Question about NetGear WGT624 Wireless Router
ICANT CONNECT WITH MY NEW DELL NETBOOK WITH MY WIRELESS WGT624 CANT GET IP ADDRESS INSTALLED
  • Anand Gupta
    Anand Gupta May 11, 2010
    Please clarify the following: # Operating system on the Dell Notebook # Are you online when connected wired to the router? # Does any other wireless computer works with the wireless connection? # Are you aware of the security encryption of the wireless network? Please revert so that I can provide you a resolution!
  • 854 Answers
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field. Please click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. Click on Wireless Settings under Setup page.
5. Take note of the SSID.
6. Scroll down, look for the Security Options and check whether WEP (Wired Equivalent Privacy) or WPA (Wi-fi Protected Access) is selected.
7. If its WEP is enabled, copy the value of the selected Key number. If WPA is selected, take note of the Passphrase.
8. To configure the computer with wireless adapter, please consider the following:
Configuring the NETGEAR adapter and Saving the Profile
a. Open the NETGEAR Smart Wireless Settings Utility icon located at the lower right portion of your computer screen. It will then open the Settings tab.
b. Change the Network Name SSID to match the one on your router.
Tip: As an alternative to typing in the SSID, you can use the Network tab to view the available wireless networks. Double click on the desired network.
c. Click the Apply button to activate the connection.
d. Enter a name for your profile (e.g. NETGEAR to Home Network) and click the Save Profile button to store the current settings.
Note: The above procedure applies only if you are trying to connect to a wireless network with no wireless security.
If the computer is using Windows built-in wireless program to manage the wireless adapter, please follow the steps below:
For Windows XP Service Pack 1
a. Please right click on the Wireless icon on the right lower end portion of your computer. Then click on to View Available Wireless Networks.
b. Click on the Advanced tab.
c. Please delete all the preferred networks then click on OK.
d. Right click on the Wireless icon again and click on View Available Wireless Network.
e. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. The network key will be the Key or Passphrase you have copied from the router setup (refer to step 7). Please type in the Network Key and then confirm it.
f. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Network.
5. Select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. The network key will be the Key or Passphrase you have copied from the router setup (refer to step 7). Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use windows to configure my wireless networks" on the Wireless Networks tab. Please ask assistance from the wireless adapter vendor for configuration if using a proprietary wireless utility (non-NETGEAR wireless adapters).
Posted on Jul 10, 2009
I have a MiniDell Inspiron Netbook that will connect to the internet through a neighbor's WiFi, but will not connect through my own Netgear router. The router is working fine for 2 other connections. How...
You may want to do a reset on the router by holding down the reset button on the back of your router. That will reset and MAC address filtering or any other security that you might have turned on.
Mar 08, 2011 | NetGear WGT624 Wireless Router
Netgear wgt624 v3 problem,cannot go to any sites
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Let me know if you need further assistance.
Thanks for using FixYa.
May 27, 2010 | NetGear WGT624 Wireless Router
Im have trouble aquiring an ip address when I try to connect to my wireless router with my aspire 1 netbook. the router is a Netgear N 300 and I also have a dell laptop which has connected with no...
Try to use wireless, see weather you can connect to the router page or not, if can means you LAN port of the netbook problem.
But make your LAN for ethernet is enable.
May 10, 2010 | Acer Aspire One Netbook 8.9" Notebook
THERE IS AN IP ADDRESS CONFLICT WITH ANITHER
Identify the peripheral conflicting with the router and change the network address on one of the two. Their setup programs should give you the possibility to do so. The address should look like: 192.168.2.x
x ranging from 0 to 9
Aug 02, 2009 | NetGear WGT624 Wireless Router
I can't connect to the internet
Is the issu on the wireless connection or wired connection through the router. Could you provide the below information:
# Connect your computer directly to your modem and perform the following tests.
A. Click on Start—Programs—Accessories—Command Prompt.
B. In Command Prompt window, type in 'ipconfig' and hit 'Enter'. Note down the IP Address, Subnet mask & Default Gateway here. Also, mail us the same IP configuration.
Above information will help me provide u an accurate resolution
Jul 06, 2009 | NetGear WGT624 Wireless Router
I purchased a netgear router and managed to hook it up to my mac laptop, but when trying to get my dell desktop to connect to it, it bumped off the connection for the laptop. So I called and had it...
It sounds like you have your internet plugged into on of the LAN ports on the router along with the computers.
Check the IP address on the windows machine while it is connected and can get online.
On the Windows Machine go to
Start > Run > Type 'cmd' and click OK
After the command window comes up, type 'ipconfig'
If the IP address reads 192.168.0.X then it seems to be configured properly. Otherwise, reply back and we can troubleshoot further.
Apr 02, 2009 | NetGear WGT624 Wireless Router
My new laptop recognises my wireless internet but wont connect
Check the security settings and see if MAC Address filtering is on in the router.
Jan 03, 2009 | NetGear WGT624 Wireless Router
Need to re-network my netgear wgt624 router
Power off your PC for a few moments then turn it back on to see if it will get a new IP address and connect again to the router.
Dec 30, 2008 | NetGear WGT624 Wireless Router
Still can't connect
make sure theres no firewall running on your pc, sometimes the firewall blocks connects to the internet..
Aug 22, 2008 | NetGear WGT624 Wireless Router
Wireless connection
NETGEAR Technical Support Engineer 1. access 1st the router's setup page * open up a browser * http://192.168.1.1 or http://www.routerlogin.com/ 2. go to wireless settings under setup if you have a wireless phone at home change the channel of the router, make sure they dont have same channel 3. change the mode of the router to w/c your laptop's wireless adapter support (eg. b only, g only ) 4. try to change security option wpa instead of wep (make sure your laptop's adapter support it) 5. change SSID (note: if you've change the SSID of the router, remove the profile on your computer under preferred networks 6. change your passphrase 7. Disable Advanced 108Mbps Features 8. Disable Setup Access List (it can be found in wireless settings under advance) 9. upgrade firmware of the router * before upgrading make sure you backup the settings (go to backup under maintenance) * if latest firmware is installed * flush firmware (flushing it is just reinstalling even if the latest firmware is installed) 10. power cycle frequently (turn off for 10 seconds then turn it on again) 11. If all of these didnt work call your laptop manufacturer for help 12. call gearhead -> 1-888-615-3488 13. or call our technical support 1-888-netgear lucky if you got me ***caesar *** NETGEAR technical support engineer
Feb 13, 2007 | NetGear WGT624 Wireless Router
NetGear WGT624 Wireless Router Logo
1,268 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
