Question about Parsons QuickVerse 2005 Expanded Edition (11149)
Quickverse 7.0 loses Greek & Hebrew fonts
I installed Quickverse 7.0 on my new Vista laptop. The installation was successful, but every time the computer is shut down and restarted, all Greek and Hebrew characters, in all books, are replaced with gibberish. I have to uninstall and reinstall to correct the problem, every time the computer is turned off.
I purchased Hebrew Tutor and cannot install it on my Windows7, 64-bit computer. Please help.
Unfortunately, the Hebrew Tutor from QuickVerse was written for older Windows OS versions. It supports: Windows 95, 98, ME, 2000, XP Home, XP Pro, or NT 4.0. The changes in the Windows OS over time has made the installer totally different and the program isn't signed for a 64-bit OS. http://www.quickverse.com/shopfiles/product_details.asp?ID=41011 has the support details.
There are two possible ways to work around the issue. The first is to try to install the program (and then run it) in the compatibility mode. This may work but often doesn't. Right click on the installer (from the CD's directory) and choose Properties. Then go to the Compatibility tab and chose Run this program as compatible with XP. Save and close the properties box. Then right click again on the installer and choose Run as Administrator. If it installs, repeat the compatibility process on the program itself.
The solution most likely to work is to use a computer with the compatible OS versions. This could be a physical second computer, a dual-boot machine or a virtual computer. If you have Windows 7 Pro or Ultimate, you can run the virtual computer with XP for free. Download and install Virtual PC and XP mode (in order) from Microsoft. For other setups, you will need a licensed version of the older Windows OS. Virtualization packages include Virtual PC, Parallels and VMWare. Then install the Hebrew tutor as you normally would to an XP computer. (Note: virtual computers do not share hardware with the real computer. You can only install a printer to one machine at a time. You can share files by saving them to external media (optical RW disc or flash drive for example).)
I hope this helps.
Feb 21, 2011 | Computers & Internet
Quickverse 7.0 and vista
run msconfig and check if any Office programs
are running at startup uncheck them or delete the entry run from the registry ,and any Office programs that
are running during installation it exist
Dec 19, 2007 | Parsons QuickVerse 2005 Expanded Edition...
My Clarion application sends codes directly to the (TM-H6000II) printer. I need to print in Hebrew but the printer seems to insist on Greek (I think!). I added the following code to the printer start: ...
This most likely requires that you get the Hebrew Font set from the Manufacturer and install it in the Printer Firm ware or update the Hebrew Font Set in your computer software. Either should resolve your problem. The printing that you currently see is, without actually seeing it, the result of the printer trying to print character codes that it does not recognize. I would try updating the Firmware in your printer first then if that failed update the Hebrew Font codes and character set and install that. Epson should have the download on their website. The information you need for the software Font download will depend on what software you are using.
Aug 31, 2010 | Epson TM-H60000II Thermal Printer
Parson's quickverse 8.0 doesn't show greek and hebrew fonts on my Vista machine but it worked fine on my Windows XP machine???
it is possible that your sytem does not contains the additional fonts required
download these fonts and drag drop them into the fonts folder in the control panel and select install when prompted
Jul 07, 2009 | Parsons QuickVerse 2005 Expanded Edition...
I have used Quickverse VErsion 7 Deluxe for years on previous laptops using Windows 98 and Windows XP. However, I have installed it on my new laptop using Vista 32 bit and if I right click on the desk
From their website
Question 1:
Can QuickVerse 2007 run on Windows Vista?
Answer: Configure QuickVerse 2007 for Microsoft Vista Compatibility Mode
  1. Download and install the latest Maintenance Release
    Browse to the Program Files folder for QuickVerse 2007
  2. Configure Compatibility Mode for these 2 files:
    C:\Program Files\QuickVerse 2007\qv11.exe
    C:\Program Files\QuickVerse 2007\QVBookManager.exe
  3. Right-click each file listed above and select Properties on the Menu
  4. Click on the Compatibility tab and make the following selections for both files listed above:
http://www.quickverse.com/Shopfiles/Faq.asp?ID=QV2007WIN
Apr 23, 2009 | Computers & Internet
Installing QV 7 produces warning MS DAO preventing installation.
I,too, have the problem of installing my Quickverse 7 on my computer with Vista. What do i do to stop the running of Microsoft DAO?
Apr 08, 2009 | Parsons QuickVerse 7 Essentials (fe11044)...
Want to install Quick verse 7 on Vista
the Quick verse 7 was made only for 95 98 2000 and XP but you can try this method on how to install the QV 7 on winXP sp3
"Install QuickVerse Essentials version 7 on WinXP w/sp3
Place the QuickVerse version 7 Essentials CD into optical drive & close tray. This begins the auto run / install process. (Please do not remove CD until right at the end!)
Installation menus appear. Accept the defaults and choose “Typical Installation” (85Mb)
Message box appears at the end of the installation: “QuickVerse installation has encountered a problem and needs to close” Choose “Don’t Send” The installation program exits.
Navigate to: Start Button / All Programs / Parsons / QuickVerse 7 / (from drop down list) find “QuickVerse 7.0” and right click on it. Select “Send To Desktop”
Click on the new QuickVerse 7.0 desktop icon to run the program.
Dialog Box appears, “The librarian datafile library.mdb not found etc…” Select “New” / "Open Book" dialog box appears click on “Close”
Now with QuickVerse 7.0 running go to File / Add Books. “Registration Guide – Introduction” box appears. Choose “Next” The path to the new collection to register should identify the optical drive (with the QuickVerse CD already inserted) Choose “Next”, “Next” and “Finish” ("Registering STEP Books" msg box appears)
Customize Option: select “No” (default) then “OK”
Go to File / Library management. “Library Management – Maintenance” box appears
The Left Hand (LH) pane shows:
Default Drive
Highlight QV Essentials in the LH pane. The RH pane shows all the books present on the CD. I chose to install only the NRSV w/Apocrypha book. Drag and drop this book to the LH pane i.e. Default Drive.
“Transferring Book Files” msg box appears whilst the book is being copied from the CD to the hd.
Close the dialog, exit the program, remove the CD and you’re away…"
hope this helps./
Nov 04, 2008 | Computers & Internet
I tried the following and it works. I had several bad installs and this works. My guess is that the first steps are not necessary, but they won't hurt.
1. Insert the first CD and explore to find the autorun file. Right click and choose properties, and run it in compatability mode with Windows 98.
2. Right click again on the autorun file and choose to run it as administrator.
3. Follow all the regular steps for installation.
4. On the new shortcut, right click and choose properties, run in compatability mode with Windows 98.
5. Finally, right click on the shortcut icon and choose to run the file as administrator.
Good luck. It is a wonderful software I have had for ten years and used on a half dozen computers.
Nov 17, 2007 | Parsons QuickVerse 2005 Expanded Edition...
Iphone
In order to view Hebrew website, you need a jailbroken iPhone with Cydia installed in it.
Please follow the steps .
1. Add the source to cydia, and pick one of the following options :
  • To install a fully localized Hebrew interface – search for the package iVrit and install it
  • To install Hebrew fonts & keyboard only – search for the package OpenHebrew and install it
  • The source is :
http://tom.zickel.org/openhebrew
Oct 03, 2007 | Apple iPhone Smartphone
Cannot install Quickverse 7 version from year 2000 because of Microsoft DAO.
Hi, I had the same problem and fixed it, (loaded my quick verse bible software by loading the software in SAFE-MODE. This mode stops the dao that is running. (probably micorsoft office at start up). This solution worked perfect....God bless
Sep 06, 2006 | Parsons QuickVerse 7 Essentials (fe11044)...
Computers & Internet Logo
357 people viewed this question
Top Parsons Computers & Internet Experts
Marvin
Marvin
tdk1988
Thomas Perkins
Thomas Perkins
Are you a Parsons Computer and Internet Expert? Answer questions, earn points and help others
