Question about GE JTP15 Electric Single Oven
JTP15 Oven - Shuts down after preheating
Oven is 5 years old and gets used about twice a month! After the oven has reached temperature, the oven will shut down and power cycle.. the display goes blank and then comes back on and I have to reset the clock.
I have already replaced the control module behind the front panel, and I get the exact same result. Is it the oven sensor? Surely it's not that easy! Okay, I know.. don't call you Shirley... :-)
Any help out there? THANKSGIVING IS COMING FAST!!!
  • JDrew Nov 03, 2007
    Thanks for your fast reply..
    The exact model number is JTP15B0D1BB.
    I just tried the HI Broil, and it did the same thing after about 10-12 minutes. Power cycle. The display goes blank, then all digits light up, and the control module resets.
    Looking forward to your reply!
  • 290 Answers
It sounds like the module is momentarily losing power when the bake relay clicks off. Does it do the same thing when you use broil?
Post back with the complete model number and I will try to find the wiring diagram for it and we will walk through checking it.
Posted on Nov 03, 2007
  • Michael  Lindley
    Michael Lindley Nov 03, 2007
    I can tell you that the temp sensor should not cause this problem. It only changes resistance as it heats up, the board senses the change of resistance and converts it into the temperature and tells the relay to open or close. The only way I could see the sensor have any effect would be if it was shorting out at a certain temp, but the control should sense the short and give you a code. It normally would stay shorted also and you wouldn't be able to reset the oven. However, I have seen stranger things happen. The sensor is only about $15-20, so it would be worth a try.
    The obvious answer would be the control has a bad solder joint on the transformer. Since you have replaced the control that doesn't seem to be the problem, but it still could be.(more on that in a minute)
    I have the tech manual for the 14 and 16 series but not the 15 but they should be the same.
    According to the parts list for your oven, the transformer is mounted on the board, so we need to make sure all the wires are on the correct terminals. If you have changed the control you probably found the tech sheet in the top of the oven. Go over it and make sure all the wires are on the correct terminals as indicated by the lettering on the board, don't depend on where they were on the old board.
    Some of these ovens had a separate transformer with wires going to the board. I don't see this on your parts diagram, but if by some chance it does, you probably have a bad connection at that plug.
    If all this checks out ok, you would want to check the neutral wire to the control. The elements will work fine without a neutral connection but the control has to have it to work properly.
    If this is not the problem, that leads us back to the control. It is not unheard of to receive a new faulty control board, especially if it is a rebuilt board. The problem you have is one that would be overlooked by the rebuilders unless they were looking for it specifically. I have a GE oven about 2 yrs older than yours and put 3 controls on it before I got one that worked properly. They all gave the same failed sensor code but only every 10 hours. Oven worked fine other than that. I would shut power down and back on and 10 hous later the F2 code would pop up. Third board fixed it, four years now with no problem.
    Post back with what you find out or any questions.
Kenmore oven shuts off before preheated
On any gas appliance there is a high and a low limit temp stat which could be indipendant or on the gas valve it's self, that is faulty.
When the oven reaches temp, it cuts out. sounds like faulty over heat stat.
Mar 21, 2014 | Ovens
I have a KitchenAid Superba KEMC308KSS0 that is about 9 years old. In the past few months it has been cooking really slowly. Whereas in the past, in convection mode, things cooked faster than...
I have a Superba built-in YKEBS 177 D56 ( dual convection/convention)...I think it might be about 10 years old. I noticed the same thing starting last year..the temperature seems a litlle off and the cook time on the convention seems to take longer. I've never used the conventional oven so I don't know if the temperature is OK on that component.
I don't have a manual. and I've been searching for it...does anyone know which one I need?
Sorry I couldn't help with your problem, mine is similar to your though!!
Jan 22, 2011 | KitchenAid KEMC308K Double Oven
Kenmore gas oven does not reach operating temperature
If your oven is 20 years old the temperature sensor system might no longer be accurate, if you have access to a temperature measuring device that can confirm that the oven is not reaching 350 then run it up and check that its not just your indicator light system. Some oven burners have air control and yours may have accumulated oven soil over the years. If your burner. Is behind a short wall like mine is, use a mirror and torch to check. A clean can bring things back to standard. Flame heat is from a good mix of. Gas and Air...
Dec 05, 2017 | Kenmore Ovens
JTP15 GE Oven - vibration noise
We have a double ge wall oven. The vent fans had become really loud. I checked the price for new fans...$275 each! Plus service of $200. If your oven is not too old, go to GE service purchase a 1 year service contract for $93.00. Wait one one month till it takes effect. Call them and request service and the entire replacement is free.
Jan 14, 2009 | GE JTP15 Electric Single Oven
GE JTP15 oven shuts off
Mine was doing the same thing all day today. All I know is when it was cool I lifted up a bit on the lower burner an inch or so, and set it down. Next thing ya know, you guessed, it, it's working again...Not sure what's doing it, will keep checking for a solution.
Jun 10, 2008 | GE Profile JTP18 Electric Single Oven
GE JTP15 Electric Single Oven Logo
493 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
