How can I unjam my sewing machine? The needle wouldnt move atall so it does sew?
Loosen your needle. Turn your handle towards you. You may have to turn a little hard. Now, throw that needle away.Take your fabric away and check the area where your bobbin goes and clean it out of fabric and thread. Now load your bobbin again and load a new needle. Pull your thread up from the bottom by turning the handle towards you while holding the needle thread with the foot down. Now look and place something under the foot and slide it forward while still holding the needle thread. The bobbin thread should come up. Let me tell you this though. Adjust the bobbin thread before you start. This is done by placing the thread in the carrier (usually unwinding counterclockwise) and place the thread under the tension spring. Hang this from your finger and bob it up and down lightly. It should fall about one inch. If it doesn't then loosen. If it falls too far then tighten.
SOURCE: Need an Empisal sewing machine manual
As far as I remember that machine was made by Janome but you will need the model number
SOURCE: i am urgently looking for an instruction manual
The manufacturer is your best bet for a free manual.
SOURCE: empisal sewing machine needle broken
try these 2 sites and ask them about the needles
a1sewingmachines.com
or
sewvacdoctor.com
