Question about Frigidaire Freezers
Door dose not close right becuse the stainless steel plate in front of the hinge on the bottom of the freezer looks out of place and twisted what can I do to fix it. Can you send me a repair manul
    Sergeant:
  • 340 Answers
I would google manufacture and try them sounds like the hinge is bent maybe take it off and try to straiten. you'll need a vice. good luck
Posted on Jun 21, 2009
Good day! The center flap (vertical hinged flap) no longer rotates back in when closing the left door. Result: the flap remains "out" when closing the door thus banging up against the right door.
Their is a factory issue on some models call the factory to see if your unit is a defective unit. Other wise the door flap has to be replaced. Not cheap..
Oct 30, 2015 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
When I open the refrigerator the freezer pops open
I appreciate your inquiry, Tammy McAninch!
Based off the information you have provided your Frigidaire freezer door pops open when you open your refrigerator door. This can happen with new refrigerators because the seal is new. I understand your question is labeled under model FGHB2866PF. It could be issues with your door not aligned properly and hitting your freezer door to open. I would check the gasket to make sure they are creating the proper seal on your freezer in order to check that you can use a dollar bill. Place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then replace the gasket. If you continue to experience issues with your freezer door I would recommend reaching out to a professional for further assistance. I hope this information helps to some degree. -Matt
Nov 17, 2014 | Frigidaire Gallery Series FGHB2866PF 27.8...
Freeze's on bottom 12' on top 40'
Hello Paul Rorrer, thanks for your inquiry!
I see that your question is listed under Electrolux freezer. Please help me understand the question you are asking. Is it freezing on the racks? Or is there a frost buildup? I would recommend turning the temperature down to help alleviate some of the cold air building up inside of your freezer.
Additionally if there is a frost buildup I would recommend checking your gasket to see if it is in good condition. You can do that by using a dollar bill. Place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then replace the gasket. If you could provide me any more information I would be happy to assist you. -Matt
Sep 25, 2014 | Electrolux 21.0 Cu. Ft. Upright Freezer -...
I have a frigidaire stand up freezer model #lffh21f7hw, and the door isn't vacumn sealing the door, why?
If you have too much weight in the door or someone pulled down in the door, it gets twisted. Try lifting up on the bottom outside corner of the door to straighten it up. You might have to loosen the top hinge to reseat it.
Jan 17, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have a kenmore upright freezer model 970-254326 bought in 2011 from sears. The door opens left to right but in my tiny apartment I NEED it to open from right to left just to put things in and get th
You should see some plastic plugs or holes for mounting bolts on the opposite side of the freezer case. The latch mechanism should adapt from one side to another.
You would remove the top hinge and then lift the door off of the bottom hinge. Then you would remove the bottom hinge and switch it to the other side. Place the door onto the bottom hinge and then install the top hinge on the other corner of the case to match.
You should be able to move the handle from one side to the other. The magnets in the doorseal should work as before to keep the door closed. The interior light is usually centered on the bottom to aid in reversing the door opening.
Dec 30, 2011 | Kenmore Freezers
Food is not completely freezing in spots
This is a symptom of air leaking into the freezer. The most common place is around the door. Check the door really good to make sure something is not obstructing it from closing all the way, it may be closing enough to satisfy the ajar alarm but not enough for a bit of moisture to sneak in. Look for tears or breaks in the seal. If you put a bright flashlight inside the freezer and close the door, turn off the lights in the room you may find a leak that way.
May 03, 2010 | Electrolux 21.0 Cu. Ft. Upright Freezer -...
Freezer door has a gap in the middle. Seal doesn't
Put a long straight edge on the door to verify a warp. A 4 foot level is good for this test.
If the door is in fact warped. You should pull back on the seal,loosen the screws behind the seal holding the door liner in place,adjust the door to the straight edge and re-tighten the screws.
If the straight edge does not show a warped door,take a hair dryer and heat the seal where it is off the frame. Do this with the door closed and you will see the seal relax and touch the frame. Let it cool in this position before opening the door again.
If neither of these is the cause,loosen the door hinge and re-adjust the door position,then re-tighten the hinge screws.
Feb 13, 2010 | Frigidaire 19.53 cu. ft. Commercial...
Re: danby upright freezer 20.1 cubic ft., model #
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Oct 13, 2009 | Freezers
Will not seal. new from sears.
The description below is for a gap at the top of the door. Adjust the procedure for gap at bottom by "twisting" the door in the opposite direction.
I'm assuming you don't want to replace the door seal. Open the freezer door. Stand "inside" the open door and place your foot at the right bottom corner (looking from the inside). Place your hand in the top right corner and pull it very slightly toward you. Do this in small amounts until the gap closes making sure you don't open one at the bottom.
An alternate method is to warm the gapped section of the door seal with a hair dryer to soften the rubber enough to allow the magnet within the rubber to pull the seal gap closed. This has worked for me numerous times by making small adjustments at a time. Good Luck
May 06, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezer door won't close at top
If you are careful, open the door 90 degrees and place your leg against the bottom corner inside of the open door and your hand at the top corner, then GENTLY push inward. You should be able to feel and see the move or twist. Then close the door to test for proper sealing. Another way to adjust the door is to loosen the screws behind the door seal and twist,but this usually unnecessary if you do the leg trick properly.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
http://www.repairclinic.com/0100_34.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 16, 2008 | Freezers
Freezers Logo
35 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
