Question about Maytag Dryers
Maytag Nepture dryer displays a upside down F5 code, control loco
Does anyone know how to fix this or why it happened.
  • 317 Answers
SOURCE: my screen is upside down
Hold down CTRL-ALT- UP arrow key
Posted on Nov 13, 2007
  • 5 Answers
SOURCE: Hotpoint Ultima (WT960)
this worked for me:
First empty the machine by lowering the hose at the rear to ground level into a container. Take off the white plastic cover on rear at bottom. You will see black rubber hose connected to barrel of machine in right hand corner. Undo the silver screw on the band securing the hose. (Biggest band). You can now pull the hose down to reveal a "table tennis like" ball. Lift it out carefully and you will probably find an obstruction like a coin or similar. I found a hairgrip but it was enough to stop the ball functioning. DO NOT TAKE OFF THE WHITE HOSE CLIPS
Comment by pulmicort, posted on Feb 02, 2008 Further to my comments re clearing scrap from table tennis ball after code F4. Machine started ok but then F5 came up. Had to take the pump off and apart to reveal broken hairclip actually seized in pump. If you are handy at all this is simplicity itself.
Slide pump to left and lift and it comes clear. Take off 2 black hoses only where connected to main machine. Pull off electrical connection. Pump and hoses lift out easily. 3 screws open the pump. Clean any obstruction and reassemble. A 30 minute operation.
Posted on Apr 16, 2008
  • 85 Answers
SOURCE: Maytag Nepture washer error code:
this is a code for too much soap is being used add vinager to wash tub to eliminate residual soap and run an empty cycle to rinse out. then use only 1 oz of HE type detergent only per load
Posted on Dec 14, 2008
  • 16 Answers
SOURCE: Display is completely upside down
You can often press CTRL + ALT + UP/DOWN to rotate the screen if you have an integrated Intel Graphics card. Or it could be CTRL + SHIFT + UP/DOWN. One or the other.
Posted on Dec 15, 2008
  • 54 Answers
SOURCE: my desktop is displaying everything upside down?? its vista
Hold down CRTL + ALT and the up arrow and that should rotate the display to the right direction.
Posted on Jun 27, 2009
I am trying to find a replacement part for a 24 Maytag Wall Oven, model CWG3100AAB. I am getting an F5 code, and I believe that means it is the ERC electronic control board.
Single/Double Wall Oven - Error Code/Message - F5 Error ...
www.maytag.com/...wall-oven...code...f5...code-f5-e0/PH7028/
MaytagHave a Maytag product question? Maytag's product help articles give answers to your frequently asked questions (FAQs).
Sep 30, 2015 | Maytag CWG3100AAB Wall Oven gas
What do Error codes F04 and E03 mean?
The dryer is in need of service if a code beginning with an "F" appears in the display.
Alternating between F# and E#, the dryer control has detected a problem that requires service.
Call for service.
May 04, 2014 | Maytag Maxima EcoConserve Series MED6000XW
Displaying upside down f5 and beeps 5 times. Cleaned piles of lint out of the dryer. Some of which was starting to burn, the wires to the thermristor were melted, fixed those. The thermristor ohm'ed out at...
okay after looking up everything sounds like you need to replace the thermistor they definitly cant be jumped off and it should be under 10 ohms. Get the model number and goto your local parts house they should have that on there shelves and replave it should work after that.
Jan 06, 2011 | Amana NED7200TW Electric Dryer
I have a 10 year old Maytag Nepture MDE5500ay with a membrane control panel. When I touch any button on the membrane it immediately indicates a 8.8. on the display. I have unpluged the machine and waited...
The 8 code generally means a stuck keypad which can only be resolved by replacement of the keypad.
The service manual at the link below will give you some guidance in section 9. Good Luck
MDE5500 Service Manual
Oct 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Control Panel frozen. Displaying "8.8." Cannot reset.
controls were somewhat an issue with these. but service manual can be found in the maytag library at servicematters.com it will detail method of entering diagnostic and reading codes. post results
May 01, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Replaced belt & pulley, now drum won't spin properly
Belt mounted upside down. Slick side goes to tub on this odd ball machine.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 08, 2009 | Maytag SDE2606 Electric Dryer
MDE 9700 AYW Maytag neptune dryer
My dyrer just stopped working one day. I've had the heating element checked, both boards and my electrical outlet checked but my dryer still doesn't work. All I get is a troubleshooting code that looks like an upside down F with a 5 behind it. If you have a solution to this problem please let me know Thank You.
Dec 05, 2007 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag Oven Error Code
main board bad or sensor .more likely board though
Nov 12, 2007 | Maytag Atlantis MDE7400AY Electric Dryer
Neptune Dryer
My maytag neptune dryer quit heating, after my wife changed the temp setting on the console from regular, to extra low drying temperature. The heating element reads 10.5 ohms. The thermal cutoff reads 0.02 ohms. The hi-limit thermo reads 0.02 ohms. The power coming into the dryer is 240 volts. What can I check or need to replace.
Dec 05, 2006 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
52 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
