Question about Orion1934 19" TV
AUX 1 Screen - Orion TV
Orion TV Model No: STV255A - 2001 model
The TV is stuck on AUX 1. The universal remote (RCA) can only turn the TV on and off and manipulate the volume. To access the menu I have to press the up and down volume controls at the same time. I can move through and adjust certain menu options (picture, audio, language, and v-chip) by moving the up and down volume keys but I cannot adjust the set channel option. I've checked the back of the TV and everything is hooked up the way it's always been (cable connected to DVD player then connection running to TV). Previously, the TV made a slight buzzing sound, but I don't know if this is related. Everything else was fine.
MikeNJ1964
  • 398 Answers
SOURCE: orion tv model 1934 only 3, 4 and aux no pic or sound!!!!!!!!!!!!!
Turn the set on, hook the cable directly to the TV, take the remote control and press 1 - 1 and if the TV tunes in channel 11 then your set is fine. If the TV was autoprogrammed when hooked to a cable box then the only channels that will be stored in memory are 3, maybe 4 and AUX. To correct this simply go back into the menu and look for the "autoprogram" option and perform the autoprogram while the cable is directly connected to the TV, without a cable box.
Posted on Jul 29, 2007
Vrya
  • 62 Answers
SOURCE: Orion model 1929
Hiii...
Mightbe you can buy a universal remote on the market what support your tv set ?
Than's
[Vrya]
Posted on Feb 23, 2008
SOURCE: Orion TV1926A: Problem hooking up dvd player/Input screen won't come up
try to switch to aux1 or aux2.
Posted on Sep 26, 2008
h_leslie
  • 27 Answers
SOURCE: I lost Orion 13" Model TV1318 remote.Need to menu button access
you can purchase a advanced universal remote or you can go through the menu manually on your set
Posted on Dec 17, 2008
  • 541 Answers
SOURCE: orion tv/vcr combo 1921 model with a phillips
These sets don't like universal remotes. It's almost like Orion made them this way. Try this tip http://www.fixya.com/support/r387655-orion_tv_remote_code_here .
Posted on Oct 15, 2009
Need sansui 076k0ut011 led tv remote codes to program an rca tv
reset sansui tv remote control 076k0ut011 Questions ... - Fixya
www.fixya.com > Forum > Tags
...your help in advance. need code for a one for all URC-2060B06 sansui tv try these ... ...sansui tv with a RCA 704 remote control I have sansui tv and a RCA 704 remote ... URC-3021 Remote Control: How do i program this remote to a sansui tv? ... TV Remote Controls Sansui Remote eBay NEW Orion Sansui JVC LED TV ...
reset sansui tv remote control 076k0ut011 Flat Panel ... - Fixya
www.fixya.com > ... > Tags > reset sansui tv remote control 076k0ut011
Flat Panel Televisions reset sansui tv remote control 076k0ut011 questions and answers. ... ...sansui tv to program rca remote to it model # HDLCD1955C need tv code for this model ... Question about Contex 39-inch 1080p LED TV LE39D3.
Original Sansui - Orion TV Remote Control 076K0UT011 ...
? 1:00
https://www.youtube.com/watch?v=mPbRsUI0xnk
Dec 21, 2012 - Uploaded by ElectronicAdventure
Original Sansui - Orion TV Remote Control 076K0UT011 - Save $5 with ... have the New Original Remote ...
[PDF]Operating Instructions For 4-Function Cable
Dec 16, 2015 | RCA Televison & Video
I need a code for a RCA universal remote and a SEARS tv.
RCA
HI,
Direct Code Entry:
Find the code your device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3. Enter the 3-digit code number.
4. Release "CODE SEARCH".
5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.
follow the below steps to set remote without codes
Code Search:
1. Turn on the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7. Try using the remote. If it does not function repeat steps 1 through 6
To Get The Code Please Go To Below Website:
http://www.rcaaccessories.com/remotefinder/
You need to select the following information from the drop down list
1.Model of the remote
2.Type of device to which you want to program(TV/DVD/VCR)
Thank you
Mar 13, 2011 | RCA Televison & Video
RCA Universal Remote Code For A Trinitron Xbr Tv
There are several RCA universal remote models. With out your specific model # I can only give you the most common code. 002.
You can also try the steps below to use the internal code search mode if your remote has this feature.
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Oct 23, 2009 | RCA Televison & Video
RCR451
Orion TV; 1030, 1035, 1191.
Emerson VCR/DVD; 2142/3391, 2148/3403.
Dec 16, 2008 | RCA Universal Remote Control
Help with codes
Code For Model RCU404
Code 030 for Orion TV Code 035 for Orion TV Code 191 for Orion TV
Nov 11, 2008 | RCA Universal Remote Control
Can't get TV onto the AUX channel
You can purchase an RCA universal remote that will let you access the A-V inputs. These only cost about $10.00 or so. Stargazer
Sep 09, 2007 | RCA F25254GY 25" TV
TV stuck on AUX
unplug the tv then plug it back in the wall
Aug 30, 2007 | Orion1934 19" TV
Orion tv model 1934 only 3, 4 and aux no pic or sound!!!!!!!!!!!!!
Jul 29, 2007 | Orion1934 19" TV
Orion1934 19" TV Logo
108 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
