Question about Lexmark X3470 All-In-One InkJet Printer
Printer cover is open, but is closed please help
    President:
  • 3,278 Answers
Check every possible open "door" in the printer. Be certain that the cartridges are installed correctly. Check for even a small jam. If all else fails, "slam" the cover. Good luck
Posted on Jun 20, 2009
Keeps saying cover is open/ please close the ADF cover
The message indicates that the printer door or the cover located on the top is not closed properly, so you need to re-open the door or the printer cover and close it accurately.
GuruAid.com
Mar 08, 2016 | Office Equipment & Supplies
Why my printer always said cover is open and close ink cover but the ink cover is close and the ink is full?
Hi, Try taking out all cartridges, unplug the printer a few minutes.
re plug , turn on. with ink cover open. then close cover and wait to follow the install prompts, This should reset the printer.
be sure to gently push the cartridges till each one clicks.Close cover.
Please let me know if this helps!
Feb 19, 2015 | Brother MFC 420CN All-In-One InkJet...
There is a problem with the pinterhead please help its a lexmark pro705
A firmware update for the Lexmark Prevail Pro705 will help fix the printhead issue you are experiencing. Please follow the steps below on how to successfully update your printer:
  1. Open the printer cover and remove the printhead and tanks (if installed). Note: Carrier will come to the center automatically with this error message as the cover is opened. Remove the ink tanks > open the printhead latch and remove the printhead > close the printhead latch, close the printer cover and confirm the error message goes away from the operator panel.
  2. Proceed with the firmware update. Please visit the Lexmark website to download and install the Lexmark Pro700 Series Firmware Update.
After successfully updating your printer, open the printer cover > re-insert the printhead > close the printer. If no printhead error comes up, continue with normal installation steps for cartridges. If error comes up again, please contact Lexmark Technical Support Center for further assistance.
Dec 11, 2011 | Lexmark X5650 All-in-One InkJet Printer
Printhead is not supported by the all in one
A firmware update for the Lexmark Prospect Pro205 will help fix the printhead issue you are experiencing. Please follow the steps below on how to successfully update your printer:
  2. Proceed with the firmware update. Please visit the Lexmark website to download and install the Lexmark Pro200 Series Firmware Update.
After successfully updating your printer, open the printer cover > re-insert the printhead > close the printer cover. If no printhead error comes up, continue with normal installation steps for cartridges. If error comes up again, please contact Lexmark Technical Support Center for further assistance.
Oct 06, 2011 | Lexmark Prospect Pro205 Wireless...
My lexmark printer x 3470 will not operate....it says the cover is open but it does not appear to be and none of the controls will function.... help please??????
It could be due to the cartridges in the carrier or the sensor for the cover has become stuck. Open the printer cover and remove the cartridges from the printer. Close the printer cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, re-insert the cartridges and close the cover. Check for any errors.
Jun 15, 2011 | Lexmark C533DN InkJet Printer
Cover open sensor is knocked off the switch assembly - Please show and tell me how I can repair it.
Open the printer cover and remove the cartridges. Close the cover. Unplug and replug the printer into the power outlet to reset it. When the printer turns on, reinsert the cartridges. Make sure the cartridges are properly inserted in the carrier and the lids snap in.
Source: Error: 'Cover open, please close the cover'
May 08, 2011 | Lexmark X6570 InkJet Printer
Its showing "close ink cover"
Hi there!
The message "Close Ink Cover" means that the cartridge door is not closed securely.
-please open the ink cartridge cover and make sure all cartridges are installed correctly and then close the cartridge cover. That should clear the message on the screen.
Hope this helps!
May 08, 2011 | Brother DCP 165C Compact Color Inkjet...
My printer keeps stating printer cover open when it is closed please help
Try to remove the sheets of paper from the feeder. Open the printer cover and remove your cartridges. Close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert the cartridges. Make sure they are properly inserted and secured. Load some paper. Check for the error again.
Apr 10, 2011 | Lexmark X1270 All-In-One InkJet Printer
Error Code 077-300 close front cover
I would suggest, turning off the printer. Unplug the printer for about 3-5 mintues and hold the power button for a few seconds causing ALL power to disapate from the printer. Also known as power cycling. Please just insure the toner tray is properly inserted into the printer and close covers. Plug printer directly into the wall. Power it up and see if that helps your issue. If this helps you please rate my solution.
May 21, 2009 | Dell 3010cn Laser Printer
Error mesage
No solution, but I have the same problem. THe printer starts up fine, I hear no grinding noises or other "funny" nioses, and then displays no error message... UNTIL I ask it to print. Then I get a message that says, "Pls (please) Open Cover".
I open the cover and it says "Please Close Cover".
I close the cover and it says, "Please Open Cover"
and this happens forever!
Does anyone have any ideas? Can anyone help me?
Stefan
Mar 05, 2008 | Brother MFC-8440 All-In-One Laser Printer
Lexmark X3470 All-In-One InkJet Printer Logo
157 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
