Question about Miller Welding Tools
225 thunderball,has no plug cord,need to know where to hook incoming cord inside welder
    President:
  • 1,388 Answers
The following link will provide you with information about a 225 thunderbolt. We have serviced many Miller welders over the years and find them to be very reliable. Good luck with your project.
http://www.millerwelds.com/om/o316g_mil.pdf
Posted on Jun 23, 2009
How do I hook up the power chord to my ac lincoln stick welder
If you're talking about an AC 225 "Cracker box", the cord attached directly to the power switch and grounds directly to the chassis of the machine. Take care when removing the cover screws as not all need to be removed. There are one 5/16" screw in the recessed area at the back of the machine, two directly under the recessed area, and 2-3 3/8" bolts at the bottom rear. When those are removed, the machine will tilt front/backwards... That's normal. It's been a while since I opened one of these up. Hope I remembered the screw positions correctly.
When you remove the rear cover, you'll see the switch and how the old cord is attached. Good luck.
Oct 01, 2014 | Lincoln Electric K1170 AC-225 Stick Welder
Lincoln Arc Welder AC 225 Wiring Diagram
won't have reverse polarity. There are only 3 wires, 2 power and one ground. It does not matter what power lead goes to what side.
Apr 19, 2012 | Lincoln Electric K1170 AC-225 Stick Welder
My AC 225-S welder is missing the wiring diagram. The cooling fan wires are pulled apart. Need to know if the fan is 110 or 220 and where to put the wires back. Billy Lynch
Fan Motor MOTOR
2910.0
230.0 AC
Here is a Picture of the wiring Diagram that should be on the inside of the rear cover If this is hard to read Here is a link to the original
Jun 27, 2011 | Lincoln Electric K1297 AC/DC 225/125 Stick...
How di i wire my 225 ark welder came without a plug
I'm assuming the cord is there and it's the flat 3 wire type. The center wire is the ground and the other 2 are the power. It doesn't matter which power wire goes on which blade, they are both the same.
Apr 09, 2011 | Lincoln Electric K1297 AC/DC 225/125 Stick...
I have a lincoln 225 welder and when you plug a grinder or band saw into it and you lay the band saw on a metal table beside the welder after your done using it it arcs on the table, and a grinder does the...
the first thing with this situation is be vary careful this can KILL,
insure that the ground contact to your welder is of good quality, you might have a voltage induced in the metal frame of your welder by the large transformer(inductor) used to modify the voltage/current to a value you can weld with, with a good ground this will not happen, if the ground contact is poor, and you repair the contact, plug it in and it trips the barker, your welder is faulty by way of the primary coil in the inductor contacting the metal body of the welder, this is not worth repairing, also look for any wires that may have worn off its insulation and are contacting the mettle frame of the welder, a good ground will save your life, insure that all your power tools that have a 3 wire cord have a ground contact. good luck and always be safe
Apr 28, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
I just got a Lincoln ac 225 welder , IT came with no stinger cable or no ground leads I NEED to know were to hook them on the inside?
the stinger is bolted to the amp dial inside the unit,there should be a ground terminal for the ground in same area.
Mar 07, 2010 | Lincoln AC-225 230V
Need the diagram for an old welder, ac/dc 125/225 need to find out how to hook the fan up
Usually the fan if it is, 112/225V. It simply connects across the Line, Phase to neutral, but AFTER the mains switch. So that it is "On" only after the Power has been switched on.
Feb 10, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Welder doesnt turn on...
Have you connected the feed from your breaker box to ADJACENT lugs on a dual pole breaker? By code you must use a ganged breaker.
You should use a voltmeter to verify the plug is getting power on teh desired pins.
Sep 25, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
ARC 225 - Can't hear fan.
sounds like you lost one leg of power to the unit,check power source and the the plug on the welder.
Jul 30, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Welding Tools Logo
140 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Robert Monigold
Robert Monigold
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
