Question about Bosch MUZ7MX3 Blender
Removing drive shaft for a bosch mixing bowl
I need to remove the drive shaft from a Bosch universal mixing bow. It appears that the cross pin should be removed first. However the pin is stuck tighter than old ****'s hatband.
You can see a detailed assembly at https://www.pleasanthillgrain.com/replacement_parts_bosch_univ.aspx#bowltabs
2 Suggested Answers
SOURCE: We have a Bosch Universal Kitchen Machine that is
I found manuals on the Internet!
Posted on Feb 09, 2010
I need to replace the Beveled Gear for my Pro 600 mixer. it seemed an easy task. However, I am stuck in removing the Beveled gear. I cannot remove it after removing the retaining ring. help pls.
If you have the gear cases apart and the bevel gear exposed then you just push the planetary shaft up through the middle of the bevel gear. You will see that the shaft is driven by the gear via a loose fitting pin through the shaft. Pull the pin out (with fingers) and then the bevel gear will lift up off the shaft without the need to fully remove the shaft. Note the fibre spacer/thrust washer under the bevel gear between the bottom case and gear, don't lose it.
Aug 08, 2016 | KitchenAid Professional 600 6 Qt. Stand...
Tip
Failure of grinding, blending, or mixing kitchen appliances
Generally, a blade or grinding or blending/mixing part that is permanently attached to a metal shaft from the appliance motor is held on that shaft by a 'shear pin'. This pin breaks when something is put in the appliance that the grinder, mixer, blender can't gring, mix, or blend. This is to protect the motor from overload. Afterwards, The motor will continue to turn, but the blade or paddle, or whatever will not turn.
The shear pin needs to be replaced.
The shear pin passes through one side of the base of the bade/grinder/paddle assembly, through the motor shaft, and out the other side of the blade/grinder/paddle.
The piece of the pin must be removed from the shaft, and from the two sides of the blending/grinding part. This is generally a press-fit, and some effort may be required to accomplish this.
When the pieces have been removed, a common 'roll pin' of the appropriate diameter should be inserted to hol the turning part on the shaft. It must fit tightly, and some effort should be required to insert the new pin.
on Feb 07, 2010 | Blenders
Any ideas how I remove both the mixing bowl & blade that won't release from my hardly used (maybe 10x's) Kitchen Aid Food Processor?
It sounds like the blade has become jammed on the motor shaft sleeve. You will be up for a new blade and motor shaft sleeve to sort that out. They are not expensive and it is the only proper fix for them. If you replace nothing it will happen again pretty much straight away and if you only do one the other damaged part will wreck the new part. To solve the not turning on problem which is a separate issue it will very likely involve replacement of either the bowl or the lid. One is as likely as the other, I have both parts in stock so I try one or the other to decide which one is the problem. Getting the blade off is a real chore, I have a small chain (with welded links so very strong) I put a couple of turns around the big blade shaft and fix it there with a shackle. It's about 2.5 meters long so I attach the other end to the leg of my bench and accelerate the motor unit away from the bench. The chain comes tight and shocks the blade off. I then drill a hole through the motor shaft about 8 mm from the top, attach the chain to that with a shackle and shock it off just like the blade. New parts now and job done.
Nov 20, 2015 | KitchenAid Kitchen Aid KFPW760WH - 12 Cup...
How do I remove the little pin at the base of the shaft so I can attach new rubber drive
That is a roll pin and you need a punch the size just smaller that that little pin. Then you can just tap it out with the punch and a hammer. Remove the drive and replace and tap the pin back into place to hold the rubber drive.
Nov 12, 2014 | For Your Kitchen Bamix Professional Stick...
Kitchenaid mixing shaft falls out w/ use
If it is model 5KPM5 then there is a pin through the shaft inside the planetary that engages the pinion gear. There is a circlip above the gear clipped to the shaft that holds the gear into engagement with the pin. I've not seen one drop the shaft out in my life, the circlip would need to pop off & the gear would need to jump up and then the pin would need to slide out. All the bits would be there inside the planetary waiting for you to discover them.
Nov 16, 2012 | KitchenAid Professional 600 6 Qt. Stand...
My blender won't blend. Everything turns but the blades.
I have no idea what might be turning, but likely you do not have the blades seated if the shafts don't turn... IF the shafts turn, the welds or swaging of the baldes to the shaft have probably come loose due to overloading.
Apr 07, 2010 | Bosch Blenders
Can't get drive coupling off bosch unversal blender blade fixture
what you need to do is hold the blades with a towel to protect your hand, then, use a visegrips needle nose to grab the coupling (pushing the guard down) and twist it loose. It may be very tight, when I loosened mine, the plastic portion of the coupling pulled off leaving the metal "nut" tight to the shaft. Either way, remove the coupling/nut in the standard "lefty loosey" direction. Many thanks to the people at pleasanthillgrain.com for walking me through the process. Blessings to you.
Mar 23, 2009 | Cuisinart SPB-7 SmartPower Work Top...
The plastic base of the glass jug is broken, need repacement.
I used a 4" stainless steel hose clamp as ours was cracked but not in pieces. So far it has worked.
Nov 11, 2007 | Bosch MMB2000 Work Top Blender
Bosch MUZ7MX3 Blender Logo
67 people viewed this question
Top Bosch Blenders Experts
eyecam
Marvin
Marvin
Ross Keen
Are you a Bosch Blender Expert? Answer questions, earn points and help others
