Question about Freezers
Woke to water all over floor. Condenser too hot to
Woke to water all over floor under freezer. Condenser too hot to touch. Fan, inside light working but freezer appears to be slowly warming up inside. Possible fixes?
    Sergeant:
  • 340 Answers
Is it clean? compressor out on over load. call for service.
Posted on Jun 21, 2009
Water on floor
The hose that goes into the drip pan to defrost the refer is plugged with stuff.
take the back off and see the hose connection.A coat hanger works well.Usually a 1/4" hose.
Also see where the bottom of the freezer drains into the drip pan.That may be plugged,also.
The temp may be set too low and the condenser is frozen up,leaking water into the floor.Just ice stuck to the condenser.
Possible that the condenser FAN stopped turning. That will ice up and melt at random:
see/hear that the fan is working.
If stuff gets into the fan,it will ice up,melt and make a mess on the floor.
Nov 26, 2012 | Sub-Zero 700 Refrigerator Freezer...
My Siemens KG36U170 fridge (upper) over freezer (lower) continually produces water in the lower section which freezes on the floor inside under the lower container and needs hacking out every couple of...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 22, 2011 | Siemens Freezers
Inside fan runs but freezer is hot
On this video, Delfield refrigerator with freon issue (restricted system)
May 06, 2011 | Delfield Upright Freezer 403
Beko fridge freezer not working
The first thing I would do is to check the compressor and the condenser fan. Remove the cover on the back of the fridge and check how hot is the compressor? Is the condenser fan turning well? Also check the condenser coil under the fridge, it is very possible it needs cleaning.
If the condenser fan is not working properly then it has to be replaced.
If the condenser fan motor is fine and the cleaning did not help then the sealed system is low on Freon and in such case you need a certified technician to fix a leak and to charge the system.
Good luck in solving the problem of the freezer...
May 06, 2011 | Freezers
Freezer not cooling, food is defrosting, model# 28042 sears ask me to clean off the coil where is the cooling coil located
To answere your question : The cooling coil is called the evaporator and is located behind the backwall of the freezer.....But this is not what they want you to clean. They want you to clean the condenser coil, witch is either the big black coils on the back of the unit or they are located under the unit.
you might also make sure you here the fan inside the freezer. open the door and press the door switch and see if you here the fan running. if you don't, then you might have a evaperator fan motor that is bad.
The next thing you shoud check is the back wall of the freezer have frost or did it have frost on it. if it did you have a defrost problem.
This is where you should start. There are many other things that could be rong.
Jan 07, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Water leaks onto floor once a week or so from under freezer
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Nov 21, 2009 | Frigidaire 12 cu. ft. / 340 liter Upright...
Freezer is not cold and evaporator fan (inside
ok well... those pipes coming from your compressor one of them should be hot. if not your compressor is not running.
Nov 10, 2009 | Amana Freezers
I have 16.7 upright Frigidaire Ultrafreeze freezer, Model AFFU1766DW3 & SERIAL #WB51720061, manufactured 04/05 that I purchased new 11/05. Water was on the floor next the the freezer but the light on...
Oct 24, 2009 | Frigidaire Freezer 16.7 Upright Freezer,...
Electrolux premier eco freezer leaking. Water appearing on the floor. Ice building up inside the freezer.
Oct 11, 2009 | Freezers
Water leaking onto the floor from freezer drain...
Sep 20, 2009 | Freezers
Freezers Logo
99 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
