Question about Garden
My Cub Cadet LT 1050 will turn over, but will not crank up. The battery is fully charges and there is plenty of gas in the tank. I made sure the parking brake was on, the PTO was off, the choke was all the way out, throttle was at Fast and I was sitting in the seat and it was fully down.
  • 30 Answers
Check the fuel filter.
Posted on Jun 20, 2009
Mowing deck locks when engaged to mow so what could be the reason ?
is something under the deck locked up against the blades?
May 01, 2017 | Cub Cadet Garden
I have a Cub Cadet LT 10:45 I will try and you try to start it it won't turn like it's stuck or something what could be the problem
take the cover off of the starter and see if it is stuck to the flywheel. if it is not it may be a valve issue. (out of adjustment) assuming that the battery is fully charged.
May 21, 2016 | Cub Cadet Garden
Wiring diagram
I have a 2009 LT 1050. I acquired my parts and electrical diagram from Cub Cadet. Go to their website, follow menu's to find your manuals.
Aug 10, 2015 | Cub Cadet LTX1045 2009 and After Deck Belt...
How can I disable the reverse stop switch on a cub cadet Lt 1050
so you can mow in reverse ???
should be a switch in or around the transmission that could be unplugged. not saying you should, but could
this is if you have a hydro... a manual trans is different
Apr 26, 2015 | Cub Cadet Garden
Battery won't keep charge on lt 1050
I think the charging components/circuit is not working properly.
May 09, 2014 | Cub Cadet Garden
I have a cub cadet LT 1050. It cranks but is very slow even with a fully charged battery. It eventually starts. This has been happenning for awhile now. I noticed the other day that the solenoid was...
You might have more than one problem but I think I can tell you why it cranks slowly and draws so much current. Some of those cadets (like those with the Kohler Command 20) have a compression release mechanism on the cam which is intended to make that big engine crank easier. It disengages once the engine fires up via a centrifugal release on the (plastic) cam gear.If this part breaks, the compression release does not work, resulting in a lot of strain on the starter motor. Interesting design, bad materials. Sometimes the engine will start anyway but this is not a good idea to operate this way. Pull the valve cover. Look at the motion of the exhaust valve when you turn the engine by hand. It will look similar to the motion of the intake valve if this part is broken. If it's working correctly, you should see the exhaust valve open slightly just after the intake valve closes. I'll attach a video to show what it looks like. Replacing the bad part is a bit of work but not terrible.
Dec 02, 2013 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Cub cadet ltx 1050 extension spring where does it go
In case anyone has a 2014 Cub Cadet LTX 1050 KW and needs to know where the damned spring goes when it falls off when removing the belt keeper, here's a photo.
Jul 15, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Battery wont stay charged
HAVE YOU CHECKED THE CHARGING SYSTEM? YOU COULD HAVE A BAD VOLTAGE REGULATOR. ITS REAL SIMPLE TO DO.START THE MOWER,PUT IT AT FULL THROTTLE.TURN A MULTI-METER TO VOLTS AND TOUCH THE BATTERY.YOU SHOULD READ 13.5-14.6 VOLTS.IF NOT GOOD CHANCE THE VOLTAGE REGULATOR IS NO GOOD.
Jul 19, 2009 | Oregon Scientific Electric PTO Clutch for...
Garden Logo
682 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
