Question about GE Profile WPRE6100G Top Load Washer
GE Drain Hose
I bought a new GE profile washing machine and the drain hose is too short. It is connected to an extender hose and clamped but it is still leaking. Is there a better way to seal the two or do I need a longer hose? If I need a longer drain hose, where do I buy one? Thanks!
  • yates_perry Jun 20, 2009
    Yes, it does have to pump UP about 2 more feet beyond the normal mid-wall hookup that you typically see. It is in the basement and the pipes are just higher.
    President:
  • 1,136 Answers
Hi, Does this washer have to pump the water up into a drain? If it is possible, it would be better for the machine if you can bring the drin pipe closer to the washer. I know it is not always a possibilty. The longer the drain hose, the harder it is on the washer and sometimes the cloths don't spin out as dry as they will with a short drain hose.
Vic
Posted on Jun 20, 2009
  • Victor
    Victor Jun 20, 2009
    That is not to bad. Is the leak at the joint of the original drain hose and the etension? If the drain hose to the washer is plastic, you might be able to wrap it with plumming tape and tehn put the extension hose on it. Use a hose clamp that you tighten with a nut driver. Don't use a sqeeze clamp.
    Vic
Tub has come off its springs?? rince cycle clothes still very wet. how to fix diy??
Step 1 - Record Specifications Carefully read your owner's manual to find the specifications for the washing machine drain hose. If you are unable to locate it, look at the steel tab at the back of the washing machine, and write down the model and serial number instead.
Step 2 - Purchase New Hose Head to your hardware store and show this information to a representative to get help in finding an appropriate replacement drain hose.
Step 3 - Cut the Power and Water Before you start replacing the washing machine drain hose, make sure to pull the power cord out the wall socket. Better yet, turn off the power supply to the washing machine at the circuit breaker.
Similarly, turn the knob on the water supply line to the washer. If you cannot locate it then temporarily turn off the water altogether. Afterward, lift and shift the drain tube into a bucket, so that any accumulated fluid in the hose will fill this instead of spilling out all over the floor.
Step 4 - Remove the Old Drain Hose Your drain hose will be held in place by clamps attached at the back of the washing machine. Hold the clamp with pliers and unscrew it out of its position with a screwdriver. After removing the clamp, inspect it. If it is not damaged or corroded by rust it can be used again, but if not toss it away and install a new clamp after the replacement hose is in place.
Step 5 - Secure the New Drain Hose Take the new hose and slide the clamp on; it should go through the straight end. Now, place the hose onto the connector located at the back of the washing machine, and slide the clamp to where the hose rests on the connector. With a wrench, make the hold of the clamp tight. Make sure it is fit in properly so that you will have no problems with leakage.
Step 6 - Put the Machine Back and Test Place the washing machine back in position, and reconnect the drain tube to the pipe. Then, turn on the power supply and open the water supply so you can test that everything is working as it should.
Jan 11, 2017 | Washing Machines
Water leaks from underneath my washing machine. how do I fix it? the hose is connected properly, too
Water leakage
1. Inlet hose loosely connected to valve---tighten hose connection
2. Drain hoses not tight on pump----tighten hose clamps
3. Broken hose---replace hose
4. Leaky gasket---replace gasket
5. Cracked housing---replace part
Sep 22, 2011 | GE Washing Machines
I have a ge profile washer machine washes and spins but wont drain
Hi.
Disconnect power, then locate the access to drain pump. On GE top loader the pump access is usually at the back, sometimes at the bottom. Disconnect the hose from the pump and remove any blockage in there.
Check also the height of the drain hose at the back and ensure that the hose is set according to manual. An drain hose set incorrectly will result in drain problems.
If that does not fix the problem, clean or replace the pressure switch and pressure hose that detects water level determining when to start and stop draining.
Regards.
Ginko
Jul 08, 2011 | GE Profile WPRE8100G
How do you replace drain hose?
Sorry to read about your problem, I hope this helps you out.
just pull the machine out, remove the clamp, on the drain hose, put on new hose, and put clamp back on, or purchase a new clamp...home depot/ace hardware..when you buy your new hose, some come with clamps.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 05, 2011 | GE Spacemaker Washer and Dryer Electric...
My water is draining out of my machine as it is filling, Why?
This is a condition known as syphoning. Your drain hose on the washer needs to go up before it connectes to the house drain. It needs to rise as high as the washing machine top then hook over the drain pipe. If the drain hose is pushed too far into the drain pipe this can also cause syphoning.
Here are some tips to help describe this better.
Is the drain hose extending more than 8" (20.3 cm) into the drainpipe?
The drain hose may be too far down inside the drainpipe (standpipe) or laundry tub. Drained water can siphon back into the washer if the drain hose extends too far. Make sure that the drain hose does not extend more than 8" (20.3 cm) into the drainpipe or laundry tub. Using the U-shape drain hose form (as described in the Installation Instructions), will provide the correct length of drain hose in the drainpipe or laundry tub.
Drain hose form
Is the drain hose taped onto the drainpipe? Is top of the drainpipe covered in tape?
Do not seal the drain hose into the drainpipe with tape. The drain hose should be loose, yet secure. There must be a gap between the drain hose and the drainpipe to allow air to flow. The air gap will break the suction. This will keep water from being continuously sucked out of the machine (siphoning) as it fills.
Is the drainpipe (standpipe) less than the minimum height of 39" (99 cm)?
Make sure that the top of the drain is at least 39" (99 cm) high (as measured from the floor.) If the drain is below 39" (99 cm), the water will start to flow out of the machine due to gravity. The flow of water can create suction (siphon) and the water will continue to drain out of the washer.
Apr 19, 2010 | GE Washing Machines
How to extend the drain hose Siemens SL34A006UC/22 Dishwasher
get another hose same diamiter and two hose clamps and a splice nipple from hardware store, cut hose to lenght with some extra insert nipple into both hoses and clamp with hose clamps make sure you get them tight.. use a metal nipple as a plastic one may crack when you clamp hoses
Dec 13, 2009 | Siemens Dishwashers
Washing machine drain hose too short
add extension with hose clamps will be fine
May 26, 2009 | Washing Machines
New hook up for drain on a GE WBB4500GOWW.
On some models, their is a female drain hose that you can purchase from your local appliance parts dealer that should be inserted only. Not your traditional clamp type. Runs about $9 dollars or so and tycally has a triangle collar that is connected along with the drain hose. Does this help?
Jan 26, 2009 | GE Profile WPRE6100G Top Load Washer
Ge Profile Harmony Washer doesn't drain properly.
It sound like you have a blocked pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it. Good luck!
Aug 16, 2007 | GE WPGT9360EPL Top Load Washer
GE Profile WPRE6100G Top Load Washer Logo
464 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
