Question about Hotpoint Kitchen Ranges
The top burners won't light after converting from lp to natural gas
  • 199 Answers
Natural Gas needs more O2 than Propane per volume to fully oxidize(burn). Essentially all you need to do is enlarge the air intake holes. 15% increase in diameter of the holes is a good starting point. That equates to 25% increase in volume. You can also buy a conversion kit. Please use the pipe thread sealant and follow the instructions carefully.
Posted on Jun 20, 2009
Convert lp natural gas
To convert a lincoln LP gas oven to a natural gas, you actually first of all need to buy from the supplier an orifice ment for natural gas and change. The difference in the orifices could be in the size of orifice aperture.
The orifice i'm talking about is located in the burner assembly. you got to dis assemble the burner so as to get to it.
After that you need to adjust the main gas manifold when the oven is on. The adjustment must be done such that the pilot flame is not yellowish
Jan 28, 2014 | Lincoln Ovens
Tip
Changing your gas appliance from natural gas to LP or vice versa.
You have an LP gas stove which you really like and would like to take to a new home but the new home has a natural gas hookup. Since natural gas is already available it would be convenient to be able to use it. Can you convert your unit over to work on natural gas?
Yes it is possible to convert any LP gas appliance to natural gas or from natural gas to LP. The only difference is the size of the orifice used in the burner.
LP gas is composed of a much larger molecule than natural gas and requires a larger orifice to output the same amount of gas as a natural gas unit at the same setting. Therefore if you used an LP stove on natural gas it would produce too much heat and burn rather intensely. If you used a natural gas stove on LP it would not have much flame at all. You can see the problem. The solution is also obvious. You need the correct orifice.
Changing the orifice is easy. It is located in the middle of the burner and unscrews out of the unit. Install the new one the opposite way. Do not overtighten it.Usually the burners are made of soft metal and can strip easily.
The parts you would need are available at most good appliance stores but I would recommend the following site http://www.repairclinic.com . The parts will be cheaper at repairclinic. They have parts for almost any brand and a great search engine. They also have excellent videos showing how to make the repair.
Thanks for using FixYa and for the great rating.
hardrocko
on Dec 10, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Convert LP Lincoln oven Impinger II series 1700 to natural gas series 1600
Yes. You need a set of natural gas orifices to replace the LP ones on the oven and all the burners too.
Jan 28, 2014 | Ovens
Convert from natural gas to lp
You can purchase an LP kit and install it on your burner
Nov 25, 2013 | Magic Chef CYG3004AWW Gas Dryer
I would like to convert a grill that was used on natural gas back to propane. Can I just purchase a regulator and hose and be good, or do I need to change anything else on the grill?
Burner orifices must be resized or adjusted to accommodate higher pressure LP.
Air shutters should be opened all the way to allow maximum air to gas ration.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 14, 2011 | Barbeques Galore Capt'n Cook 3-Burner...
BOUGHT A BRINKMANN 2545 GRILL LAST NIGHT. WE HAVE IT ATTACHED TO GAS LINE COMING FROM HOUSE. GRILL WILL LIGHT BUT IT IS A LITTLR FLAME AND THE OTHER BURNERS WILL NOT LIGHT?
If you have a high pressure 2lb LP Gas System feeding your house, you will need and inline regulator for you grill.
If you have Natural Gas, the grill will have to be converted to Natural Gas. You can do this by changing burner orifices. You can purchase them from Brinkman. That is, if Brinkman approves the change to Natural Gas. Some gas grills aren't convertible.
Feb 09, 2011 | Brinkmann Grilling
Need instructions for Natural Gas to LP Gas for GE Dryer
You can get the conversion kit. It will tell you how to convert the dryer. I recommend that you get a technician to do it though.
This gas dryer is equipped with a Valve & Burner Assembly
for use only with natural gas. Using conversion kit
WE25X0217, your local service organization can convert
this dryer for use with propane (LP) gas. ALL CONVERSIONS
MUST BE MADE BY PROPERLY TRAINED
AND QUALIFIED PERSONNEL AND IN ACCORDANCE
WITH LOCAL CODES AND ORDINANCE
REQUIREMENTS.
Good Luck and Please Rate FixYa!
Jan 19, 2009 | Dryers
Convert from lp to natural gas
you need to change the gas regulator (if installed on back of oven),pilot and burner orfice your ready to go.happy new year.
Dec 05, 2007 | Magic Chef CGR3742 Gas Kitchen Range
Low flame
so you stove was converted from natural gas to LP using WB28K10043 KIT-CONVERSION L.P. ? is this correct?
Aug 23, 2007 | Hotpoint RGB745 Gas Kitchen Range
Kitchen Ranges Logo
105 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
