Question about KLH R5100 Receiver
How do I switch to optical input? - KLH R5100 Receiver
Zone 2 is mute with optical input
You can't use a digital input in zone 2. Only analog inputs can be used.
Jan 20, 2014 | Yamaha RX-V659 Receiver
Connect Apple tv to Philips LX700
OPTION 1 (using remote):
Press the system key on the remote,
find the digital input option,
choose optical,
finish!
OPTION2: (Using LX700 button)
"program" button on the front panel for 5 seconds,then press LEFT or RIGHT button to choose DIGITAL INPUT,and Press "program" button again,then change coaxial to optical by rotating VOLUMN control on the front panel. then just confirm by pressing the "program" button again and wait for 5 sec to quit menu. Now switch OFF and switch ON receiver again.
Now make sure the source id DISC IN (ie., digital input ).
Your LX700 should be picking up optical signal!!
It worked for me and i hope it works for you to as well.
-SASi (ssasi2000@gmail.com).
Dec 15, 2012 | Philips LX700 System
How to hook it up to new emerson tv without s-viedo connection
Hi,here is my solution...
If you want to listen your TV on your Stereo system thru your receiver,
** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to respective mode on RECEIVER corresponding your RCA or Optic connection...
There you go..Your TV sound is on the Receiver..
If you want to display your DVD on the TV,than do everything visa versa..as;
**connect "Video Output " RCA jacks or "Optic cable output" of your Receiver
** to "Video input " or "Optic Cable input"
of your TV and make a selection corresponding input of TV
Hope this helps!
Take care and please
Remember to rate/vote and give me 4 Thumbs Up to continue f
or Helping out the Community :)
Apr 10, 2011 | Curtis DVD6041 System
Can not get sound through surround system from the tv
check to see if yr plugged into line out,on tv.its usually [on sony]an optical out.go thru the input setup on yr amp,on the GUI,and switch tv input to OPTICAL,usually OPTICAL 1.try that
Jun 12, 2010 | Audio Players & Recorders
Switching digital inputs with a remote?
The default assignments for the digital INPUTs to Source names are:
OPT1= Video2
OPT2= CD.
If you have never changed them you should be able to select the PS3 by choosing Video2 and the 360 by choosing CD.
Or you could go into the setup routine on Page 33 of the manual and assign each digital input to a different 'function' that works better for you.
By the way, if you have the choice of coaxial vs optical cables on a given device the cheaper, longer and least sensitive-to-dirt-and-damage choice is coaxial - plain RCA cables. You can even extend them with Male-Female extender cables or split them with Y-cables for sharing one port with two devices or one device feeding two other devices (example: Cable Box-to-TV-and-Receiver). Just don't have two sources feeding one input turned on at the same time or they'll interfere with each other. Try that with optical cables.
Mar 10, 2009 | Onkyo TX-SR304 Receiver
Htr430
Yes, you can switch between Coax and Optical inputs, but not using the remote. Press the button "Input" on your HT-R430
Jun 04, 2008 | Onkyo HT-S680 System
Optical inputs
Hi boltbob
Strange one... . The unit has'nt just lost its presets for optical input selection by chance. Most receivers have a volatile memory for user presets that can reset input settings to default when the unit has been unplugged for a period of time. This may mean that your amp is not looking at the optical inputs for that source. If it has correctly selected the optical inputs, then something common to all optical inputs has failed, maybe a a buffer stage between optics, D/A or Source switching stages.
Try disconnecting the unit from the wall socket for 10 mins to do a hard reset and see if that has any resolve to the issue.
Other than that, its out with the multi meter anbd do some DC checks about the optical , buffer and d/a stages. Try the reset and let me know how you go.
regards
robotek
May 05, 2008 | Denon AVR-3805 Receiver
DVD optical/TOSLINK input no longer working
If it's only the DVD input, and you had tested it systematically, like you'd stated, then the input connector could be loose or defective.
iTritek Solutions
www.itritek.com
Mar 24, 2008 | Panasonic SA-XR45S 5.1 Channels Receiver
I have two optical inputs the one one the left works wellwith my dvd player. I tried plugging my satalite into the other optical input but it won't let me change the tv button to digital
Discovered, with help, that the manual actually did cover this. Around pages 20-21 described the way that you can set which inputs each of the OPT1/OPT2/COAX inputs get assigned to. Basically scroll through the different setup options on the remote till you find the settings for the OPT2 - in my case it was set to "Off" - which explains things. Just switched to TV and voila, worked great.
Jan 22, 2008 | Pioneer VSX-D409
Kenwood vrs-6100 receivers optical digital
You want to receive the optical signal from the TV's built in decoder / receiver to play through your Kenwood? Maybe you need to select the digital input. The manual says:
Use the INPUT SELECTOR key (or Input Selector keys)
to select DVD, VIDEO or FRONT AUX.
2 Press the INPUT MODE key.
Each press switches the setting as follows:
1 "F-AUTO": Auto detect
("AUTO DETECT" indicator lights up)
2 "D-MANUAL": Fixed to digital input
("DIGITAL" indicator lights up)
3 "ANALOG": Fixed to analog input *
("AUTO DETECT", "DIGITAL" indicator goes off)
Also check your TV to make sure it is outputting to the optical jack.
Jan 11, 2008 | Samsung HTP-1200 System
KLH R5100 Receiver Logo
55 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
