Fan in the oven cut out but oven stayed hot then after about 10 minutes it started working again never noticed that it has done that before
SOURCE: Fan oven stays warm
is the fan working when oven is staying warm? possible fault if you don't have an earth trip is a short to earth on the neutral side of the element
SOURCE: Problem with main fan oven - electric
there is an overheat stat and this is operating and cutting out the oven. the causes are several but here are the main things to look for: oven stat is faulty causing the oven to overheat. you should check over the range to see if stat is reasonably accurate. overheat stat itself is faulty. there is another stat which turns on the casing fan. (this is the fan which is out of sight - not the fan inside the oven) if this stat is faulty and not turning on the casing fan, then the overheat stat will operate. the casing fan is faulty or jammed. lack of ventilation. see if you can narrow it down a bit and get back to me if you wish
SOURCE: electric oven fan
This problem is caused by one of two components, depending on the model, there is a thermal cut in thermostat that keeps the fan running until the unit has cooled down and on some models there is a four wire timing device that keeps the fan running for a specific time after the temperature drops, the fault can only be casued by one of these components. Smeg Service Engineer
SOURCE: Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
SOURCE: Oven cuts out after about 15 minutes
most common fault is the cooling fan is failing to come on, whreas the fan will be okay ( check windings with ohmn meter ) it will normally have a ceramic 10k resitor in series with the live which goes open circiut
