Question about Mitsubishi WS-55809 55" Rear Projection Television
TvV won't turn on....
I turn my mitsubishi ws-55809 on it makes one tick sound green light turns on for about 2-3 sec then turns back off with a tick sound. We tried looking at the capasiters but they all look fine. Is there any other solutions for this problem that i can fix myself???
  • 3 more comments
  • gahoffmanski Nov 10, 2007
    MI have the same model - exact same problem just started today.
  • elfernys Nov 17, 2007
    how can I get a manual for it
  • Anonymous Nov 28, 2007
    My Mitsubishi green LED lights for about 2 seconds when powered on then goes out. I hear the relay pull in then drop back out.
  • satdude Dec 02, 2007
    I press the power button and the green light comes on for about 2 seconds and hear a clicking sound. Unit will not power up
  • hotrod67 Dec 09, 2007
    We are having the same problem. Press Input and Menu for 5 seconds. The green power light will flash a code. Mine was 23. I did the code thing today. Now I need to find out what the code means.
Does it have a lamp like the lcds
Posted on Nov 17, 2007
Mitsubishi big screen HD 1080 series model WS-55809. it switched off one day. and when i turn it back on it switches right back off. red light in front. what part do i need to fix it/
That model does not have a red light---Green.
If set powers up for a few seconds (green power light) and goes out do the self check the model indicated has:
On front of set (not with remote) press and hold both the input and menu buttons for at least 5 seconds and release both.
Green power light will blink a two digit error code like 2 blinks, 2 blinks a pause and repeat it several times.
Let me know what error code you find (if you have unplugged the set that will clear all errors and you have to plug it in and try to turn set on again---when it fails do the self check)
Mar 31, 2012 | Mitsubishi WS-55809 55" Rear Projection...
Iris not working
If no sound or picture does the green power light (based on model number WS-55809) come on when you turn set on and a few seconds later go out?
Mar 21, 2012 | Mitsubishi WS-55809 55" Rear Projection...
My HD 1080 WS-55809 won't turn on - little green light comes on for 2 - 3 seconds, then nothing. It was fine - we were watching a DVD but had it on pause - the tv turned itself off - then it won't turn...
Hi
Thanks for using FixYa. Error code 2-2 means short protect which is either caused by bad convergence ICs and/or 2 Pico fuses (F9A05 and F9A04). You’ll need to open the back of the unit and replace the parts that have gone bad to resolve this issue.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Just bought this used Mitsubishi WS-55809 and when I turn it on the pic. is all messed up. The write is deformed looking and all the words are repeated 3 times. I hit the back of the TV and the pic. and...
Sounds like you have some solder problems on your deflection board. If you're up for it, you could fix that yourself with some solder and a soldering iron. Just take the back off, and look for the board with 2 of these on it (numbers may be different).
Remove the board carefully noting where you unpug things (take photos if needed). Then reflow the solder joints on these parts. I hope this was of assistance, best wishes.
Mar 29, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55909 dm board repair
The DM is fine if the led isnt blinking. Your set is going into protective shutdown. Try pressing the menu and the device/input buttons on the set both in together for 5 seconds to see if the set will blink a series of blinks pause then blink another series of blinks. Such as 2 blinks pause then 2 blinks, Then let me know what the blinks were and I will assist you with whats wrong
May 28, 2009 | Mitsubishi WS-55809 55" Rear Projection...
My tv ws-55819 tv won't turn on it cliks on but it won' syat on
ok when the power is plugged in hold down the menu + device buttens for five sec what is the error code there should be two sets of numbers....
like 1 pause 2 let me know and i'll see what i can do!
Feb 01, 2009 | Mitsubishi WS-55819 55" Rear Projection...
I have a mitsubishi 48" integrated 1080. The Timer green light keeps blinking. I have no picture. Can this be the fuse? My coworkers say this might be the problem. Can I replace it myself? If so, where is it located?
meeh.shell@yahoo.com
Oct 13, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Blinking green light
Please verify Model # and mo / yr built off back of set...
critical for correct solution........T.
Dec 02, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
83 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
