Question about Miele Washing Machines
W1930 will not drain, door will not open - Miele Washing Machines
  • lchilton672 Jun 22, 2009
    Yes, I was able to drain the washer, open the impeller pump, removed the small metal washer that was jamming it, and it works fine now. Thanks for saving me the service call! Lee Chilton.
U need to read the user manual, it has everything to do with problems and wat to do and dont.
the following link will help u over there.
http://safemanuals.com/user-guide-instructions-owner-manual/MIELE/W1930-_E
Posted on Jun 20, 2009
Door wont open; water not draining. What's going on?
THe water must be totally drained and it is not. So go back into the area that you used to open the door and look for the drain. If you use that manual drain have a wet vacuum cleaner ready there will be a flood. When you take that drain plug out there should be a filter attached and you will find that a sock or something is plugging it up and not letting it drain. There is a chance the pump motor is bad but usually it is plugged drain.
Sep 02, 2015 | Washing Machines
Miele Novotronic w1930 leaking lower left
Good morning
From what you described it could be that your drain hose is cracked since it is bending on the inside of the machine when you push it in after draining the water.An other possibility could be a clamp failing or th connector on the drain pump that is cracked.
To solve the problem would be to dissmantel the machine to assess the machine on the in side for any devects.
One other thing to check for is the plug on the end of the drain hose,is it a tight fit because it it could be leaking at the plug.
If you think it is not tight enough use a cable tie to tighten it and see if the leak will stop.
Dec 05, 2013 | Miele Novotronic W1930 Top Load Washer
Asko washing machine wont drain
Hi ,it could be a blocked or seized up drain pump.
You can try and clean the pump ,it normally works.
Nov 27, 2013 | Miele Novotronic W1930 Top Load Washer
I have a miele novotronic w 1930 front load washer that for all practical purposes appears dead. No lights, nothing . I checked the breaker and the fuse box that miele's use and dryer still functions...
Also look for a fuse on the board. Sometimes they put a simple fuse on the board that goes out and the repairman replaces it with a whopping bill to boot.
Nov 04, 2013 | Miele Novotronic W1930 Top Load Washer
Washer w1930
check drain pump for damage or clog.
thanks,
Nate
Aug 13, 2008 | Miele Novotronic W1930 Top Load Washer
Door locked light is staying on and door will not open
possible machine has not drained - this will prevent door opening.
put drain hose at floor level into a tray and drain that way then switch off at mains, wait 3 mins and see if door opens
Aug 07, 2008 | Hotpoint Aquarius WD63 Front Load...
Program selector know is broken
First thing i would do if it is not selecting a different cycle is take the knob off and check to if the inside of the knob is broken and hust turning on the shaft, other then that it proberly is electronic replacement.
Oct 27, 2007 | Miele Novotronic W1930 Top Load Washer
Washing Machines Logo
47 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
