Question about Kenmore 91112 / 91114 / 91117 Electric Kitchen Range
Bake element got very bright then sparked and caught fire.
I ordered a new element. Should I be worried about anything else besides just replacing the bad element?
    President:
  • 1,136 Answers
Hi, Just go ahead and replace the old element. It happens with no real reason. The new element should work great.
Vic
Posted on Jun 20, 2009
Oven element burned through into half, what do i do?
Here is that element to order. There is also a video on that same page to show you how to make the repair.
GE WB44T10011 Oven Bake Element AppliancePartsPros com
Apr 03, 2014 | GE JBP82 Electric Kitchen Range
The coil in my oven caught on fire
You will need to replace the element, If it was just the lower bake element, it is a very easy repair, two screws and two wire connectors. UNPLUG the stove FIRST!!
Jul 01, 2010 | GE Spectra JBP78 Electric Kitchen Range
The baking element isn't working.
You can replace the element. The element should just plug in to the oven. You might have to remove a few bolts that hold the element in place. Get the model number of your range and call your local appliance stores, or order it online. Unplug the old element and plug in the new element.
Apr 28, 2010 | Kenmore 96012 / 96014 / 96019 Electric...
Bottom element doesnt work in oven, but top does.
NOPE!
  1. Broil element does not have welded-on legs and will touch the bottom of oven, overheating itself and will end up the same way your bake element did; besides, the bottom of the oven will corrode pretty quick
  2. Many ovens use both elements during bake cycle
  3. self clean cycle uses broil element
  4. The bake and broil elements typically have different mounting brackets and screw holes ate in different places
  5. you'd have to cover the hole, left after removing the broil element, and insulate the wires, which went to broil element
  6. the ends, protruding behind the mounting bracket may have different length and different connectors. you may end up shorting the wiring to the casing, which may in turn destroy the control board if there is one
  7. Bake elements usually cost only $40-$60. No jury rigging required.
Hope this helps ;)
Mar 29, 2010 | Ovens
Baking Element Caught fire
Elements wear out from the inside. Sooner or later it happens to all of them.
Mar 31, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
I have a Magic Chef range. My baking element in the oven caught fire and broke in half from the heat. I am trying to replace the element but am not sure if I am supposed to disconnect the element from the...
hi!!! All you have to do is go and buy a new heating bake element..turn off the power to the oven by the home breaker..then move the oven away from the wall and remove the back panel screws and look for the baking element it has 2 wires going into it.Very easy to fix..good luck..
Jan 03, 2009 | Kitchen Ranges
Baking element
oh bleep, right? well, if you're lucky this will get you going again. 1. disconnect power to range. 2. remove back metal cover just above range power cord (usually 5 quarter inch hex screws) 3. look for burnt off wire leading to/from bake element. If yes, 4. strip ends of broken wire and splice with ceramic wire nut if no 4. bad news. replace ERC (electronic range control) you fried something on the board. It's got the clock display and all the electronics behind it.
Aug 29, 2008 | GE JBP90 Electric Kitchen Range
Troubleshooting failed bake element
What exactly do you mean when you said element caught on fire?
Jul 31, 2008 | Ovens
this a common complaint when the element burns out it is scary to see but all you need to do is replace element
Apr 21, 2008 | GE Profile 30" Free-Standing 5 Burner Self...
Kenmore 91112 / 91114 / 91117 Electric Kitchen Range Logo
118 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
