Question about AT&T CECT Unlocked i68+ Quadband GSM FM Mobile Phone+Free gift Smartphone
I68+ phone is not allowed me to make calls or receive calls.
I just purchased a I68+ 2GB quad band phone, I have placed the sim card in the phone, check with my wireless company to make sure it is compartible and also they told me that my sims card is ok. Once I placed the simcard into the I68+ reads the card but is not allowing me to make calls. This the summary of messages that i am getting on this phone
Emergency calls only
Unable to connect
Please help me any solutions to the problem?
  • Anonymous Mar 28, 2014
    Received Snapfon EZ two as a gift placed battery and simcard that came with phone into phone but phone tells me that it is an Invailed sim card what do I need to do
Hey,i just got mine yesterday and i experience the same thing but i figured out how to do it on my own.im a fourteen year old and was surprised that i got it but heres how you get it to work...
first, go to settings and hit dual sim settings.
second, theres gonna be four options theres:dual SIM open,only SIM1 open,only SIM 2 open,or flight mode.depending on what slot you put your sim card in thats the one youll choose,i put mine in the first slot so i hit only SIM1 open.\
next, you take the back off of your phone and double check that your sim card is in the correct slot.
then, put the back of your phone back on and turn your phone on.
finally,when it turns on your network should come up the the top where it used to say insert SIM1 or insert SIM2, and i have at&t so when i turned mine on single showed up at the top right under the little symbols at the top.
i hope this helped.
if not,i apologize lol
have a nice day(:
Posted on Jun 21, 2009
3 Suggested Answers
Onifade
  • 268 Answers
SOURCE: A safe JAVA platform for my Sciphone i68 Quad-band
www.getjar.com
Posted on Dec 25, 2009
SOURCE: my sciphone i68 says emergency calls only when i try to use it
We had the same problem on both of our new sciphones. After long hours of research we finally found an easy solution to it so hope this helps.
1) Shut down your phone completely (you will know because a red sign will come up on your phone and you have to confirm that you are shutting it down).
2) Take our your battery and then your sim card
3) Make sure that your sim card is in the right way. (It has to be on the highest slot, not the one closest to the bottomof the phone, and the metal plates have to be facing down, or towards the phone).
4) Reinsert your battery and then start your phone up again
5) Go to restore factory settings and plug in the code 1122 when it asks for one. NOTE: Your phone will reboot, and when it turns on it should be okay.
We tried everything and this is the only thing that worked. We had t-mobile sim cards for both phones and it worked fine. Good luck!
-twins-
Posted on May 13, 2010
Hi I bought a iphone 4 clone in china. I'm not sure about the model: the label inside states: Model F8+. It is a dual SIM, GSM/GPRS GSM quad band 850/900/1800/1900. The phine worked in china with my...
Ciao! Go to settings- SIM card settings and set both SIM cards as active, usually it helps. If not, reset the phone settings, the code is 1122. Spero che ti risolva la tua problema.
May 15, 2011 | Apple Cell Phones
Hey I have a problem, my chineese iphone 4- when i try to call it makes a message: " not allowed do dial" and I can't change my prefferred mode from WLAN only to GSM only.. how to fix it?...
Not Allowed to Dial Error Message on a SciPhone i68 4Gsciphone-i68-4g.pngI recently purchased a SciPhone 4G with a dual sim card phone. I was very happy with this phone. I had no problems until one day I couldn't call out. I kept getting a not allowed to dial message every time I tried to call anyone.
I could still receive calls and send and receive texts but I couldn't call out. After quite a bit of research on the internet I came up with a solution. None of the solutions available had all the information I needed I just kept trying different combinations until it worked.
Here is the step by step solution I used to remove the "not allowed to dial" message and allow me to dial out again.
  1. turn off the phone
  2. place 2 sims on the phone
  3. restart the phone
  4. keep the WLAN disabled
  5. enter the engineering mode * # 82043036 #
  6. select the option RF Test Tool (on my phone it's option 13)
  7. Select GSM, to accept him
  8. go to Power scan
  9. go to Band Select and select OK DCS1800
  10. another screen will appear (model F003) look at each of the options until you find one that will have your phone appear unresponsive (this locked)
  11. pressing the main button (the box) will take you to the home screen
  12. go to the setup menu
  13. go to network settings menu SIM1
  14. this is a preferred mode
  15. select one of the preferred modes GSM or WILAN
  16. restart the phone and you should be ready to make calls
sciphone-i68-4g.jpgYou just enter the code/s into the phone number area in the dial section and the phone will recognize it and enter into the proper mode.
I still love this phone. It has built in WIFI so I can surf the internet with out having to have a data plan from my service provider. I use T-Mobile.
Here are the particulars on my SciPhone:
Mode: i68 Quad Band Phone
Specifications:
  • Dual SIM
  • Dual Standby
  • WiFi
  • Bluetooth
Mar 17, 2011 | Cell Phones
I need a manual
Check this out. It can be of some help to you
http://www.lightinthebox.com/i68--Dual-Card-Quad-Band-JAVA-Ultra-Thin-Flat-Touch-Screen-FM-Cell-Phone-Black--2GB-TF-Card--SZHX0012-_p54335.html
Feb 26, 2010 | Motorola Cell Phones
My sim card doesnt work in my sciphone i68+
I see that this had been a while. The reason that your Sim cad doesn't work could be various: 1. Make sure that your phone is quad band, if it's a tri band then make sure that ATT works in 1900mhz. If it works only in 850 and your i68+ is a tri band, (which is not suppose to) then it will never work. As far as I know all i68+ original are quad band, some fakes i68+ are sold as quad band but are actually tri-band. 2. If you ATT sim card is a 3g card, it won't work either. These phones are not yet equip to work with 3g. I hope this clear up at least a little of your doubt with the Sciphone.
Sep 01, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Only emergency calls on my unlocked CECT i68 3g phone.
This phone is a POS.  Sounds like it can't read the SIM card, and therefore only 911 calls are available.
Jul 08, 2009 | Dual Electronics CECT P168 Cellular Phone
My sciph I68+ reads the card but is not allowing me to make calls
take out the sim card and turn it around with the chip facing the opposite way example if the chip is facing down then flip it over i got a sciphone i68 last night and had the same problem the guy i got it from told me how to fix it
Jun 26, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
CECT I9 does not let me make calls!
the band is 850 (you can switch this manual or let it switch automatically)...on cell go to call center / call settings and switch end call to off....
Jun 21, 2009 | Dual Electronics CECT P168 Cellular Phone
My sciphone i68 says emergency calls only when i try to use it
-twins-
Jun 20, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Chang Jiang A968 Quad-band Dual SIM Mobile Phone With TV
have teh phone replaced or try manually setting the network
Dec 28, 2008 | Cell Phones
Bought new LG Shine KE970 online. Supposedly unlocked. Insert sim for AT&T and can use phone features, but phone screen reads "limited service" and will not allow me to connect to the...
Phone is a tri-band phone instead of a quad-band one. Will not work on ATT network in home area and many others due to many tri-band phones not being supported on the ATT 850mhz network.
Aug 08, 2008 | Cell Phones
AT&T CECT Unlocked i68+ Quadband GSM FM Mobile Phone+Free gift Smartphone Logo
520 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
