Question about Frigidaire Refrigerators
There is water leaking into my "old Frigidaire"modelFP18TAWO
This has happened before and I think I ungloged something but I cant remember what. I need a new fridge but I also need new hip and I cant get to the stores to comparison shop. I just want it to hold on about another 6 months and then bye bye. can you please give me some ideas on how to stop this???
  • Frigidaire Master
  • 4,655 Answers
I think I can help. All leaks like this start by a blockage in the defrost condensate drain line. If the leak is in the freezer then the rear panel will need to be removed to examine why the tray below the evaporator or the coil inside the freezer. But sometimes the drain gets blocked in its turns to the drain pan below your refrigerator.If so then most likely the water ends up on the bottom of your fresh food compartment. I going to put a link below and left click it and it will take you to a perfect example of this type leak and how to fix it. Thank You Sea Breeze Let me know if this helps.
http://appliancejunk.com/forums/index.php?topic=22.0
Posted on Jun 20, 2009
Leaking dishwasher
Hi, Yes. replace the gasket..
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Jun 19, 2010 | Frigidaire FDB1502RGC Built-in Dishwasher
Frigidaire self defrost freezer is puddling water at bottom of fridge...I unplugged and took out groceries in the whole fridge...how will I know if this unglogged ???and what should it unglog??thanks diane
kind of a pain to get to, but there is a cover on both the front and back of the fridge, if you remove one (or both) you will see a hose that goes to the pan that all of the components sit in, you will have to get pressure to it from the bottom side. I suggest a "gallow gun" available at your local home improvement store, you may also be able to use compressed air in a can from a computer store
Jul 12, 2009 | Frigidaire FRT17G4B Top Freezer...
I have a front loading frigidaire washer gallery 1670 series
I would say yes, its worth keeping. Mine leaked a while ago and I bought a new pump assembly. I think it was about $70. You can remove the two screws on the bottom of the bottom face plate and remove the cover. The pump is on the right side. Look for goo leaking out of the shaft seal. Verify before you buy parts, It could be the rubber boot torn or something similar.
Don't reach inside untill its unplugged.
You can replace the shocks easily too. Lots of parts places online with illustrated parts catalogs.
Jan 19, 2009 | Frigidaire GLTF1670A Front Load Washer
Frigidaire washer machine #FWTBB30DS0
check to see if your drain hose is too far down in the stand pipe this will siphon water out as it fills.
Jan 17, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Frigidaire Water Leak
Have you found a solution to your problem? We started having a a similar problem with our Frigidaire. Thank you.
Jun 18, 2007 | Frigidaire PHSC39EESS Stainless Steel Side...
Fridge leaking inside top
it sounds as though you have a clogged drain.you will need to defrost for 24hrs for good results.also you could have a seal problem near your airflow vent in ref.compartment in this case you would need to contact your local tech.
Jun 04, 2007 | Frigidaire FRT15G4B Top Freezer...
Refrigerators Logo
89 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
