Question about Dishwashers
I have a Belling IDW604 dishwaher just installed in my kitchen. Have only used it a couple of times and have noticed quite a lot of water left in bottom when program has finished. If I then do a quick rinse program the water will disappear. Is everything ok?
    Problem Solver:
  • 5 Answers
There should not be water in the bottom. It's possible it's not draining completely which usually means a clogged hose. It can also be there is something under the screen filter that has blocked the hole. Also, I had installed one that didn't drain completely because the drain hose was not high enough. It should be higher than the dishwasher, and if they installed it under the cabinets and attached to the sink drain, the entry must be above trap. I hope this helps some.
Posted on Jun 20, 2009
I have a belling IDW604 integrated dishwasher which is not heating the water
An open element will have voltage present and still not operate. Use an ohm meter to test it.
Dec 21, 2015 | Belling Dishwashers
Belling IDW604 wont heat water
Check heater for continuity, thermostat and control timer
May 09, 2012 | Belling 24 in. IDW603 Built-in Dishwasher
Belling idw604 not filling with water, any ideas??
If you can test the supply voltage to the inlet solenoid it may have failed, if it has voltage as required and it is not letting water in the solenoid it's self will be at fault.
Mar 12, 2012 | Dishwashers
E4 is displayed on my belling idw604 dishwasher and it won't operate
unplug machine. remove right hand side panel. check if water has collected in the bottom tray, if so soak up with cloth or kitchen roll until all water has been removed. switch on power and machine should have reser
Feb 07, 2011 | Belling Dishwashers
Idw604 error code e4
had same problem. Tilt dishwasher to the left and drain all the water (it will come out on the side). That's E4 solved. Now turn it on, E4 should not light up. If it does, turn it on and as soon as u do this, close the door. This won't activate the Trip Switch but will automatically turn the pump on. Good luck!
Aug 02, 2009 | Belling 24 in. IDW603 Built-in Dishwasher
Belling idw604
The E3 code is normally related to the overheating of the water during a wash. There is a thermal swith that has a manual reset button mounted on it. The button is normally red in colour and is about 3mm in diameter. REMEMBER TO SWITCH OFF THE POWER BFORE ATTEMPTING ANY REPAIRS. The switch is accessed by removing the silver plate mounted beneath the door. The plate is secured by 2 phillips screws. The switch, black in colour, is mounted to the left and is about 10cm in from the front of the machine. Simply press the red button to reset. This should solve the problem but if the problem persists I suggest you call an engineer.
Jun 27, 2008 | Belling 24 in. IDW603 Built-in Dishwasher
BELLING IDW604
i have just fixed my e4 code problem
take off salt cover and remove all water with tea towel or dish cloth you must make sure all water is out switch off at wall then back on if still e4 reapeat getting water out my washer is cleaning as i type
Dec 01, 2007 | Belling 24 in. IDW603 Built-in Dishwasher
Instruction book
need the manual for the belling idw604 dishwasher
Jul 04, 2007 | Belling 24 in. IDW602 Built-in Dishwasher
Dishwashers Logo
201 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
