Question about Microwave Ovens
I have a whirlpool self cleaning oven door that will not open. I have tried disconnecting it for over an hour. I have taken off the back cover but I can not see how I am supposed to disconnect the arm. How do I get the door to reopen. I do not use the self cleaning option anyways, so I really do not need it. Marlowe
  • 583 Answers
Check door/latch switch and replace if defective.
You will need to unplug your range, then move it out from the wall, then open the back access panel, by removing the screws, then you will see your lock latch motor switch assembly, here is a photo of it.
http://www.repairclinic.com/SSPartDetail.aspx?PartID=1154660&PPStack=1
thanks for using fixya.keep updated.
please do not forget to accept and rate this solution positively
Posted on Jun 20, 2009
Oven door will not open after self cleaning cycle
There is a thermostatic control with prevents the oven door from opening until the oven has COOLED.
May 09, 2015 | Microwave Ovens
I have a whirlpool oven. I ran the self cleaning cycle,let it cool down for a day and ride to open the door. It wouldn't open. I then cycled the circuit breaker and tied again. No good. There appears to be...
sad to say but way too many of us have gotten lazy , even I do at times but self cleanings ovens have always been a problem. the excessive heat required is costly and burns up many elements among other things
Oct 29, 2017 | Whirlpool RMC275PVQ Built-in Microwave...
How do you start the self cleaning oven process on a kenmore stove purchased from Sears in 2009?
  1. Empty the Oven
    • Take everything out of the oven. Remove the racks and clean them with soap and water in the kitchen sink. Look for any loose debris such as foil or charred food and remove that as well.
    Oven Cleaning
    • To operate the self cleaning mode, find the switch on the range marked "Clean." The oven door will lock once the cleaning operation has started. Do not open the door until after the self-cleaning process has completed. It will take between two and three hours.
      During the cleaning process, you may see and smell smoke. This is normal because the oven is operating at a higher temperature than when it is cooking. The high temperature is reducing all the organic matter in your oven to ash. You will also sometimes hear popping sounds from the oven that is caused by the expansion of metal under extreme heat. This is normal for a self-cleaning operation.
      After the oven has completed the cleaning cycle, allow it to cool for a couple of hours. Once cool, take a damp dish cloth and remove the ash from the bottom of the oven. Wipe down the interior of the oven door and around the seal. Be careful around the seal so you do not damage it. Replace the racks back in your oven, and the cleaning operation is complete.
    Other Considerations
    • Clean your oven at least once every three months. If your oven gets heavy use, consider cleaning it once a month. Always run the self-cleaning cycle when you are home. Because it uses intense heat, it is best to perform this operation later in the evening or early in the morning.
Aug 10, 2011 | Microwave Ovens
How do I use the self-cleaning function on my Whirlpool Super Capacity 465 self-cleaning oven?
If you just want to run the basic self-clean cycle. First remove the broiler pan and racks from the oven. Next clean any heavy spills up with a non-abrasive cleaner (do not use an oven cleaner). Clean the window of the oven door and the door frame (to the outside of the gasket). Then close the oven. If the oven has a touch-pad, press the Auto-clean pad on the oven followed by Start. The oven will automatically lock and then unlock when the oven has cooled after the cleaning cycle. (I'm less certain of the control settings for the dial type of oven control.)
In order to get your manual you need the full model number of the oven. This is on a plate located behind the storage door. This pdf, http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/ca8e028c60d9804f85256a8c00621f04/$FILE/4322089.pdf , gives you a picture of where the model and serial numbers are is on page 4 as well as some of the information contained in the serial number on the subsequent pages.
Once you have your model number, go to http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=WHRCOM and enter the model number. This should let you get the manual specific to your oven.
I hope this helps.
Apr 26, 2011 | Whirlpool Microwave Ovens
Error code F5:E7 Can not get the oven door unlocked or reset this code. What do we do?
Beginner on forumn, don't have any manual in front of me on f5:e7. Sounds like a conventional oven problem, oven door locking. If in fact is some form of conventional heat oven (convection?), I had similar problem with a GE range, it flashed some kind of code seams like which I later interpreted by using owner's manual that explained codes. In my case it was in "cleaning mode" and you can't turn that off unless you unplug or turn breaker off, that puts it back to default mode with nothing running. I simply tried out the self cleaning feature, from there the oven went to full on heat and oven door locked unexpectedly. I learned stays locked till cycle finishes and oven cools, which is some time after the oven automatically switches off, said that it can be a couple of hours before you hear a...click, and now door opens (note to self, don't ever do that again).
Jan 13, 2011 | KitchenAid Microwave Ovens
I have a kenmore microhood 63684 turned lites on and can't get them to off,when fan button is pushed fan does not start but when lite button is pushed after fan is energized fan starts real slow and...
What this simply mean is that there has been a problem from the fan either from the wire connection or from the Cole of the fan connected to the fan motor.
There are two ways of over coming this type of problem below are the recommendation to solve the problem
First of all set the oven on self cleaning from the below instruction or make use of your owner manual to operate the elf cleaning
Please after the self cleaning you most allow the oven to cool down to it best before opening
Some ovens are self cleaning During the cleaning process, the oven heats up to a temperature of 900 degrees Fahrenheit. The extreme heat cooks off food and spills inside the oven, leaving ash that can easily be wiped out. The oven door locks while it is cleaning to prevent the door from being opened. Self cleaning ovens are better insulated than regular ovens to keep the extreme heat inside.
  1. Read the owner's manual that came with your oven before you perform self cleaning. Although all self cleaning ovens work basically the same way, there may be slight variations for some manufacturers and models.
  2. Take out the oven racks. You need to clean the oven racks by hand, and then put them back in when the oven is done cleaning.
  3. Wipe up any spills and messes inside the oven first, using warm water and a mild soap. Ovens smoke more during cleaning when there is food inside. Wash the inside of the oven door as well. Do not scrub the door gaskets, just gently wipe them off. Damaging the gaskets prevents the oven from sealing.
  4. Lock your oven door manually if your model does not lock it automatically when you clean.
  5. Open a window near the oven for ventilation. There is a certain amount of smoke when you clean the oven. The dirtier the oven is, the more smoke is created.
  6. Turn the control on your oven to "clean" and set the timer for 2 to 5 hours depending on how dirty your oven is, and what the manufacturer recommends.
  7. Wait for the cleaning to finish and the oven to cool before opening door. When oven is fully cooled wipe up any ash inside. If your oven is not completely clean, next time set the timer for longer. If your oven is spotless you might want to see if you can get away with a shorter cleaning time.
SOLUTION 2 IF THE ABOVE RECOMMENDATION DID NOT SOLVE THE PROBLEM
Then you will have to replace the hole of the fan from the oven i.e the fan is need to be service
Hope this help?
Thank you and thank for using fixya.
Nov 26, 2010 | Kenmore 63682 / 63684 / 63689 Microwave...
I have a Thermador ME272 double-convection wall oven. After self-cleaning the bottom oven, the bottom oven won't turn on. When I press Lower Oven or Self-Clean on the control panel, I get no beep and...
I would almost guarantee the thermocouple is bad.It is a small rod whose wires come out from the back wall into the oven and is mounted inside the oven,usually near the top.This is a common fail component in ovens due to the temperatures it endures over time,especially with self-cleaning because they usually go over the maximum temperature cooking allowed during cleaning.If you want to test it yourself,you or someone can swap out the 2 thermocouples as they should be identical..Make sure the circuit braker is pulled first.Behind the oven there is probably a cover which is fairly easy to access.If it is possible to switch the 2 connectors without removing the thermocouples,it would obviously be much quicker.If you switch them and turn both ovens on,the problem should switch ovens also.If you switch the thermocouples and the problem DOES NOT switch ovens,the bottom doesn't work but top still does,the circuit board is bad.Wait about a half hour before touching the thermocouple after heatup and leave the door open.Good luck,Greg
Nov 20, 2010 | Microwave Ovens
I HAVE A DCS OVEN AND I USED THE SELF CLEANER ON IT ON SUNDAY NIGHT. WHEN I WOKE UP ON MONDAY MORNING THE CLEANING LIGHT WAS STILL ON EVEN THOUGH THE OVEN WAS COOLED DOWN. WHEN IT WOULDNT OPEN, I USED A...
Hi.
The Oven getting lock after self cleaning is not uncommon.
That is caused by the high temperature reached on self cleaning, that can jam the control board or damage the door lock or the temperature probe.
Try first tripping circuit breaker or disconnecting power cord for five minutes.
After restarting try the oven.
If the oven still does not work, then hold down the cancel button for ten seconds.
If still no luck, then the oven is faulty in consequence of the extreme temperature reached in self cleaning.
If the Oven has regular display, then faulty part is usually the temperature probe.
If oven has no display, then the control board may had been damaged.
I can understand what problems a faulty oven can be in this moment.
Try first the reset, if that does not work, ring the number listed at the end of the owners manual to see if today any technician is available.
A local technician could easily put back the oven to work, replacing the probe, the point is that it will be difficult to find a technician right now.
Let me know if the reset works.
Regards.
Nov 24, 2009 | Microwave Ovens
DOOR SHOWS OPEN BUT IT IS NOT
After self cleaning the range the door won't open....
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Hope this may help;
DON'T FORGET TO HELP
Sep 06, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave Ovens Logo
22 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
