Moved don't have the manual. It is only 1...
It is possible the the battery could be damaged after being stored for that length of time. If it was wasn't completely charged before storage, or if it was exposed to extreme temperatures (even for a short amount of time) you may need to find a replacement battery. http://www.batteryinternational.com/electric-scooter-batteries.html should have the battery you need.
Jun 08, 2009 | Zoom 220 HMV 3-Wheel Travel Scooter
Upon power up, 3 red LEDs flashing rapidly continously, no power.
The control systems on power mobility equipment have a "prevent" circuit that immobilizes the equipment while it is plugged into a charger, so folks won't take off with it plugged into the wall outlet. When you turn it on when plugged into a charger, the display will flash constantly, or sweep constantly, depending on the manufacturer. This is normal. Your off-board charger should have a red light to indicate power to the charger, and another light for the charge status. Yellowish means it is charging, when it turns green, you are fully charged. If the status light is green all the time, that is an indication that the charger is not functioning properly, or that the batteries are below a chargeable state. Check charger output, which should be 26-28 volts dc, and each battery should show at least a 12 volt reading, but around 13.5 volts with a full charge. If one or both of the batteries drops below 12 volts after a short period of time, it's time for a fresh pair. Fully charge new ones before using the chair.
May 31, 2009 | Pride New Jazzy 600 Power Wheelchair by...
Peg perego 12v charger question
The green light means it is ready to use. If the battery is bad though, the light will still be green.
Mar 07, 2009 | Peg Perego 12 Volt Rechargeable Battery
Microtek Inverter not fully charging the batteries
xenion pure shinewave inverter not charging fully
Jan 17, 2009 | Computers & Internet
Rechargable Batteries Battery Charger
When batteries are placed into the charge mode, the red light will come on.
When fully charged, on those units with a green light, the green light will be an indication that your batteries are charged and if your unit has no green light, the fully charged indication will be when the red light turns iff.
Apr 24, 2008 | Universal Battery Charger Charges Multiple...
Zoom 220 HMV 3-Wheel Travel Scooter Logo
158 people viewed this question
Top Zoom Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Craig Butler
Craig Butler
Are you a Zoom Health and Beauty Expert? Answer questions, earn points and help others
