Panasonic DMR-E85H DVD Recorder
Problem for Panasonic DMR-E85H DVD Recorder
DMR-E85h - Please wait error - capacitor replacment
By paul913 on Jun 21, 2009
I have the "please wait" error on my DMR-E85H. I replaced capicators c1270 & c1271. Upon turning the unit on the c1271 cap blew up.Any Idea as to what I might have done wrong or what the problem might be?Paul
Comments:
Jun 23, 2009
- I have the "please wait" error on my panasinic DMR-E85H dvd player. I replaced capicators c1270 & c1271. Upon turning the unit on the c1271 cap blew up. Any Idea as to what I might have done wrong or what the problem might be? Is it possible that I got one of the leads too hot when soldering? Should I try replacing the one again?
Paul
Jun 27, 2009
- It was a polarity issue. I had one in backwards. I was not aware that they were + & - and was not able to see the writing on the circuit board until I got a magnifing glass. Thanks, Paul L.
Best Solution
posted on Jun 23, 2009
Very Helpful)
welcomejee
Rank: Guru  Panasonic Televisions & Videos  Expert
Rating: 89%, 3226 votes
Capacitor blow up if its polarity in circuit is incorrect or its working voltage is lower then volts in circuit.
Polarity= capacitor has 2 pins and usually one is marked with Negative mark ( - )
Working volts= each capacitor has 2 details, one is its capacity and other is operating volts range. for example 100MF/UF 25Volt...100MF is its capacity and 25V is its working volts limit and must not be used in circuit having above volts.
In your case 2 possibilities, either capacitor was put in opposite polarity in circuit or its working volts are less then old capacitor.
Please wait error comes in DVD players when sled motor of optical lens does not work, please slide optical lens 2-3 times by holding its sides with fingers. Do not forget to unplug unit before doing so.
Thanks.
Solution #2
posted on Jun 21, 2009
Somewhat Helpful)
INTERLOGIC
Rank: Wiz
Rating: 76%, 172 votes
service.us.panasonic.com/OPERMANPDF/DMRE85H.PDF
Comments:
Jun 21, 2009
- panasonic.com.au/content/library/files/F000766.pdf
Popular Solutions for Panasonic DMR-E85H DVD
Questions and Unsolved Problems for Panasonic DMR-E85H DVD
Do you recommend Panasonic DMR-E85H DVD Recorder?
Answer
Answer
it was working but you had to leave it on for a couple of hours before the power came on now ther is... (More)
Answer
DMR-E85H won't let me change clock. When I plug it in, the message on display is Please Wait. Then... (More)
Answer
what can i do when the panasonic dmre85hs machine freezes after 2 two seconds on power up with no... (More)
Answer
How do I change the code so it is region free?
Answer
How to record with out a remote control (DMR-E85H recorder)
Describe your DVD Players problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Player Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
