I have my computer set to automatic updates but the updates from Windows Vista will not install. is there a program that will repair Vista updates ?
Here is a helpful Microsoft Knowledge base article that should help! Install Windows updates
I’m happy to help further over the phone at https://www.6ya.com/expert/adrienne_b03fb46fc6334991
SOURCE: WINDOWS UPDATE WILL NOT WORK IN WINDOWS VISTA HOME PREMIUM
Hey try to do this now
1: Open up "Control Panel" and navigate your way to "Programs and Features".
2: Click "View installed updates" on the left hand side.
3: Find the update KB929777 and uninstall it.
4: Attempt to install the update again in Windows Update
5: Once successful, restart your PC.
and if it works thats good but if it ddnt let me know plz
SOURCE: Cannot upgrade windows vista home premium from disc
Check the programs that vista says it can not update. They may be incompatible with Vista. You can find this out by running the Windows Vista upgrade advisor available for free at microsoft.com. If you really want Vista & can do without the offending programs you can uninstall them & then run the upgrade. Hope this helps & please remember to rate my answer. Thanks.
Go to the Start menu and select Control Panel
In the search box, type in "update."
Click on the link to turn automatic updating on or off.
Select from the available options including the time you'd like updates to be downloaded and whether you'd like to be notified and asked before downloaded updates are installed.
1. Go to Start button > All Programs > Windows Update.
2. In the left pane, click Change settings.
3. Select Install updates automatically.
4. Under Recommended updates, select the Include recommended updates when downloading, installing, or notifying me about updates check box, and then click OK.
5. Make sure you click Check for updates to make sure your computer has the latest updates installed. You might need to shut down and restart you machine after the updates are applied.
SOURCE: No Internet Explorer with Vista
You should reinstall Windows vista. But my advice is to update to Windows 7.
SOURCE: Security fix KB973704 for 2007 Microsoft Office
if you want to install your updates then first try to check whether the update settings are set to automatic updates or not.
if not then go to control panel > windows update and set auto matic updates. if it is already done then
try MSCONFIG
ie. start > run > type 'msconfig'
go to 'services' and check whether the windows update service is checked or not if not, check the box
click ok
then restart your pc..
